bishop Posted September 27, 2019 Report Share Posted September 27, 2019 Had a strange oddity today. Took lad from work for a spin went to show him launch control and it sat spinning the front wheels for a second before getting up and going. I’ve only done launch once before and it was damp but went like a rocket. I just had the haldex serviced yesterday. Has anyone had this before? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 Had a strange oddity today. Took lad from work for a spin went to show him launch control and it sat spinning the front wheels for a second before getting up and going. I’ve only done launch once before and it was damp but went like a rocket. I just had the haldex serviced yesterday. Has anyone had this before? Sent from my iPhone using TapatalkPossibly just didn't get it quite right, easily done. Did you try it again with the same results? Maybe you fully disengaged traction control ie did a long press instead of a short one?Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 Possibly just didn't get it quite right, easily done. Did you try it again with the same results? Maybe you fully disengaged traction control ie did a long press instead of a short one?Sent from my SM-G950F using TapatalkYes I did fully disengage traction control. Should I only do the quick press?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 It’s also dsg so kinda hard to get wrongSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 It’s also dsg so kinda hard to get wrongSent from my iPhone using TapatalkI believe it's just a quick press, I've only done it a handful of times and never had the issue you mentioned. It actually is quite easy to mess up, especially if you dont really step on the brakes.Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 I believe it's just a quick press, I've only done it a handful of times and never had the issue you mentioned. It actually is quite easy to mess up, especially if you dont really step on the brakes.Sent from my SM-G950F using TapatalkYes same only second time doing it. The first time I think I just did a quick press and it was fine didn’t think turning it off would make such a negative difference. I also tried to do it again to test for the same results and it wouldn’t engage launch just popped up the warning light. Turned off and back on and it was gone bit strange Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2019 Report Share Posted September 27, 2019 Yes same only second time doing it. The first time I think I just did a quick press and it was fine didn’t think turning it off would make such a negative difference. I also tried to do it again to test for the same results and it wouldn’t engage launch just popped up the warning light. Turned off and back on and it was gone bit strange Sent from my iPhone using TapatalkYeah I think that's probably what it was so doing the long press the car didnt actually go in to launch mode so you just did a quick start with traction control off hence the wheel spin. Nothing damaged I'm sure except a little pride lolSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 Yeah I think that's probably what it was so doing the long press the car didnt actually go in to launch mode so you just did a quick start with traction control off hence the wheel spin. Nothing damaged I'm sure except a little pride lolSent from my SM-G950F using TapatalkIt did pop up saying launch activate just was like a front wheel drive spinning up for a second or 2 before going. Then when I tried again it wouldn’t engage at all Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 Just strange as it worked fine the first time but now I had the diff serviced it’s acting weird Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blower Posted September 27, 2019 Report Share Posted September 27, 2019 Launch control will work with either ESC sport (short press) or ESC Off (Long press). Regardless if ESC is in sport or Off it shouldnt spin wheels much - hardly at all (unless all 4 are spinning due to soaking wet conditions and/or crap/worn tyres) If just your front wheels are spinning then there is something wrong with the haldex system - regardless of launch, esc setting etc - either all 4 wheels spin, or none at all. If just the fronts the haldex is fubared. Scotty2hotty and gregozedobe 2 Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 Launch control will work with either ESC sport (short press) or ESC Off (Long press). Regardless if ESC is in sport or Off it shouldnt spin wheels much - hardly at all (unless all 4 are spinning due to soaking wet conditions and/or crap/worn tyres) If just your front wheels are spinning then there is something wrong with the haldex system - regardless of launch, esc setting etc - either all 4 wheels spin, or none at all. If just the fronts the haldex is fubared.Well it’s weird it was like a proper burn out then after like 2 second it shot off like expected. It was working fine last time I tried it in the wet now I had the haldex serviced yesterday and it’s done thisSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blower Posted September 27, 2019 Report Share Posted September 27, 2019 2 minutes ago, bishop said: Well it’s weird it was like a proper burn out then after like 2 second it shot off like expected. It was working fine last time I tried it in the wet now I had the haldex serviced yesterday and it’s done this Sent from my iPhone using Tapatalk Sounds like there is a problem with the haldex system - best get it checked, get codes read. Did they just do an oil service or did they also remove and clean the pump (and its little mesh filter)? gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 Sounds like there is a problem with the haldex system - best get it checked, get codes read. Did they just do an oil service or did they also remove and clean the pump (and its little mesh filter)?Yes filter and oilSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bishop Posted September 27, 2019 Author Report Share Posted September 27, 2019 So I just popped out and tried it again and it worked fine. Could there of been an airlock or something from the pump being removed and clean (I’m not to sure how it works) that caused it to engage slowly that first time?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blower Posted September 27, 2019 Report Share Posted September 27, 2019 1 hour ago, bishop said: So I just popped out and tried it again and it worked fine. Could there of been an airlock or something from the pump being removed and clean (I’m not to sure how it works) that caused it to engage slowly that first time? Sent from my iPhone using Tapatalk Completely possible! Quote Link to comment Share on other sites More sharing options...
