SpaceMonkey Posted December 1, 2019 Report Share Posted December 1, 2019 Could someone explain this please? When unlocking the car (2019) the headlights come on for 30 seconds and light the area/path you are on. However when locking the car the headlights turn off immediately and do not light the pathway. I've had this function on all my last 3 cars and have only just realised its not working on the Golf R as i expected. My settings are in the pic. I have tried this on another Golf R (2016) and the exact same thing happens. Thanks. Quote Link to comment Share on other sites More sharing options...
MarkH Posted December 1, 2019 Report Share Posted December 1, 2019 I can answer this one. When you switch off the engine and before you get out of the car flick the main beam stalk on the steering wheel. Get out of the car, lock the door and the lights will stay on for 30 seconds. goodbadboy and JonSW 1 1 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 1, 2019 Report Share Posted December 1, 2019 This can be changed to automatic when opening the doors with VCDS. I have done this on all my Golfs. You can also turn off the coming home lights with a unlock, lock on the key as you walk away. Looks very cool when someone says Oi you have left your lights on. (few button presses to impress) Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 1, 2019 Report Share Posted December 1, 2019 Unfortunately unless you code it, you have to do the stalk method every single time which is a bit annoying. As above though, you can code it with VCDS or obdelven. I used the latter to do mine, coding here Quote Link to comment Share on other sites More sharing options...
SpaceMonkey Posted December 1, 2019 Author Report Share Posted December 1, 2019 thanks to all, just tried it and 100% works. Great. goodbadboy and Booth11 2 Quote Link to comment Share on other sites More sharing options...
RGirl Posted December 3, 2019 Report Share Posted December 3, 2019 On 01/12/2019 at 09:09, TechieAli said: This can be changed to automatic when opening the doors with VCDS. I have done this on all my Golfs. You can also turn off the coming home lights with a unlock, lock on the key as you walk away. Looks very cool when someone says Oi you have left your lights on. (few button presses to impress) Or you can use OBD11. I used that to code mine but yeah either can be used to gain that function Quote Link to comment Share on other sites More sharing options...
