Djs2394 Posted September 2, 2020 Report Share Posted September 2, 2020 Hi All, Any reason why when I get in the car, put my foot on the brake and hit the start button it normally doesnt work first time, usually doesnt work 2nd or 3rd time either. Seems to be random how many times I need to press it to start the engine however it will normally stop the engine on the first press.. Any ideas? Faulty start/stop switch? Cheers for any ideas.. Quote Link to comment Share on other sites More sharing options...
Stobsie Posted September 2, 2020 Report Share Posted September 2, 2020 Sounds as if the switch Is detective had similar on our A5 and the switch was replaced under warranty. Djs2394 1 Quote Link to comment Share on other sites More sharing options...
Matt7R Posted September 2, 2020 Report Share Posted September 2, 2020 Sounds to me that the sensor that detects the brake is pressed is defective. If it's switching off first time (when you don't need to touch the brake) that might account for why it's less reliable when turning on. Have you tried pressing the brake really hard and then the switch to see if it turns on more reliably? ---------------------------------------------Come on, get up. Let me see your bruises.--------------------------------------------- Stobsie 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 3, 2020 Report Share Posted September 3, 2020 I've read a few reports of faulty stop/start switches, so it is most likely the switch (but worth checking Matt's suggestion as well). To check if it's the switch or the brake sensor try the on/off button without touching the brake, if the switch is faulty nothing will happen, if the switch is working it will turn the car on without starting the engine (= old "accessory" mode). Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted September 3, 2020 Report Share Posted September 3, 2020 Never had an issue with mine....Works flawlessly every time...Good luck with sorting the problem..Let us know how you get on getting it checked out Quote Link to comment Share on other sites More sharing options...
jebjeb Posted September 22, 2020 Report Share Posted September 22, 2020 I found that if you are a bit quick with it all it often doesn't work, i.e. jump in the drivers seat, close the door, foot on brake and stop the start/stop button in a couple of seconds and often it will just turn it on to "ignition" but not start the engine. But may be more of a fault if it is taking a few presses. Quote Link to comment Share on other sites More sharing options...
Costanator Posted September 28, 2020 Report Share Posted September 28, 2020 I found that if you are a bit quick with it all it often doesn't work, i.e. jump in the drivers seat, close the door, foot on brake and stop the start/stop button in a couple of seconds and often it will just turn it on to "ignition" but not start the engine. But may be more of a fault if it is taking a few presses.I agree. I've had to "slow my roll" when getting in my R. I've really noticed the parking brake switch to not like the quickness I'm expecting out of it. Sometimes several presses before I realize I'm needing to be more intentional with my press of it. JoshSent from my Pixel 2 XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
DazR Posted October 12, 2020 Report Share Posted October 12, 2020 I’ve heard a lot of people disconnecting or dialling out the start stop feature Quote Link to comment Share on other sites More sharing options...
