98 RON Minimum
Blackpug
It's a choice thing some will say some high octanes are not as good as others due to adding bits to the mix
as long as it is as recommended it's fine .
I wouldn't run 95 oct unless in Emergency as it's set up for 98 . The car will alter it's own settings but it's
not instant ,lots of theories best stick to the Instructions on the tin as it were :wink:
This will help read the page and click on the retailers logo's bottom of page for their Individual fuels available :wink:
http://www.petrolprices.com/about-fuel.html
That's awesome, thanks!
Using Tesco Momentum while I can get money off via the weekly shop. If the offer does end in September it'll probably be back to good ol'95 - ran my 6R for 3 years on the stuff without any problems at all. :afro:
You won't have any problems with 95, however I'd expect it to be down on power and possibly worse fuel economy .
IMHO, don't be tight , use 98 :afro:
I just use shell vpower nitro+ it is a true RON98 and where I live only about 4p more than standard. The only alternative I use would be Tesco RON99 but I haven't had a need for that yet. Plenty of shell garages about. And I tend to fill up once I've gone below half full when I pass one.
By my calculations it would be about £144 pounds extra in fuel of my lifetime ownership. Just not worth it to run on anything else than what is recommended.
I thought v-power nitro was 99RON and 8p more?
I thought 98 but 99 is fine as well as it is a 98 minimum. For me locally there is only about 4p between it. Naturally fc each garage is different.
Shell used to be VPower RON98, but now VPower Nitro+ is RON99
VPower has always been 99, it was Shell Optimax that was 98.
The old V power (Optimax?) was 98 Ron and new Nitro+ V Power is 99, same as Tesco momentum 99.
I am fortunate enough to live 2.5 miles from a shell station and 8 miles away from 2 Tesco momentum stations.
There has been lots of talk (thats mostly what it is) about which is better (V Power or Momentum) as they have not been independantly tested together in the same conditions as to which performs better (we all know which is lower priced = Tesco).
I will put in whichever I happen to be going past on that day :afro:
Said that this morning :afro:
Cheers, from that site I've come up with this list
Tesco Momentum: 99 - http://www.petrolprices.com/tesco.html
Shell V-Power: 99 - http://www.petrolprices.com/shell.html
BP Ultimate Unleaded: 97 - http://www.petrolprices.com/bp.html
Total Excellium Unleaded: 97 - http://www.petrolprices.com/total.html
Esso Energy unleaded: 97 - http://www.petrolprices.com/esso.html
Super unleaded: ?? - http://www.petrolprices.com/texaco.html
Sainsburys: ?? - http://www.petrolprices.com/sainsburys.html
ASDA: ?? - http://www.petrolprices.com/asda.html
Morrisons: ?? - http://www.petrolprices.com/morrisons.html
I'm guessing the unknowns (??s) are all going to be 97RON, so that only leaves Tesco and Shell if you want 98+...
Will have to make do with super unleaded 97 Ron as N Ireland doesn't get 98 or v power nitro. Bar 3 stations in Belfast which would be a 80 me round trip.
@bigmac3161 Where are the 3 in Belfast - keen to know.
Was searching Subaru forums fi 98 Ron and they said there are 3 texaco stations that do 98 that's it one on road to Bangor as for the other two not sure.
