bigearmuffs Posted November 16, 2020 Report Share Posted November 16, 2020 I've always thought the Golf R headlight range was too short, I've had my Golf R (2014) from new and have recently bought a new VCDS, mainly for service lights, fault codes etc as I now maintain the car rather than a garage and will most likely continue to do so. As I was looking through VCDS I suddenly thought I could cure my headlight throw problem, however from initial research and a quick look around VCDS this looks like the most confusing thing in the world, youtube videos don't seem to help as they don't look to be using the most recent version of VCDS. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Richard_Nottm Posted November 16, 2020 Report Share Posted November 16, 2020 57 minutes ago, bigearmuffs said: I've always thought the Golf R headlight range was too short, I've had my Golf R (2014) from new and have recently bought a new VCDS, mainly for service lights, fault codes etc as I now maintain the car rather than a garage and will most likely continue to do so. As I was looking through VCDS I suddenly thought I could cure my headlight throw problem, however from initial research and a quick look around VCDS this looks like the most confusing thing in the world, youtube videos don't seem to help as they don't look to be using the most recent version of VCDS. Any help would be greatly appreciated. Im sure there's an adjustment screw for L and R. Defo seen an article on here. Raises or lowers them. Im sure owners complain too low from factory, bigearmuffs 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 16, 2020 Report Share Posted November 16, 2020 8 minutes ago, Richard_Nottm said: Im sure there's an adjustment screw for L and R. Defo seen an article on here. Raises or lowers them. Im sure owners complain too low from factory, Yes there’s physical adjustment that can be done. Pics are unfortunately hard to see now but here’s a guide that many follow for a mk7. http://www.golfgtiforum.co.uk/index.php?topic=276375.0 It’s a bit different for a7.5 and there’s a guide in our own how to section for that. Not sure this is of any help @bigearmuffs as not really what you were asking. bigearmuffs and Richard_Nottm 2 Quote Link to comment Share on other sites More sharing options...
bigearmuffs Posted November 16, 2020 Author Report Share Posted November 16, 2020 Thanks all will give that a go. Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 16, 2020 Report Share Posted November 16, 2020 1 hour ago, bigearmuffs said: I've always thought the Golf R headlight range was too short, I've had my Golf R (2014) from new and have recently bought a new VCDS, mainly for service lights, fault codes etc as I now maintain the car rather than a garage and will most likely continue to do so. As I was looking through VCDS I suddenly thought I could cure my headlight throw problem, however from initial research and a quick look around VCDS this looks like the most confusing thing in the world, youtube videos don't seem to help as they don't look to be using the most recent version of VCDS. Any help would be greatly appreciated. @bigearmuffs: Hi. Why do you believe that the Golf R has a throw problem? Does the car have any errors on the auto-scan? I assume that we are dealing with HID lamps - if so, you could try resetting the car's understanding of level-ground - see the procedure below. Headlight - basic setting Don Quote Link to comment Share on other sites More sharing options...
bigearmuffs Posted November 23, 2020 Author Report Share Posted November 23, 2020 woohoo, done, I don't know if anyone can beat it but that is a job I have been saying needs to be done for 6 years, and it only took 5 mins. I have no idea why I didn't look before but on the headlight is two allen key adjusters per light, one does direction and the other does height. So turn to raise or lower. Simply parked the car up with the lights on and wound them up until the desired height was reached. It is spot on now. Thanks all. gregozedobe and Booth11 1 1 Quote Link to comment Share on other sites More sharing options...
