smug_1273 Posted January 7, 2022 Report Share Posted January 7, 2022 Looking into updating my map software to the latest version (currently 19 version installed in car) from what I have read no SD card supplied with the Pro Navigation System which I have, on the screen in the version section it has 2 tabs. The first says 'Update SD/USB' and the second 'Update online' Have gone to the VW website and downloaded the only Europe download available for the 2019 7.5r with Pro Navi System. Unzipped it on my MacBook desktop, then copied the complete folder onto a formatted 64gb sandisk USB flash drive (not sure whether I need to select only certain sub folders inside the main folder, there are so many) so just copied the main initial folder. I have then plugged into the usb slot in the cubby under the Nav system then selected the previously mentioned 'Update SD/USB' tab to which it displays looking for data but eventually comes back with nothing found. I tried this several times with formatting in MFAT and EXFAT types but still no joy. Wondered if anyone knew of a current walkthrough for my car model and pro navi using USB flash drive? thanks in advance. Quote Link to comment Share on other sites More sharing options...
DustyBones Posted January 9, 2022 Report Share Posted January 9, 2022 This any help : - https://app-connect.volkswagen.com/mapupdates/car/ and this - has info about using Mac OS https://app-connect.volkswagen.com/mapupdates/manuals/Discover_Pro_November_2020_EN.pdf Cheers smug_1273 1 Quote Link to comment Share on other sites More sharing options...
TweedsideR Posted January 9, 2022 Report Share Posted January 9, 2022 To the best of my knowledge, the Discover Pro system (MIB2) does have two SD card slots in the glove box, just above (or below) the CD slot. Plug your SD card into the left-hand one and try the update options again. I don't know about the Mac system, but on my windows system, the Mib1 and Mib2 folders, along with metainf.txt and WMPinfo.xml files are all in the root (first) folder on the SD card. This worked perfectly on my 2019 Discover Pro. smug_1273 1 Quote Link to comment Share on other sites More sharing options...
smug_1273 Posted January 9, 2022 Author Report Share Posted January 9, 2022 2 hours ago, TweedsideR said: To the best of my knowledge, the Discover Pro system (MIB2) does have two SD card slots in the glove box, just above (or below) the CD slot. Plug your SD card into the left-hand one and try the update options again. I don't know about the Mac system, but on my windows system, the Mib1 and Mib2 folders, along with metainf.txt and WMPinfo.xml files are all in the root (first) folder on the SD card. This worked perfectly on my 2019 Discover Pro. Hi, yes I do have the 2 SD slots but no card came with the car so was trying to use a USB instead. Did you use a VW SD card or a 3rd party one and what size? When I download the relevant files. when I open the root folder as you call it yes there are 3 items/folders (metainf.txt , MIB1, MIB2), did you just copy the MIB2 folder only from these 3 onto your SD card? or did you copy all, or did you open the MIB2 folder and then copy all the files from inside this folder? thanks Quote Link to comment Share on other sites More sharing options...
TweedsideR Posted January 13, 2022 Report Share Posted January 13, 2022 i used a standard Sandisk SD card. You do not need a VW card for the Mib2. I simply copied all the files to the SD card. Then you plug the SD card into one of the SD slots in the glovebox and follow the options to update the Nav. It takes about 20 seconds to "find" the card so don't panic. It then takes about 30 minutes to update the maps, but it does show you the progress in %ages. Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 13, 2022 Report Share Posted January 13, 2022 Use a good quality class 10 SD card, and follow @TweedsideR instructions. It can be very hit and miss on a Mac, so keep trying if it fails first time. Quote Link to comment Share on other sites More sharing options...
Deano Posted January 13, 2022 Report Share Posted January 13, 2022 Can you not connect the car to your phone and download the maps straight to the infotainment system? I seem to recall doing it this way before. Quote Link to comment Share on other sites More sharing options...
