Help
Benmk7
Hi basically I own a golf r an it was on stage 1 we removed the map and set it back to stock but before this my engine blown up twice and now we have decided to remove the map main issue’s are Piston cooling jet solenoid I have changed the sensor but unfortunately still showing this problem I drive the car for a min or 2 the epc and rpm comes on may I get some help the mechanic is blaming that my ecu has a problem and that it should be repaired any ideas !
  • Replies 9
Posted Images
Hi Ben
Sorry to hear of your issue.
Just to advise that you posted up multiple threads on the same topic across the forum.  You only need one thread for the issue so I’ve removed the other threads and keep this one in the mk7 section.  The FAQs section is for site/forum issues as opposed to car issues. 🙂
39 minutes ago, golf7.5r said:
When you say your engine blew up, what do you mean exactly? Unlikely an ecu would cause this, more likely to be oil starvation, oil contamination or has been rebuilt badly at some point.
Basically engine blew up meaning the crankshaft got scratched up from low oil pressure everything in the engine is new including new oil pump but now I drive the car for one min the epc and rpm light comes up and I can’t drive it losses full power
2 hours ago, HalAdams said:
Where is your 'mechanic' who says the ECU is bad? Did s/he take and note the fault codes above?
Both codes are well documented on the internet - with the probable cause coming from your oil control valve.
He’s saying that the ecu isn’t responding the the piston cooling jet solaind we tested the capable and wiring seems fine Basically engine blew up meaning the crankshaft got scratched up from low oil pressure everything in the engine is new including new oil pump but now I drive the car for one min the epc and rpm light comes up and I can’t drive it losses full power and he is based in London also ecu was updated and I’m not sure how to fix this issue I can’t find any information at all all sensors are new too plus the mechanic just keeps blaming ecu can we make him wrong by fixing this issues by recommend what to change or what to do
With all due respect, it sounds like your mechanic knows not what he is talking about and you would be better off taking the car to a proper VW place.
And please do not say it is more expensive. Of course it is ! your car has an engine designed with fine parameters that should not be played with.
How pray, can a piston cooling solenoid be the cause of big/main bearing oil starvation? Piston cooling is spraying oil underneath piston crowns. No where near a crankshaft.
you gave two codes above. Why are you only focussing on one of them? I would look closely at the second code and apply some logic that says, in all probability, it is the piston cooling - and crankshaft oil supply - that are hindered by the second fault.
Isn't this regulated by a control solenoid in the oil filter bracket. It's not a sensor (there are also 2 x oil pressure high and low sensors in there as well).
Have you definitely replaced the control solenoid? What was the part number.
This issue with the oil pressure sensor fault make it sound like it might be contaminant debris causing them to block up ...maybe. could also correlate with the engine failures and debris that would of been circulating.
Have you replaced the oil pressure sensors?
This might help possibly quite a lot explain what I was referring to.
So, from my review of service diagram. It indicates.
2 x oil pressure switches in oil filter housing bracket 1 low pressure, 1 high pressure
1x spray nozzle valve solenoid in oil filter bracket
1 main oil pressure control valve in lower engine near crank pulley.
1 extra "level 3" oil pressure switch on front face of engine to right of water pump.  I didn't know about that one.
