-kenny- Posted August 1, 2024 Report Share Posted August 1, 2024 This could work for other mib3 cars aswell, but i tried in my mk8R. Came across these settings somewhere and decided to try. Has been working for me since 3 months now. Not a single bong. You do sacrifice travel assist and emergency assist ofcourse. Also, the capacitive steering wheel is disabled. Lane assist still works though. But it works by sensing weight and resistance on the wheel, as it does in older cars. These are the steps for obd11: Open bonnet and leave driver's door open. -Go to control units. -in ecu 13 adaptive cruise control, go to security access, it will generate a code automatically. If it doesn't do so, proceed without security access. Then go to long coding and change travel assist to 'disabled' -in ecu a5 driver assistance, go to security access, it will generate a code automatically. If it doesn't do so, proceed without security access. Then go to long coding and change emergency assist to 'not coded' an Klr to 'not coded' You don't always need security access. Some changes work without security access, i believe changing travel assist didn't. If it doesn't, try using security access. Be sure to make a backup of the original settings before changing them, in case you want to restore. I took screenshots before changing. This got rid of the errors for me. Hope you have the same luck. Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 1, 2024 Report Share Posted August 1, 2024 Thanks for posting. Great option for some. It’s not something I’ll do as all is ok since new steering wheel. Also I would not want to lost the capacitive steering wheel. Quote Link to comment Share on other sites More sharing options...
toughpower Posted August 15, 2025 Report Share Posted August 15, 2025 Not sure if this works on a Golf, but on my 2021 Škoda Octavia (MQB Evo) I kept running into random “Travel Assist unavailable” and “Emergency Assist unavailable” messages because of a faulty touch sensor in the steering wheel (KLR). It was pretty annoying. Instead of turning off Travel Assist in Module 13, I just disabled Emergency Assist and the KLR in Module A5 (Drive Assistants). Now Emergency Assist is gone—which I don’t really care about—but Travel Assist, Lane Assist, and other driver aids still work. They just don’t check for your hand on the wheel anymore and react to slight steering input instead. You might see the “Take Control” alert a bit more often, but a small turn of the wheel is enough to clear it. AHG 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted August 15, 2025 Report Share Posted August 15, 2025 Valuable information … Eliminate the issues without compromising on function and without cost true forum gold Quote Link to comment Share on other sites More sharing options...
hooch-85 Posted November 9, 2025 Report Share Posted November 9, 2025 On 15/08/2025 at 14:33, toughpower said: Not sure if this works on a Golf, but on my 2021 Škoda Octavia (MQB Evo) I kept running into random “Travel Assist unavailable” and “Emergency Assist unavailable” messages because of a faulty touch sensor in the steering wheel (KLR). It was pretty annoying. Instead of turning off Travel Assist in Module 13, I just disabled Emergency Assist and the KLR in Module A5 (Drive Assistants). Now Emergency Assist is gone—which I don’t really care about—but Travel Assist, Lane Assist, and other driver aids still work. They just don’t check for your hand on the wheel anymore and react to slight steering input instead. You might see the “Take Control” alert a bit more often, but a small turn of the wheel is enough to clear it. Thanks so much for this. Have done this coding today and haven't had a bong since. Hopefully it continues this way. Travel assist still works fine but SOS is disabled which is something I prefer anyway as I'd lost count of the amount of times I'd pressed it inadvertently! Quote Link to comment Share on other sites More sharing options...
