W4ff13 Posted October 14, 2024 Report Share Posted October 14, 2024 Hi All, Been reading the various posts and I'm looking at getting OBD11 Pro. I come from mk4 1.8T golfs, and used to have VCDS years ago, but sold the cable and never bothered with the coding side of things for years. I just wanted to check a couple of functionality things if I may with those with experience of OBD11 - I think the answer is yes but always good to ask! 1. Can you monitor live data, specifically things like Haldex oil temp for when you do the oil change yourself? 2. Can you function/cycle items on the car, specifically things like the Haldex pump and ABS pump (I assume if you ever get air into the ABS system you need to cycle the pump as per older VAGs)? 3. Can you backup/save profiles in case anything goes wrong - I assume it's fairly idiot proof in terms of having multiple confirmations before updating/changing key settings? TIA! Quote Link to comment Share on other sites More sharing options...
dv52 Posted October 14, 2024 Report Share Posted October 14, 2024 @W4ff13:Hi. When you say "I come from mk4 1.8T golfs" - does this mean that this is your current vehicle (being the car on which you intend to use OBD11)? If not - then it would be immensely helpful for the forum to understand what model/make/Brand vehicle you have!! OK - as for you questions, my general responses as follows below: Question 1: Yes, OBD11 will read and display "Live Data" from each of the modules. Of course, the exact information that can be monitored is determined by whatever facilities have been programmed into the module. Here's a short video that describes the Live Data function on OBD11: Question 2: I'm not sure what you mean by "function/cycle items on the car". The process for bleeding air from the brake system is manual, it isn't done by coding changes to the brake module and the Haldex pump is self contained.(so doesn't need bleeding) That said, each module will normally have a set of factory designed "Output Tests" - that can be used to ascertain if the module is functioning properly. Maybe this facility is what you mean by your question? If so, the following video might be useful Question 3: Yes, OBD11 has a Backup facility - which is a data-dump of the adaptation channel database (including channel values) in the module at the time that the file is created. OBD11 recommends that a Backup is created of any module (in its virgin state) before any coding changes are made. Backup files are stored against your OBD11 account and the information can be retrieved at will Making Backup files is time consuming - but it's an invaluable resource when (not "if") the moist stools in the brown stuff collide with the proverbial fan blades!!😀 So well worth the effort IMO Don W4ff13 1 Quote Link to comment Share on other sites More sharing options...
W4ff13 Posted October 16, 2024 Author Report Share Posted October 16, 2024 Hi Don, Thanks for the reply there. I've has a mk4 1.8T for 17years and just got myself a mk 7R so that's where my questions are arising from. As you're likely aware given the detail of your response the 1.8T is very basic compared to a 7R, and I guess I've spent that many years around mk4's that I wanted to check a couple of things. Q1 - mainly temps and maybe some air logging - looks like all this can be done so great news. Q2 - this is from a mk4 specific issue, if you ever had to replace a brake line and the ABS unit got air into it, there was no way to bleed it unless you used VCDS to cycle the pump (activate it when the car is off and not under a hard braking scenario). I was asking this in reference to doing a DIY Haldex oil change, including removal of the pump to clean the filter. I'm assuming air will be in there and you'd want to cycle the pump a few times and recheck level before calling it a job done. Q3 - Noted, as long as it has it then all good. Thanks again! I'll look to get it ordered next month I think. dv52 1 Quote Link to comment Share on other sites More sharing options...
xs2man Posted October 16, 2024 Report Share Posted October 16, 2024 5 hours ago, W4ff13 said: Hi Don, Thanks for the reply there. I've has a mk4 1.8T for 17years and just got myself a mk 7R so that's where my questions are arising from. As you're likely aware given the detail of your response the 1.8T is very basic compared to a 7R, and I guess I've spent that many years around mk4's that I wanted to check a couple of things. Q1 - mainly temps and maybe some air logging - looks like all this can be done so great news. Q2 - this is from a mk4 specific issue, if you ever had to replace a brake line and the ABS unit got air into it, there was no way to bleed it unless you used VCDS to cycle the pump (activate it when the car is off and not under a hard braking scenario). I was asking this in reference to doing a DIY Haldex oil change, including removal of the pump to clean the filter. I'm assuming air will be in there and you'd want to cycle the pump a few times and recheck level before calling it a job done. Q3 - Noted, as long as it has it then all good. Thanks again! I'll look to get it ordered next month I think. Just saw a promo code on FB today giving 20% off for today only. Not sure if it'll work later or not, but maybe it's a regular promo, so you never know? Anyway, code is TODAY20 if your interested. If it turns out to be a pain to get your full backup, I think you are pretty close to me, maybe. I can scan with VCDS for you before you start, which should capture the long coding, by the looks of it, for any module that has it. At least you would have that much backed up. I was thinking of grabbing OBD11 instead of upgrading my cable. As there is one module that my cable doesn't hit. But I am still unsure. And, to be honest, I have done all the coding I need just now on the Golf. That said, my Caravelle is also too new for my cable, so maybe I should grab the dongle just now with 20% off, and then get the plan later when I need it, ha ha. W4ff13 1 Quote Link to comment Share on other sites More sharing options...
W4ff13 Posted October 16, 2024 Author Report Share Posted October 16, 2024 Thanks @xs2man - yeah I think we're pretty close, happy to help out if I get OBD11 and you want to have a go with it before committing? I've got nothing just now so it's same initial outlay for me really. I'm not really an FB user but thanks for the heads up - I'll likely wait till Nov/Dec to buy it anyhow, not urgent just something I want to get before I actually need it for whatever reason - I waited too long to get my VCDS cable when I first got my mk4 as always regretted it as I could have done stuff myself sooner. xs2man 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted October 18, 2024 Report Share Posted October 18, 2024 Just buy it from Voltas IT (original maker) on their OBDeleven website or from a known and trusted soutce I read about too many people buy cheap online only to learn it is a knock off or somehow limited W4ff13 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted October 18, 2024 Report Share Posted October 18, 2024 On 17/10/2024 at 01:26, xs2man said: Just saw a promo code on FB today giving 20% off for today only. Not sure if it'll work later or not, but maybe it's a regular promo, so you never know? Anyway, code is TODAY20 if your interested. If it turns out to be a pain to get your full backup, I think you are pretty close to me, maybe. I can scan with VCDS for you before you start, which should capture the long coding, by the looks of it, for any module that has it. At least you would have that much backed up. I was thinking of grabbing OBD11 instead of upgrading my cable. As there is one module that my cable doesn't hit. But I am still unsure. And, to be honest, I have done all the coding I need just now on the Golf. That said, my Caravelle is also too new for my cable, so maybe I should grab the dongle just now with 20% off, and then get the plan later when I need it, ha ha. @xs2man: Yes, I agree - 20% discount is worth pursuing!! As I said on another thread HERE , as long as either of your cars don't have the newer form -SFD2 protection, OBD11 should work - and if the car has the older SFD - VCDS will NOT work!! Don't be "still unsure" - OBD11 ain't rocket science and there's lots of very knowledgeable folk in this place that can help! And in the unlikely scenario that you don't get satisfaction on this forum - come and have a chat on the OBD11 forum!! Don W4ff13 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted October 18, 2024 Report Share Posted October 18, 2024 4 hours ago, AHG said: Just buy it from Voltas IT (original maker) on their OBDeleven website or from a known and trusted soutce I read about too many people buy cheap online only to learn it is a knock off or somehow limited @AHG: Forgive the pedant in me - but a few comments below in response to your words above: Ain't no VOLTAS IT anymore - stuff recently changed!! The current name for the old company "VOLTAS IT" is now OBDeleven, UAB (company code: 303255404, address: Karaliaus Mindaugo pr. 38, Kaunas, 44307, Lithuania) The acronym UAB = Uždaroji Akcine Bendrove = the Lithuanian words for a private limited company (AFAIK) Also, whilst it's well known that there are lots of VCDS clones on the electric internet - I wasn't aware that the same problem existed for OBD11 devices!! Is this a thing with OBD11? My reason for asking is that until I read your post, I had assumed that the inherent design of OBD11 mitigates the risk of clones! I had thought that the quintessential deficiency with Ross-Tech products that makes them so vulnerable to clones is that VCDS software is irrecoverably cemented into a 70 year-old design technology - whereas OBD11 uses an entirely different design that at least in principle makes it very resistant to IP theft To explain, for Ross-Tech devices, the compete VCDS operating software plus the entire related database for every vehicle is available for free download from the home-site. Although not intentional - this naive set-up is an open invitation to opportunistic IP thieves to steal software!!! And given the brisk trade in VCDS clones, it's surprising that Ross-Tech still uses an out-of-date business model for its products! Yes, Ross-Tech tries to protect much of their IP, but clearly from the continuous stream of latest release clones - these attempts have limited success OBD11 on the other hand does stuff very differently and their design is much-more in tune with 21st century technology. For these devices, the only part of OBD11 software that is in the public-domain is the initiating App. The rest of the operating software is safely stored behind the firewall of OBD11's central servers. And more importantly for IP teft, the only part of OBD11's vehicle database that is released is the bit that's needed to service the user's request for the car's VIN - and this information is deleted after use! This set-up means that there is a great deal of data transfer between OBD11's central servers and the user tablet/mobile-phone (unlike VCDS) - but it does greatly assuage the risk of IP theft! But, maybe I'm wrong - and I always delight in learning stuff? Don Quote Link to comment Share on other sites More sharing options...
AHG Posted October 19, 2024 Report Share Posted October 19, 2024 Thank you for the info on Voltas becoming OBDeleven As per fakes, I haven’t experienced it myself so can’t say for sure, but on some Facebook groups I heard of people buying online from 3rd parties getting older versions that don’t support Apple products, or getting “lifetime” pro users that don’t work, or that are actually not pro or not lifetime, or just some 30-day trial or something. I don’t know if the device itself was fake, or just old, or if the subscriptions were fake … I’m just saying, it’s not that expensive so best to buy from the source, as shit did and does happen with 2nd hand or 3rd party purchases of OBD11. dv52 1 Quote Link to comment Share on other sites More sharing options...
