Obd 11
Ynot247
So ive had my golf R mk 7.5 for a month now and loving every minute of it so far.
I’ve been reading about Obd 11 and was wondering if it’s worth buying. I see some cool changes you can make using it and it will pick up any faults the car has (that’s my understanding on reading about it, correct me if I’m wrong).
Wondering if it’s easy to make the changes using it as I’m not to savvy with the codes and stuff I’m seeing that may need changed.
any help would be appreciated , thanks
Tony: Hi.
I'm always happy to see these questions from interested folk that have a yen to dip their fledgling feet into the murky waters of diagnostics (forgive the mixed metaphor).
As for your question "is it [OBD11] worth it"  - this is impossible to answer because I don't know how value stuff. Whether a purchase is worth what is paid is fundamentally about whether the buyer perceives a net return on funds paid - which is  a very personal perception.
I've been using OBD11 since it was first released and I also use VCDS and VCP. IMHO, all three a good tools - but the fact is the each diagnostic device has its good points and it's disadvantages (again, my personal view). However, OBD11 is now a mature tool and there have been millions sold -  this says something about  how the product has been assessed by others.
I guess the main distinguishing feature of OBD11 is  One Click Apps (OCAs) - these are particularly marketed to folk (like yourself) who are "not to[o] savvy with the codes and stuf[f]". OBD11 users must pay "credits" for OCAs - but they provide a quick (and sometimes risky) method for implementing tweaks. I say "sometimes risky" because occasionally OCAs don't work and the coding changes result in errors. When (not "if") this happens - unwinding the failed tweak is problematic because the coding changes are not disclosed!
So, before you use OCAs - understand the risk! IMO, it's like rolling dice: sometimes you win - but sometimes you lose (and the more OCAs you use, the greater the risk)! Much better to learn how to implement tweaks manually - again IMO!
Hi Tony
I started using obdeleven back in 2017, as a complete newcomer and novice to it, and have found it a very useful tool for making various adaptations and doing scans etc on various cars.
I prefer not to use the one-click apps because you cannot see what changes are being made and the potential for them not to work, particularly if you want to reverse an action.
My pref is to use the coding to achieve the ‘tweaks’ I want.  That way you know exactly what is being changed and how to reverse it should you want to or need to.  Plus it keeps a history of your actions which is invaluable imo.  For this you need a Pro subscription to obdeleven on top of purchasing the dongle.
There is a lot of coding information out there in places such as the obdeleven forum and car specific forums such as this one., where there’s both plenty of expert informed coding, and a wealth of tried and tested coding by end users.  The quality of this information can make it less scary to do tweaks so long as you trust the information you are following and take it step by step.   I would say that if you are not confident then you have the one-click apps, but if you decide to try coding tweaks, stick to the simple ones, but avoid complex coding changes, and do not be tempted to ‘wing’ it or experiment.  Things can go awry. If you are unsure about something then it’s probably best to listen to that inner feelings.
I have it, bought it primarily to wind back the EPB motors to change rear pads.
I haven’t coded anything, mainly because I’m not interested.
There’s an annual fee to pay if you want to code, which makes buying credits to do specific changes more cost efficient if you only want to do one or two things. You don’t need a subscription to scan and clear codes.
38 minutes ago, Ynot247 said:
 if I decide to buy one im sure I’ll be pestering use with more questions lol.
As Rebecca said: that's what we do - answer questions!!
if it picks up any faults on the car, can they be fixed using obd 11 or does it have to be done professionally?
Now that's another impossible question to answer - it's similar to the question "how long is a piece of string"?
At a helicopter view -car faults fall into 2 x broad categories: coding problems and hardware problems (or both).
In general, diagnostic devices are useful in extracting error codes that are generated by the car's internal monitoring system. In this respect, the error code only points-to the cause of the fault - it normally doesn't identify the actual faulty equipment! This means that the user usually has to undertake additional investigative stuff to find the offending component!
So, bottom line= OBD11 will ASSIST in your diagnostic endeavors - it ain't a panacea for all vehicle faults. Plus, often the error messages that OBD11 identifies are confusing and worse - occasionally  OBD11 tells outright porkies!!
As to whether you need the services of a professional - that really depends on the nature of the fault (once identified) and in your confidence and level of expertise (plus, also the equipment required to fix the problem)
My advice is ALWAYS  try DIY as a first attempt (so called "professionals" are normally overpriced and they rob you of the invaluable opportunity to learn)
So, bottom line= OBD11 will ASSIST in your diagnostic endeavors - it ain't a panacea for vehicle faults (and sometimes OBD11 tells porkies!!)
As to whether you need the services of a professional - that really depends on the nature of the fault (once identified) and in your confidence and level of expertise (an also the equipment required to fix the problem)
My advice is ALWAYS  try DIY as a first attempt ( so called "professionals" are normally overpriced and they rob you of the chance to learn)
Perfect thanks again for the very informative reply again. Really do appreciate it. Think I’ll look into getting one on their site
On 18/03/2025 at 20:52, Booth11 said:
Yes that one will allow you do coding as well as use the one click apps.
So if I get this one do I still need to buy credits for one click apps?
first thing I’d like to do is permanently deactivate the stop start, can this be done but coding or only through the one click apps?
Yes that package gives you both options.
Disabling Stop Start, through either one-click apps or coding, may not be possible as iirc, at some point VW removed the ability to do this on cars built after a certain time which affected some mk7.5s but I recall worked on some earlier 7.5 cars and mk7s. So a bit of an unknown for that particular adaptation.
Ok thanks. Do I dnt need to buy credits with that package?
If you get the Pro subscription version, you will have access both to purchasing credits (the in-app currency for using one-click apps) and I think you can still earn credits too, as well as access be able to carry out some coding adaptations (where they have not been restricted).  You don’t need credits for the latter.  I guess one option is to get the Pro version and then if find you don’t use the coding then just don’t renew at the end of the yearly subscription period.  Alternatively if you don’t think you’re going to want to do coding, just get the non Pro version. Whichever suits your needs best. 🙂
Perfect that makes sense now. Think I’ll get the pro version and see how it goes.
Let us know how you get on.
I’ve moved this thread to the obdeleven section now.
There’s lots of information and coding threads in this obdeleven section, so worth a browse, just be aware that as models get updated things can change with what works and what doesn’t on the various cars.
Also worth looking on the obdeleven forum at the mk7.5 (mk7 FL (facelift) section - here
https://forum.obdeleven.com/board/198/mk7-fl
