Carly issues
Artriel
Hi guys
I recently got a Carly OBD device to make some changes to my MK7.5 R Wolfsburg Wagon and im having a problem with it. I'm wondering if anyone was as stupid as me to get one and is having similar issues?
I can connect and read the codes but when i try to make modifications like turning off the start/stop function the change does not take and i get an error on the app saying to enquire with Carly via email.
Anyone come across this? At this point im considering just getting and ODBEleven and some credits to make the changes i want.
16 hours ago, AHG said:
Engine should not be running.
No ignition, just power on (electric).
Tried what you suggested and it sort of worked. When i scan for faults with the car in "tech mode" it came right down to only 5 from 23. I knew about these codes already so im not too concerned about them at this stage. Annoyingly i still cant make custom coding changes. I still get the same error. I also get an error screen saying my batteies voltage is too low ie below floating 12.5v. Its an AGM battery and i have tried charging it to get it back up but it doesnt seem to want to go back up. It just keeps sitting at 12.5 until i start the engine then it comes back up to 13.6v. From my research into AGM batteries they should sit at between 13.5 and 13.8 floating. I wonder if thats the cause of my problem? I'm the third owner and i wonder if the car was never coded for an AGM battery when the original EFB battery was replaced?
I would venture a guess that this is the culprit
seem to be in line with the battery fault it gives you
My battery sits a 11V when engine is off
and it does what I ask it to do
You can do that also with OBDeleven I think, unless it’s a chicken and egg thing where you can’t unless the battery is coded for. Then yiu’d need a power source (or try to code with engine on. May not work though).
@Artriel: Jeffery - Hi.
Hmm.........regardless of the battery manufacturing technology - a resting battery voltage of 12.5V and an operating voltage with alternator support of 13.6V ain't too shabby!! And it certainly shouldn't be the cause of your problem. That said, I'm not familiar with Carly - so I'm not sure where the device measures the car's battery rail voltage (it matters!!).
Anyhow, as for your observations - there are 2 x different tweak-methods for disabling Start Stop (SS) on MQB platform cars like this Golf mk7.5 as follows:
  1.  Temperature method
  2. Voltage method
Method 1 is generally applied to the earlier model Golf mk7 and the adaptation channels that need to be changed do NOT appear in the 09 module in vehicles that were built after about mid 2016.
So, exactly which instructions are you attempting to inflict on this car?
  2. Voltage method
Inside the Carly app there is 1 main enable and disable option and 2 alternate options to do the same. All 3 don't work and the app comes up with an error message saying the code wasn't applied. The GUI for the app doesn't show any serious details.
@Artriel
Jeffery: Again, I'm not familiar with Carly - but as a general approach to using diagnostic devices that have "automated" coding facilities - I DON'T!!  In my experience and regardless of the tool -the ease of "automated" coding is a ruse because it ALWAYS comes at a cost which is invariably undisclosed/unknown until the loose moist stools in the brown-stuff collide with the proverbial fan-blades (and then, it's too late)!!
My suggestion is that you activate the tweak as a manual coding exercise . Since this car is a mk7.5, the "Voltage method" is the appropriate tweak to disable SS.
The general tweak instructions for the Voltage method is as follows:
  1. Ignition-ON, Engine-OFF (open hood)
  2. Fire-up the diagnostic device software and connect to the dongle
  3. Navigate to Module 19 - which Carly probably calls something like "Can Gateway"
  4. Select the adaptation function
  5.  Go to the adaptation channel: Start_stop_voltage_limit
  6. Change value to 12.1V (factory default is 7.6V)
  7. Exit software and cycle ignition
Hey dv52.
Thanks so much for your advice. I tried everything I could within the Carly ecosystem and it just does not seem to have the access to the cars ECUs that we require. I've tried every menu option it has and I cannot get to a singular module. I think I've purchased a complete lemon of a product and should've done a lot more research. I don't know what else this OBD reader can do other than tell read codes. It will/cannot change any existing settings via the app as I can see. Im so sorry for wasting your time mate. You clearly have a vast knowledge of these VAG systems. I'm planning on getting VCDS OBD cable and the accompanying software to access the ECUs properly.
On 29/07/2025 at 10:01, Artriel said:
Absolute legend. Thanks lad. I'll try it during my lunch break and report back.
haha... most definitely not "legend" - "absolute", or otherwise and thanks for the "lad" descriptor (ain't been that since the last century)!!😉
20 hours ago, Artriel said:
Hey dv52.
Jeffery: To satisfy my own intellectual itch after reading your reply - I can confirm the Carly has 2 x pricing options: Basic Package and Premium Package. These pricing schemes are not unusual for diagnostic devices - but  I suspect that you can guess what the difference is between the two packages!!
Read HERE - note that the sentence "Get the Carly Universal Scanner with the free Basic Features" is entirely misleading and it's totally incorrect. There is nothing "free" about the Basic Features because you need to throw money at Carley for the Basic Package!!
I'm not sure if you can upgrade to the Premium Package after purchasing the Basic Package to be able to make manual coding changes (I suspect that you can because these options normally set a software switch against your account)  - maybe contact the seller?
PS: the alternative solution to deleting Start Stop via coding on MQB platform cars is to retrofit a physical Start Stop kill switch that automatically replicates the action of pressing the SS button on the center console after ignition switch-ON. These switches aren't difficult to install and there are lots of sellers on the electric internet. Check-out YouTube for videos of the install process
Hey mate. It appears you are right. My account i paid for doesnt seem to allow coding even though all the coding options are available in the app interface. I have just bought a generic OBD2 to USB cable from Amazon and am going to try VCDS. Looks like i might need the proper Ross Tech Hex Cable but i'll see if i can get the generic cable going.
