Rhys1786 Posted August 18, 2025 Report Share Posted August 18, 2025 Hi All I have a 23 plate Golf R MK8 with a stage 1 ECU tune. 20,000 miles on the clock (Tuned from around 5,000 miles) As of last week i have been getting the above error intermittently whenever i come to a stop at lights etc. A restart of the car clears the errors and away i go again. Seems to only happen if i have been driving for 30mins or so but doesn't happy everytime. With the tune i know this will flag up with VW if i take it in, will the tune void all warranty? Or could i potentially still have work done under warranty if this relates to a software glitch or something non performance related? Furthermore has anyone else had similar issues and potentially know what could be the issue? Quote Link to comment Share on other sites More sharing options...
AHG Posted August 18, 2025 Report Share Posted August 18, 2025 Does your tune turn off the Start Stop system ? I know some do (or enable to do so) Quote Link to comment Share on other sites More sharing options...
Rhys1786 Posted August 18, 2025 Author Report Share Posted August 18, 2025 6 minutes ago, AHG said: Does your tune turn off the Start Stop system ? I know some do (or enable to do so) I did have the start/stop disabled when i had the tune done yes. Though this has been like this for roughly 15,000 miles so assume it wasn't the tune that has kicked up the error. Quote Link to comment Share on other sites More sharing options...
blizzard60 Posted August 18, 2025 Report Share Posted August 18, 2025 Is the fault DRIVE system error or driver system error? Not trying to be nit-picky, but driver sounds like assistants, and could probably be covered. I have no idea why it would disable start/stop though. A true “drive system” error is going to be very hard to convince a dealer to warranty when you have a tune as it’s a fault in the drivetrain. Do you have an OBD11 or VCDS that could read the fault? Quote Link to comment Share on other sites More sharing options...
Rhys1786 Posted August 18, 2025 Author Report Share Posted August 18, 2025 10 minutes ago, blizzard60 said: Is the fault DRIVE system error or driver system error? Not trying to be nit-picky, but driver sounds like assistants, and could probably be covered. I have no idea why it would disable start/stop though. A true “drive system” error is going to be very hard to convince a dealer to warranty when you have a tune as it’s a fault in the drivetrain. Do you have an OBD11 or VCDS that could read the fault? hmmmm not entirely sure on that one to be honest, will check next time it kicks up the error. I have a local garage here that would do me a favor and read the codes for me, that was my next port of call so will revert back one i have the codes. Quote Link to comment Share on other sites More sharing options...
Rhys1786 Posted August 18, 2025 Author Report Share Posted August 18, 2025 Had the garage plug into the OBD, only engine error was engine coolant flow low/performance. Checked the actual level of coolant to make sure no leaks or anything and all seemed ok. Temps on the way home were like the attached, seem fairly normal? This was 30mins of driving. Potentially a faulty sensor or pump? Can't seem to post a photo but temps from top to bottom are 62 102 90 All in Celsius Quote Link to comment Share on other sites More sharing options...
AHG Posted August 18, 2025 Report Share Posted August 18, 2025 3 hours ago, Rhys1786 said: I did have the start/stop disabled when i had the tune done yes. Though this has been like this for roughly 15,000 miles so assume it wasn't the tune that has kicked up the error. Did you have any software updates since you tuned it ? My theory is that the tune “killed” the start/stop in a way that didn’t agitate in screen messages in the original software, but some updated version may notify you that your start/stop isn’t available. I would start with asking the user about this They may have an update version of their own to fit the updates in car software (had that in my mk6, APR updated my tune for free) Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 18, 2025 Report Share Posted August 18, 2025 @Rhys1786: Hi. Hmm...... some confusing information here!! First, there are lots of Start Stop errors that can appear on dash and that do not result in formal error codes on the vehicle diagnostic SCAN. SS is a very complex and deeply integrated facility that can be affected by a multitude of finicky things! However and accepting that the exact nature of the "Driver system error" has been poorly defined - it is far more likely that this warning message on the dash would be registered in the car's fault memory. The fact that this has not happened in this case is perhaps telling because it suggests (to me at least) that the car's self- monitoring process is perfectly happy for the "Driver system error" to be not recorded. Now, in the uncertain world of diagnostics, nothing can be ruled-out (especially given the ill-defined error)- but the dynamic above is symptomatic of a software cause - IMO, of course. It's not clear whether, the original tune is to blame, or if the cause is a combination of the tune and later OEM software updates (perhaps, over the air?), or if the tune is blameless! I'm not sure what normal practice is in the UK - but a good tuner will ALWAYS keep a copy of the original ECU software. Is it possible that you could restore this car back to factory software to check if these errors still appear? And if the errors do re-appear, leave the factory software intact while the dealer sorts-out the cause as a warranty matter (yes, dealers can still detect a previous tune - if they suspect so) Don Quote Link to comment Share on other sites More sharing options...
blizzard60 Posted August 19, 2025 Report Share Posted August 19, 2025 11 hours ago, Rhys1786 said: Had the garage plug into the OBD, only engine error was engine coolant flow low/performance. Checked the actual level of coolant to make sure no leaks or anything and all seemed ok. Temps on the way home were like the attached, seem fairly normal? This was 30mins of driving. Potentially a faulty sensor or pump? Can't seem to post a photo but temps from top to bottom are 62 102 90 All in Celsius P00B7? This is extremely common on MK7’s but not particularly common in MK8s, although not completely unheard of. That fault will absolutely present a “Drive System Error”, eventually. Normally with a CEL. Most likely cause is a thermostat. But could be water pump or simply a sensor being a brat. If you can’t test these you need someone to diagnose it. Here in Canada, you’d need an extremely friendly dealer to warrant this with a tune. Quote Link to comment Share on other sites More sharing options...
Rhys1786 Posted August 20, 2025 Author Report Share Posted August 20, 2025 On 19/08/2025 at 05:47, blizzard60 said: P00B7? This is extremely common on MK7’s but not particularly common in MK8s, although not completely unheard of. That fault will absolutely present a “Drive System Error”, eventually. Normally with a CEL. Most likely cause is a thermostat. But could be water pump or simply a sensor being a brat. If you can’t test these you need someone to diagnose it. Here in Canada, you’d need an extremely friendly dealer to warrant this with a tune. This is the error I'm receiving, showing as passive/sporadic on the readings. Booked in with VW now, guess I'll run the gauntlet and see if they mention the tune Quote Link to comment Share on other sites More sharing options...
blizzard60 Posted August 21, 2025 Report Share Posted August 21, 2025 6 hours ago, Rhys1786 said: This is the error I'm receiving, showing as passive/sporadic on the readings. Booked in with VW now, guess I'll run the gauntlet and see if they mention the tune Keep us posted! 🤞for you! Quote Link to comment Share on other sites More sharing options...
Cheche Posted November 17, 2025 Report Share Posted November 17, 2025 Hello, Any updates with this? I recently got a golf mk8 and I just had the Error: Start/Stop and the amber engine light flashing. I called the dealer and they said I need to book the car in, the only problem is they are full and can't have a look at it before 15th December. I reallyy need the car and I can't just leave it there for almost one month. Any suggestions? Thank you Quote Link to comment Share on other sites More sharing options...
Dollyman Posted November 17, 2025 Report Share Posted November 17, 2025 Any other Dealers within a reasonable distance you could try? Quote Link to comment Share on other sites More sharing options...
