OBDeleven
minesaturbo
Just got the new 3 device delivered must say quiet impressed with speed of delivery, especially given was delivered by Royal Mail ordered think last Wednesday night and was delivered this morning, (considering I posted a letter 2nd class other week and took 1 week to be delivered).
Never had one before but seems pretty intuitive and prob gives much more data than i'll every understand.
Only thing seems bit disappointing is the Haldex pump prime / learn seems to be a paid for app feature now so need some credits, only reason I bought it as im going to service Haldex oil. Suppose i'll just consider it part of the cost each time I might service the Haldex oil 🤷‍♂️
Can anybody else inform if there's anything else I could potentially use it for such as above for servicing stuff, ie. resetting or maybe key values / voltage readings / temps for stuff to indicate healthy running or something that might need attention
thanks
  • Replies 3
thanks
I’ve moved your post into the Obdeleven section.  Worth having a browse through this section to see what tweaks are available and what others have done. 🙂
@minesaturbo: Hi
Welcome to the wondrous world of OBD11 - I hope that you will enjoy the magic of its use!!
So, in regard to your specific question - it ain't really as it seems!! OBD11 offers 3 x different "Plans" that ALL use the same dongle (the bit that plugs into the car's OBD port). How the device is used (or, more precisely, the limitations of the device use) is entirely determined by which of these plans that you select  - and of course, which plan you pay-for.
If you buy the so-called "free" plan (note: the word "free" is deceiving - but lots of folk misuse this term) - you are correct that you will need to use One-Clip-Apps to service the Haldex system. In this case, OCAs will indeed need to be purchased separately.
If you opt for the PRO, or Ultimate plan, you can service the Haldex system via manual coding. But you will need to learn manual coding and you will need to throw money at the associated annual subscription fee. However, these two plans will enable you to do a lot more than just the Haldex service.
I suggest that you read THIS
  • 2 weeks later...
