VCDS Location Map
don16
Hi everyone,
Just a quick update to the VCDS location map, I'm based in the north west and offering vcds services such as
Fault code read/clear
Extended brake lights
Exhaust flap disable
DRL brightness & control screen
Headlight washer delay
Soundaktor volume adjustment
Alarm beep on lock/unlock & control screen
Start stop disable
Rear indicators in opposite sync
Disable seatbelt warning
Hi Jeff, whereabouts in the North West are you ? Would like some of your VCDS services
When suits you? & what are you interested in having done
Hi Jeff, weekends are good for me, if they are for you ?
Was looking at the DRL, Brake Light, Reversing Light tweaks, seat belt alarm off, and Fan speed when on Auto and any other good ones you might happen to suggest ??
