Start/Stop Error
Smiwii
I think the engine has to be at a certain temperature for start/stop to work so short journeys may not allow the system to kick in
Where did you get this from :))
No it works right away.
Mine had the same error come up when I changed driver mode from Normal to Eco. Stop/Start was already de-selected and it suddenly forcibly engaged itself and flashed up the error. Whenever I pressed the deselect button the error came up. Turned the engine off and the fault cleared. I've reported it to the dealer when the car went in to West London VW Service Dept, who failed to do anything about it, along with everything else the car has now been in twice for. Just thought I'd mention that. WLVW.
I've only had a stop / start error twice,  and it has worked OK again after turning the engine off & restarting.
However I've had it not "stop" the engine loads of times for various reasons.  If you go into the "Car Status" menu it tells you the reason why if you press the Stop Start Info icon.
So far I've seen something like these reasons for not activating
1.  Air conditioning requires power ..... (hot day, soon after setting off)
2.  Front Wheels are at too much of an angle  !  (when steering wheel not central)
3.  Climate Control temperature (when I had the heater on max heat)
I'm guessing there's a load more .... battery charge being the obvious one as stated above and probably engine temp.  Mine is a lot quicker to work now after setting off in the morning than when I got it back in the colder March.
Page 251 if your your manual... "Important preconditions for automatic engine switch off ..... ... A minimum engine temperature has been reached"
Kiss my face.
Your sign-off analogy seems (in)appropriate, if a little unnecessary.
Interesting...my engine must reach 'minimum temperature ie not an iceberg, within 30 seconds and/or 10yards then, as stop/start kicks in at the end of my drive ;)
Its an Alan Partridge comment, just a joke!
https://www.youtube.com/watch?v=bkcCBXZHfPw
Yeah dunno really, Ive only had my car a couple of days and have noticed the stop/start doesn't work immediately.
If your aircon is on, it won't work a lot of the time anyway. I've had my R(s) for 14 months so pretty used to them by now  :smiley:
