Traction issues
Aaron7r
Hi all. My car has problems. When I'm using laugh control or giving it some from 1st or 2nd gear it's lighting up the traction light or with traction off spinning the wheels, This is in dry conditions. I have brand new tyres so should not be a traction issue. I'm have plugged the car in and it's not showing a fault with haldex. This is now doing my head in as I can't find a fault. I still think my haldex unit has gone and it's not flagging a fault code? I would really appreciate some help on this. Regards Aaron
The code I have got is c111307 can't find the fault code is anywhere? I have only launched it a handful of times so I have not abused the car! I think it's the launch that has done it.
Maybe you could get away with a Haldex 'service' mate. I know it's not meant to be done for a while but that may possibly cure it
Sent from my SM-G935F using Tapatalk
You definitely have a Haldex issue somewhere there
Mine gets plenty of abuse and never has traction issues whatsoever even in the wet with traction turned off it just grips and goes
Have to be very naughty to see traction control light when traction turned on
Think mine is normal for a standard car unless mine is very underpowered?
Anyone else struggle to break traction in standard R?
Is yours standard power? Although for it to do what you describe with Haldex working as it should you would need to run serious power to light all 4 wheels up
Hi all. I have plugged the car in and have fault code C1113-07 it's a mechanical fault with the haldex. Car is going in hopefully under warranty
Did you check for faults on the ABS module?
C1113 is a generic OBD fault code related to ABS so I doubt VW assigned it to something else. Worth a look.
  • 1 year later...
