ashleyman Posted August 6, 2016 Report Share Posted August 6, 2016 I've spent the afternoon Googling and searching and reading but not getting anywhere. Probably using the wrong search terms. Basically, is there a way (without doing it manually) to restore any VCDS tweaks you've done to the car to factory? Thank you! Quote Link to comment Share on other sites More sharing options...
DUB R4XX Posted August 6, 2016 Report Share Posted August 6, 2016 I've spent the afternoon Googling and searching and reading but not getting anywhere. Probably using the wrong search terms. Basically, is there a way (without doing it manually) to restore any VCDS tweaks you've done to the car to factory? Thank you! In a word, No You need to reverse code all the changes you've made I'm afraid. They will all be in the debug txt file on the laptop you've used to do them along with dates and what the settings were before you changed them to what they are currently. Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 7, 2016 Report Share Posted August 7, 2016 I've spent the afternoon Googling and searching and reading but not getting anywhere. Probably using the wrong search terms. Basically, is there a way (without doing it manually) to restore any VCDS tweaks you've done to the car to factory? Thank you! Ashley : Hi As Steviekichface has suggested, there is no "automated way" of restoring the coding/adaptation channel settings to their original values (alas). So, the way to do this is to use the codinglog.txt file (and possibly also in the adplog.txt file) that lives in the Ross-Tech /VCDS/Debug subdirectory on the laptop that you used to make the changes. If you concurrently have both the Alpha and Beta versions of VCDS software installed, you may need to access two versions of the codinglog.txt/adplog.txt file (the Beta version is in the Ross-Tech/VCDS-Beta/Debug directory) depending on which VCDS version you used to make the change. Once you have located the file(s), use a text reader like notepad to open it. You will find a list of records of all of the changes that you asked the VCDS to make. Be aware though that not all of the information in this file is correct! An unfortunate aspect of the way that this file is constructed is that each record is made when you press the Doit!, or Save button in the VCDS software. This means that the record is blind to what happens after this point. So if your change request was rejected by the control module, the record will say that the change happened. But, even with this idiosyncrasy, the codinglog.txt file is a very handy facility. If you need further help with how to use the codinglog.txt file, I wrote a brief paper on the topic which you can download using the link below Don https://www.dropbox.com/s/g080pcj7h7wwwcp/CodingLog%20file.pdf?dl=0 gregozedobe, dazie00 and DUB R4XX 1 2 Quote Link to comment Share on other sites More sharing options...
DUB R4XX Posted August 7, 2016 Report Share Posted August 7, 2016 You really are the top of the class when it comes to VCDS stuff dv52. We would all be lost without you! A personal thank you from me for all the hard work and time you devote to helping people like me HamidS92 1 Quote Link to comment Share on other sites More sharing options...
Dielis Posted February 26, 2021 Report Share Posted February 26, 2021 Don, I would like to thank you very much for your excellent explanation on how to use the CodingLog.txt file to fix errors. I like it so much that I have translated it into Dutch. If you want to give permission for this I would like to post this on Dutch forums so that many more people are helped just like me. Of course the credits are for you and I also mention the source. Kind regards, Dielis Stolk Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 26, 2021 Report Share Posted February 26, 2021 @Dielis: Thanks for your very kind words and for the politeness of your request! Yes, of course you may use the material as you see fit ; everything that I write and post on the web is "open source" and made freely available to everyone who takes an interest. Sometimes, I've seen my stuff copied without attribution under someone else's name - not really an good way to behave, but then "plagiarism is the most sincere form of flattery". Not much I can do about this dishonesty - but I have more important things to worry about!! 😊 My post and my paper was written some time ago - since then, Ross Tech has developed RAW-HEX files which can be used to automatically return module coding to a previous state (which was the original subject matter for this thread). I've written about this feature on my local forum HERE, or you can find more data on Ross-Tech's on-line manual HERE. It's entirely your prerogative, but you might want to include some additional words about this new VCDS feature in your Dutch translation. If you do mention RAW-HEX in your document, I suggest that you emphasize that this feature can't be used if the VCDS user hasn't created a previous reference database. VCDS can't automatically restore a module to a previous state if it doesn't have access to a file containing the module's prior coding. Don Quote Link to comment Share on other sites More sharing options...
Dielis Posted March 8, 2021 Report Share Posted March 8, 2021 OK Don thanks for your tip, I will also explain the new option in my story. But I haven't done anything with it yet, because I just got back from a short vacation today. I hope to find time for it this week. Thanks and greetings, Dielis Quote Link to comment Share on other sites More sharing options...
