baz2011uk Posted November 12, 2016 Report Share Posted November 12, 2016 just been out to enable the inner brake lights on my 2015 R using OBDEleven but when i get into the Leuchtel27 NSL RC6 > Lichtfunktion C27 > here i am a little stuck as the guide i am looking at says "brake light on" then set in the list i have and there is a very long list in this section there is no English so would i be looking for Bremslicht auf as its all in German and there is no brake light on in English if someone could confirm or advise what i need to tick before i set this would be great Cheers Baz Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 12, 2016 Report Share Posted November 12, 2016 just been out to enable the inner brake lights on my 2015 R using OBDEleven but when i get into the Leuchtel27 NSL RC6 > Lichtfunktion C27 > here i am a little stuck as the guide i am looking at says "brake light on" then set in the list i have and there is a very long list in this section there is no English so would i be looking for Bremslicht auf as its all in German and there is no brake light on in English if someone could confirm or advise what i need to tick before i set this would be great Cheers Baz Baz: hmm.............. not entirely sure why your instructions direct you to the Leuchtel27 NSL RC6 "Leuchte-set" as this is the channel-set that controls the two "stand-back lights" (the inner-most LEDs in the taillight fittings). There are lots of ways of extending the functionality of the two inner taillights, but perhaps the simplest tweak is as follows (using OBD11 dongle): After you connect to the dongle, select Central Electrics control module (it has 09 in the yellow circle) Scroll down the screen and select Security access Enter the magic number 31347 Select Adaptation from the main screen Enter "HRA65" into the search line and select Leuchte24SL HRA65 (this is the "Leuchte-set" for the right-side parking light inner tail) From the list displayed, select Lichtfunktion B 24. The default setting for this adaptation channel should be not active Only if the setting is not active, change the value to Bremslicht (Brake light) and press ok. Press the green tick tag to accept the change Go back to the main screen that shows the list of Adaptation channels Enter "HLC10" into the search line and select Leuchte23SL HLC10 (this is the "Leuchte-set" for the left-side parking light inner tail) From the list displayed, select Lichtfunktion B 23 . The default setting for this adaptation channel should be not active Only if the setting is not active, change the value to Bremslicht (Brake light) and press ok. Press the green tick tag to accept the change Exit the OBD11 software Don Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted November 13, 2016 Author Report Share Posted November 13, 2016 Baz: hmm.............. not entirely sure why your instructions direct you to the Leuchtel27 NSL RC6 "Leuchte-set" as this is the channel-set that controls the two "stand-back lights" (the inner-most LEDs in the taillight fittings). There are lots of ways of extending the functionality of the two inner taillights, but perhaps the simplest tweak is as follows (using OBD11 dongle): After you connect to the dongle, select Central Electrics control module (it has 09 in the yellow circle) Scroll down the screen and select Security access Enter the magic number 31347 Select Adaptation from the main screen Enter "HRA65" into the search line and select Leuchte24SL HRA65 (this is the "Leuchte-set" for the right-side parking light inner tail) From the list displayed, select Lichtfunktion B 24. The default setting for this adaptation channel should be not active Only if the setting is not active, change the value to Bremslicht (Brake light) and press ok. Press the green tick tag to accept the change Go back to the main screen that shows the list of Adaptation channels Enter "HLC10" into the search line and select Leuchte23SL HLC10 (this is the "Leuchte-set" for the left-side parking light inner tail) From the list displayed, select Lichtfunktion B 23 . The default setting for this adaptation channel should be not active Only if the setting is not active, change the value to Bremslicht (Brake light) and press ok. Press the green tick tag to accept the change Exit the OBD11 software Don Hi Don Thanks for the instructions you have provided i will give them a try tomorrow and let you know how i got on the guide i followed was from http://www.vwroc.com/forums/topic/8555-extend-rear-brake-lights-to-use-inner-boot-leds-mk7/ on this guide it mentions about increasing the power from 0 to 100 would i need to also do this after following your instructions? cheers Baz Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 13, 2016 Report Share Posted November 13, 2016 Hi Don Thanks for the instructions you have provided i will give them a try tomorrow and let you know how i got on the guide i followed was from http://www.vwroc.com/forums/topic/8555-extend-rear-brake-lights-to-use-inner-boot-leds-mk7/ on this guide it mentions about increasing the power from 0 to 100 would i need to also do this after following your instructions? cheers Baz Baz: New requirement - wasn't aware that you also wanted to have the brake lights operate at 100%! My instructions above use the illumination level of the existing Parking lights (which is 28%). You could alter the value in the Dimmwert AB channel to 100% for both Leuchte24SL HRA65 and Leuchte23SL HLC10 , but this will also increase the parking light illumination to 100% But to do the tweak properly (i.e. both components - brake plus 100% illumination), the following changes are needed. Don Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted November 13, 2016 Author Report Share Posted November 13, 2016 thanks for clearing that up Don Quote Link to comment Share on other sites More sharing options...
jonnyfR Posted December 24, 2016 Report Share Posted December 24, 2016 After reading the first thread the guy linked, and then seeing this ive just spent an hour confused as to the setting you suggested were existing and then to be changed for this to work. Nothing changed anything .... I then went back to the previously linked thread and changed Enabling the Extended brake lights on the Mk7 LED units Two part, 1, enable the lights 09 (Central Electronics) Security Access - 31347 Adaptation Channels (8) - Leuchte27 NSL RC6 -Lichtfunktion C27" > "Brake light on", Set 2, turn up the power from 0 to 100% (10) - Leuchte27 NSL RC6 - Dimming CD27" > "100", Set crude video here http://vid1333.photo...zpsyrdppk0g.mp4 As suggested And it worked... This seems very confusing i dont know if it then works differently for different cars? Quote Link to comment Share on other sites More sharing options...
Stobsie Posted December 24, 2016 Report Share Posted December 24, 2016 After reading the first thread the guy linked, and then seeing this ive just spent an hour confused as to the setting you suggested were existing and then to be changed for this to work. Nothing changed anything .... I then went back to the previously linked thread and changed Enabling the Extended brake lights on the Mk7 LED units Two part, 1, enable the lights 09 (Central Electronics) Security Access - 31347 Adaptation Channels (8) - Leuchte27 NSL RC6 -Lichtfunktion C27" > "Brake light on", Set 2, turn up the power from 0 to 100% (10) - Leuchte27 NSL RC6 - Dimming CD27" > "100", Set crude video here http://vid1333.photo...zpsyrdppk0g.mp4 As suggested And it worked... This seems very confusing i dont know if it then works differently for different cars? The coding you have quoted is for VCDS and OP was asking for OBDeleven ? Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted December 24, 2016 Author Report Share Posted December 24, 2016 After reading the first thread the guy linked, and then seeing this ive just spent an hour confused as to the setting you suggested were existing and then to be changed for this to work. Nothing changed anything .... I then went back to the previously linked thread and changed Enabling the Extended brake lights on the Mk7 LED units Two part, 1, enable the lights 09 (Central Electronics) Security Access - 31347 Adaptation Channels (8) - Leuchte27 NSL RC6 -Lichtfunktion C27" > "Brake light on", Set 2, turn up the power from 0 to 100% (10) - Leuchte27 NSL RC6 - Dimming CD27" > "100", Set crude video here http://vid1333.photo...zpsyrdppk0g.mp4 As suggested And it worked... This seems very confusing i dont know if it then works differently for different cars? if your using OBDEleven follow this thats how i did it but asked questions as didnt want to screw it up with there being a lot of options in there Module 09 (Central Electrics) Security Access 16 Code = 31347 Adaptation 10 Channel (8)-Leuchte27 NSL RC6 Lichtfunktion C27 Set to brake light = Bremslicht (default is not active) Channel (10)-Leuchte27 NSL RC6 Dimming CD27 Set to 100 (default is 0) Quote Link to comment Share on other sites More sharing options...
Donny Posted August 10, 2020 Report Share Posted August 10, 2020 On 13/11/2016 at 02:18, dv52 said: On 13/11/2016 at 00:06, baz2011uk said: Hi Don Thanks for the instructions you have provided i will give them a try tomorrow and let you know how i got on the guide i followed was from http://www.vwroc.com/forums/topic/8555-extend-rear-brake-lights-to-use-inner-boot-leds-mk7/ on this guide it mentions about increasing the power from 0 to 100 would i need to also do this after following your instructions? cheers Baz Baz: New requirement - wasn't aware that you also wanted to have the brake lights operate at 100%! My instructions above use the illumination level of the existing Parking lights (which is 28%). You could alter the value in the Dimmwert AB channel to 100% for both Leuchte24SL HRA65 and Leuchte23SL HLC10 , but this will also increase the parking light illumination to 100% But to do the tweak properly (i.e. both components - brake plus 100% illumination), the following changes are needed. Don Hi, I have bought my son a 2013 mk7 tdi and am looking to enable the rear inner lights as brake lights as well. I haven't got the OBDEleven pro version as I have been using apps so far so no coding for me but on the app list for my son's car there is one for Four (Five) Brake Lights. Will this do the same as the instructions you have posted above? The app says use only with bulb lights which the car has but it also says US models only whereas I am in the UK. Will the app work or will I have to code it and if so can I use your instructions above, even though mine has bulbs instead of LEDs? I am also interested in applying the DV52 tails app to work in conjunction with this and want to know if they will both work at the same time. Thanks Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 12, 2020 Report Share Posted August 12, 2020 ^ ^^ ^Donny: Hi. My 4 x brake light tweak suggestion above should result in this effect: whereas DV52 tails App should result in these effects: So, bottom line - yes the 4 x brake light function has been integrated into the DV52 tweak . But I'm not sure how the OBD11 App operates and I never use APPs - because APPs leave no records in the OBD11 History facility regarding what changes they made. This means that if the loose stools and the fan blades collide after implementing the APP and the reversal process doesn't work (it does happen), reverting the changes to their original values is problematic. I guess If you must use an APP because you don't have the PRO version of OBD11 -then my suggestion would be to just implement DV52 tails. This means that you get the 4 x brake light tweak included for free and you avoid entirely the question about US versus UK fittings (because I designed the DV52 tails tweak for our Rest-of-World cars in Australia) . So, it's a clear case of win-win where you get to keep both the wins !!! 😘 Don Quote Link to comment Share on other sites More sharing options...
Donny Posted August 13, 2020 Report Share Posted August 13, 2020 On 12/08/2020 at 01:38, dv52 said: ^ ^^ ^Donny: Hi. My 4 x brake light tweak suggestion above should result in this effect: whereas DV52 tails App should result in these effects: So, bottom line - yes the 4 x brake light function has been integrated into the DV52 tweak . But I'm not sure how the OBD11 App operates and I never use APPs - because APPs leave no records in the OBD11 History facility regarding what changes they made. This means that if the loose stools and the fan blades collide after implementing the APP and the reversal process doesn't work (it does happen), reverting the changes to their original values is problematic. I guess If you must use an APP because you don't have the PRO version of OBD11 -then my suggestion would be to just implement DV52 tails. This means that you get the 4 x brake light tweak included for free and you avoid entirely the question about US versus UK fittings (because I designed the DV52 tails tweak for our Rest-of-World cars in Australia) . So, it's a clear case of win-win where you get to keep both the wins !!! 😘 Don Hi Don, Thanks for your informative response. If I were to use the DV52 tails will the inner tail lights illuminate at 28% (the existing level for parking lights)? I would like them to be at 100% just like Baz had wanted earlier in the thread. I am thinking about getting the PRO version because I'm becoming interested in the coding so after applying the DV52 tails app would I need to go into Adaptations and make the changes you listed in the yellow table earlier in the thread? Thanks Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 14, 2020 Report Share Posted August 14, 2020 ^ ^^Donny: hmm.........Of course you are free to do whatever you want -but I would caution against increasing the Parking Lights (PL) to 100 % (i.e. the same as the brake lights). Put yourself in the position of the car driving behind you during night time when the PL is switched-on. With your changes - the car at the rear sees the illumination level @100% - you suddenly step on the Brakes to avoid an imminent collision - but the car at the rear see no change in the lamp illumination because it's the same as the Brake light. Yes, you can argue that the car at the rear will see other lights change (the high-level 3rd brake light - for example) - but I reckon that it's just not safe with this arrangement. And, I suspect that your car won't be road legal with your changes - I don't know your road laws for car lighting, but I suspect that your current 28% setting is enshrined somewhere in your regulations. Even if I'm correct -of course you can take the risk that contravening the road rules will never be a problem - but if ever the car is involved in a serious accident, the prosecutor for the other party will have a strong case for negligence (IMO of course - I'm not a legal person). Anyhow - you are free to do whatever you want (as I said, it's entirely your decision). I make no moral judgements in these forums , and most definitely, my role isn't to be the ethical/legal conscience of those who implement my tweaks. Don Quote Link to comment Share on other sites More sharing options...
Donny Posted August 14, 2020 Report Share Posted August 14, 2020 2 minutes ago, dv52 said: ^ ^^Donny: hmm.........Of course you are free to do whatever you want -but I would caution against increasing the Parking Lights (PL) to 100 % (i.e. the same as the brake lights. Put yourself in the position of the car driving behind you during night time when the PL is switched-on. With your changes - the car at the rear sees the illumination level @100% - you suddenly step on the Brakes to avoid an imminent collision - but the car at the rear see no change in the lamp illumination because it's the same as the Brake light. Yes, you can argue that the car at the rear will see other lights change (the high-level 3rd brake light - for example) - but I reckon that it's just not safe with this arrangement. And, I suspect that your car won't be road legal with your changes - I don't know your road laws for car lighting, but I suspect that your current 28% setting is enshrined somewhere in your regulations. Even if I'm correct -of course you can take the risk that contravening the road rules will never be a problem - but if ever the car is involved in a serious accident, the prosecutor for the other party will have a strong case for negligence (IMO of course - I'm not a legal person). Anyhow - you are free to do whatever you want (as I said, it's entirely your decision). I make no moral judgements in these forums , and most definitely, my role isn't to be the ethical conscience of those who implement my tweaks. Don Hi Don, Let me rephrase as you may have misunderstood me. I will be looking for the inner lights to retain the brightness of the parking lights during normal driving however during braking I would like them at the same brightness as the outer brake lights which I assume change from 28 to 100%. Is this possible? Thanks Quote Link to comment Share on other sites More sharing options...
Donny Posted August 14, 2020 Report Share Posted August 14, 2020 6 minutes ago, dv52 said: ^ ^^Donny: hmm.........Of course you are free to do whatever you want -but I would caution against increasing the Parking Lights (PL) to 100 % (i.e. the same as the brake lights. Put yourself in the position of the car driving behind you during night time when the PL is switched-on. With your changes - the car at the rear sees the illumination level @100% - you suddenly step on the Brakes to avoid an imminent collision - but the car at the rear see no change in the lamp illumination because it's the same as the Brake light. Yes, you can argue that the car at the rear will see other lights change (the high-level 3rd brake light - for example) - but I reckon that it's just not safe with this arrangement. And, I suspect that your car won't be road legal with your changes - I don't know your road laws for car lighting, but I suspect that your current 28% setting is enshrined somewhere in your regulations. Even if I'm correct -of course you can take the risk that contravening the road rules will never be a problem - but if ever the car is involved in a serious accident, the prosecutor for the other party will have a strong case for negligence (IMO of course - I'm not a legal person). Anyhow - you are free to do whatever you want (as I said, it's entirely your decision). I make no moral judgements in these forums , and most definitely, my role isn't to be the ethical conscience of those who implement my tweaks. Don Actually I have just realised my mistake. I assumed the inner brake lights would only shine to a brightness of 28% while braking but now I realise that by turning them into brake lights the 100% brightness while braking will happen and the normal driving lights will be 28%. Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 14, 2020 Report Share Posted August 14, 2020 ^^^Donny: with DV52 tails, the inner lights will illuminate to 28% when the PL is switch-on and this illumination level will change to 100% when the brakes are applied. So the tweak already does this! Don Quote Link to comment Share on other sites More sharing options...
