Lawrie Posted January 18, 2017 Author Report Share Posted January 18, 2017 I'm guessing you would press the button without your foot on the brake/clutch? Sent from my iPhone using Tapatalk Pro Bnkrs1789 1 Quote Link to comment Share on other sites More sharing options...
TomGolfRmk7 Posted January 18, 2017 Report Share Posted January 18, 2017 Think mines just arrived in the office. Great post Lawrie, thank you, on the back of that am waiting for my android tablet to arrive otherwise I would have been a bit disappointed when the Dongle arrived and I wouldn't have been to use it! Lawrie 1 Quote Link to comment Share on other sites More sharing options...
Brentendo Posted January 18, 2017 Report Share Posted January 18, 2017 I'm guessing you would press the button without your foot on the brake/clutch? Sent from my iPhone using Tapatalk Pro This worked. Cheers 😊 Lawrie 1 Quote Link to comment Share on other sites More sharing options...
montecarlo Posted January 20, 2017 Report Share Posted January 20, 2017 Exhaust Flaps To keep the exhaust flaps permanently open (Golf R hatch only) and have all four working regardless of mode (or engine restart) you must disable the functionality. To do this there is an important start up procedure - otherwise you will code them permanently closed. To prepare I... 1) started the engine and selected race mode (if gearbox is DSG - select 'sport') 2) turned off the engine 3) turned the ignition back on (didn't start the engine) 4) performed the mod below. After pressing the coding button (bottom right of the scan button in the image above) you need to select: Engine Control Module > Coding > (make sure the 'long coding' toggle-switch top right is switched on) then select: Byte 9 (from the options at the top where you can type in byte numbers) > Untick bit 2. Then click the tick to save changes. Lawrie, Thanks for a great summary and tips! I've used the exhaust flaps mod successfully and loved it. However, it becomes drony especially on long highway trips and low to moderate engine speeds, and wanted to put it back to original settings. So, I thought that I would just tick the Byte 9 / bit 2 back on, and all would be back to normal. Apparently not so. I tried the above start up procedure, that didn't work. So I thought I would try the above start up, but this time in Normal mode (and DSG in Drive), that didn't work either. Is there something I am missing? Or is there a totally different trick to put the exhaust flaps back into normal operation? Any help greatly appreciated. Mine is a MY2015 R, by the way. Quote Link to comment Share on other sites More sharing options...
Lawrie Posted January 20, 2017 Author Report Share Posted January 20, 2017 Lawrie, Thanks for a great summary and tips! I've used the exhaust flaps mod successfully and loved it. However, it becomes drony especially on long highway trips and low to moderate engine speeds, and wanted to put it back to original settings. So, I thought that I would just tick the Byte 9 / bit 2 back on, and all would be back to normal. Apparently not so. I tried the above start up procedure, that didn't work. So I thought I would try the above start up, but this time in Normal mode (and DSG in Drive), that didn't work either. Is there something I am missing? Or is there a totally different trick to put the exhaust flaps back into normal operation? Any help greatly appreciated. Mine is a MY2015 R, by the way. Hey. Did you try this as posted above?... My R goes back to VW tomorrow and Select Car leasing deliver me a shiny new one. I therefore decided to put the indicators and exhaust flaps back to standard. I did the reverse of the instructions above and the indicators reverted back immediately. The flaps took longer though. The OBD Eleven accepted the coding but it didn't reactivate the flaps immediately. It only did so after I had left the car locked for 10 minutes and returned to it and started the engine. After speaking with @Ninja_Geezer it seems his R did the same when reverting, so don't be alarmed if they don't start functioning right away when/if you put them back to stock. Sent from my iPhone using Tapatalk Pro montecarlo 1 Quote Link to comment Share on other sites More sharing options...
montecarlo Posted January 20, 2017 Report Share Posted January 20, 2017 Hey. Did you try this as posted above?... Sent from my iPhone using Tapatalk Pro I now remember reading this earlier... So I went outside to my car, started it, and voila... Everything back to normal... Thanks a lot! :afro: Lawrie 1 Quote Link to comment Share on other sites More sharing options...
montecarlo Posted January 20, 2017 Report Share Posted January 20, 2017 Lawrie, I had posted about this in a seperate topic without success, but wanted to ask you and others following this topic: I have a non-cruise control car, and I have bought a steering wheel button set that including cruise control buttons. Part number is 5G0.959.442.M if that's helpful at all. It seems I cannot attach images yet as a newbie. My question is, would you or anybody else in the forums know what to change in the coding to make the system know that I now have necessary buttons to control it, and turn on the cruise control (speed limiter, etc.); without ACC of course. Cheers. Quote Link to comment Share on other sites More sharing options...
Lawrie Posted January 20, 2017 Author Report Share Posted January 20, 2017 Lawrie, I had posted about this in a seperate topic without success, but wanted to ask you and others following this topic: I have a non-cruise control car, and I have bought a steering wheel button set that including cruise control buttons. Part number is 5G0.959.442.M if that's helpful at all. It seems I cannot attach images yet as a newbie. My question is, would you or anybody else in the forums know what to change in the coding to make the system know that I now have necessary buttons to control it, and turn on the cruise control (speed limiter, etc.); without ACC of course. Cheers. I personally have no idea I'm afraid. I am far from an expert in VAG coding, I just put together a guide for people new to OBD Eleven wanting to do the most common tweaks. As all GolfRs (in the U.K. at least) have cruise, I'd suggest asking on Golfmk7.com or similar... montecarlo 1 Quote Link to comment Share on other sites More sharing options...
montecarlo Posted January 20, 2017 Report Share Posted January 20, 2017 I personally have no idea I'm afraid. I am far from an expert in VAG coding, I just put together a guide for people new to OBD Eleven wanting to do the most common tweaks. As all GolfRs (in the U.K. at least) have cruise, I'd suggest asking on Golfmk7.com or similar... I'll do that. Thanks Cheers Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 23, 2017 Report Share Posted January 23, 2017 Thanks to Lawrie for a great thread. Just ordered OBDeleven Pro. Often thought about getting VCDS, but overkill for my needs, but OBD looks just the job for the few bits I want to do. Will no doubt have a few questions later down the line. Now need to source a very cheap Android tablet as iOS only household, suggestions gladly received. ninja_geezer and Lawrie 2 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 23, 2017 Report Share Posted January 23, 2017 Thanks to Lawrie for a great thread. Just ordered OBDeleven Pro. Often thought about getting VCDS, but overkill for my needs, but OBD looks just the job for the few bits I want to do. Will no doubt have a few questions later down the line. Now need to source a very cheap Android tablet as iOS only household, suggestions gladly received. Great purchase ,i would look for a second hand samsung tab or a new google nexus 7 both great tablets ,depends if you can get wifi from your driveway parking postition rebecca ,if not then you would need something with 3g/4g capability, Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 23, 2017 Report Share Posted January 23, 2017 Great purchase ,i would look for a second hand samsung tab or a new google nexus 7 both great tablets ,depends if you can get wifi from your driveway parking postition rebecca ,if not then you would need something with 3g/4g capability, Thanks Paul. Depends just how close I can get my car to the house, lol. I'll check in the morning but pretty sure home wifi extends to my spot on the driveway. Prefer to buy new, but cheap as it'll only see the light of day for OBD11 purposes. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 23, 2017 Report Share Posted January 23, 2017 Thanks Paul. Depends just how close I can get my car to the house, lol. I'll check in the morning but pretty sure home wifi extends to my spot on the driveway. Prefer to buy new, but cheap as it'll only see the light of day for OBD11 purposes. Sent from my iPad using Tapatalk Something like this would do just fine ,cheap and cheerful . http://www.argos.co.uk/product/5058882 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 23, 2017 Report Share Posted January 23, 2017 Something like this would do just fine ,cheap and cheerful . http://www.argos.co.uk/product/5058882 That looks a good shout, could be the one if no 3/4G needed, cheers. Also wondered about Amazon Fire, but read conflicting stuff about that (it not being Android as such) be compatible. Sent from my iPad using Tapatalk ninja_geezer 1 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 23, 2017 Report Share Posted January 23, 2017 That looks a good shout, could be the one if no 3/4G needed, cheers. Also wondered about Amazon Fire, but read conflicting stuff about that (it not being Android as such) be compatible. Sent from my iPad using Tapatalk Yes would avoid the amazon fire as it runs a not standard android software .i just use my samsung 3 year old note 3 works a treat. Booth11 1 Quote Link to comment Share on other sites More sharing options...
