OBD Eleven - The Basics
Lawrie
Thanks Paul. Depends just how close I can get my car to the house, lol. I'll check in the morning but pretty sure home wifi extends to my spot on the driveway.
I'm not sure how the ODBEleven dongle works or what the quality is like but sometimes on cheaper devices with low quality wi-fi chips you need a stronger signal than something like an iPhone would do ok with.
Prime example is I can get wi-fi from inside my car whilst parked on the street outside my flat with my MacBook Pro and it's strong enough to surf the net albeit slowly. With my Windows laptop it won't pick up the wi-fi network at all unless you're outside the car and on the pavement.
If you find it doesn't work when the dongle arrives, you can get 'Powerline Adapters' which are about £30 a set and that'll be perfect for boosting your network out onto your driveway.
i cannot get my wifi from my driveway so i use 4g and it works just great ,i dont think you need superfast broadband for the OBDeleven to work properly.
Got superfast broadband, just wondered about signal strength. Will see in the morning. If not a 4G it will be.
If wifi signal transpires to be too weak on cheap android tablet, then it can be returned and will buy something else/4G capable.
Just remembered, have actually got a booster in our 'garden room' so can commandeer that if needs be.
You'd then need to buy and pay for a sim and some sim data every time you want to use the tablet.
Sure it won't be a problem for you but thought it might be good to have a relatively cheap fix in place just in case you found the the signal to be poor. Oh well.
Glad the guide was useful Rebecca.
I bought one of these but they were only £45 at Xmas time:
http://www.argos.co.uk/product/5538120
My fibre wifi reaches my car on the drive but I find it works slightly better using my iPhone as a personal hotspot and connecting over 4G.
Just make sure whatever you buy has Bluetooth and android 4.1 or later.
Good suggestion.
Edited my previous post as remembered we have a booster in one of our back rooms where the wifi struggles - if you sit on right hand couch it's fine, move 5 feet to left and iffy signal, but fine with booster, so can try that if necessary. But worse case scenario is SIM card.
Thanks Lawrie, that another really good suggestion. I use my iPhone regularly as a hotspot for my iPad when out and about, so that could be a great workaround. Luckily got a huge data plan on my contract too, not in any way related to forum dwelling ;-) lol.
The guide is great, as are all the helpful contributions from yourself, Paul and others, I've been on the fence about OBDeleven for a while but this thread tipped the balance, thanks for taking the time and effort to post the guide.
Something like this would do just fine ,cheap and cheerful .
http://www.argos.co.uk/product/5058882
Just ordered this one. Cheers Paul. Runs Android 5.0 so should be ok.
Wifi signal on driveway is fine, full strength (better than some rooms in the house, lol), but if any issues with signal on cheapo tablet I'll just follow Lawrie's suggestion and use my iPhone as a hotspot.
Got a few things want to do for starters (if all doable with OBD11)  - full brake lights, disable Stop/Start; headlight washer disable; enable chirp on lock/unlock; DRL brightness, that's it but sure there'll be more ;-)   At some point might do the 4 flaps just to try, see what it's like in terms of droning.
Checked the spec of the tablet and it meets the requirements just fine,dont expect it to be fast though but if you are only using it for the OBDeleven you wont worry. :wink: just make sure you set up a google account when you set the tablet up for the play store if you already have not got one.
all the mods you have listed i have already done with the OBDeleven also done some on my brothers car and my cousins .of the ones listed i used an app for headlight washer disable (10 credits ) other than that i think ive done 10 other mods using the long coding.oh not sure if Lawrie mentioned it but it keeps a full history of your changes so it makes it easy to change back,you can email it to you computer and even print it off for safe keeping.
