Winter pack
JORD7R
I was working on the basis that if every UK 7R which has leather has heated elements 95% sure these will fingers crossed.
Will contact Hazzydayz Monday and find out what plug I should be looking for under the seat.
True, unless they had the leather fitted by an upholsterer rather than leather seats from another 7R.
If they have heated seats you might be able to to see the harness hanging underneath.
Kufatec supply the wiring harness for it  https://www.kufatec.de/shop/en/volkswagen/golf/golf-7-5q/harness-seat-heating-golf-71?action_ms=1
Yeah thanks, that's what i'm thinking. I'm going to take some pics from under the seat tomorrow to see if it looks obvious. I'm guessing it's a complete climate fascia replacement rather than two buttons that clip in for the heated seat control where I currently have blanks?
I know it can't be that simple!! :-D
are the standard 7r cloth seats all fitted with the heating elements? i.e could they be retro enabled with a just new control panel and vagcom.
When I had my Mk6 I contacted Kufatec to enquire about the parts for retrofitting to heated seats they were under the impression a lot of the VW's came with the element already in the seat. I never got any further though.
  • 3 weeks later...
Is there a way to check if the heated element is in the seat or not?
Yes! I don't have much hope though as everything I've tried to fit so far hasn't been possible!  :grin:
I would say no.
The pads were only in my seats because apparently on the leather seats it's standard from the factory whereas on cloth it was option only (winter pack) so unless the really unlikely has happened and a previous owner swopped out your cars factory cloth seats for another set of cloth seats that were from a winter pack spec car I would say you're being very optomistic pal.
Have a look under the seats that's what I did and I spotted a loose plug that was for the heated elements. If you have a loose/spare plug under there then happy days!!
