EdotP Posted January 14, 2017 Report Share Posted January 14, 2017 I really want to turn this down or off. I can't do this via individual mode as I have an older R. Does anyone know if I were to unplug, or get it turned off via vcds, whether this would void warranty? Ta Quote Link to comment Share on other sites More sharing options...
dexter Posted January 14, 2017 Report Share Posted January 14, 2017 Certainly won`t void warranty if you just turn it down mate. My R, which was pre-owned by VW had had the Soundaktor turned down completely when I bought it. I wanted it turned back up, so nipped into my local VW dealer who did it for no more than £15 IIRC..., so if they`re turning it down themselves, then no, it won`t affect warranty. Hope this helps Quote Link to comment Share on other sites More sharing options...
Zayvin Posted January 15, 2017 Report Share Posted January 15, 2017 Or find someone local to you with VCDS who will probably do it for beer tokens! Quote Link to comment Share on other sites More sharing options...
TomGolfRmk7 Posted January 15, 2017 Report Share Posted January 15, 2017 I was looking at this recently and came across this video which may be of interest just for background. This chap is turning it off but shows how quick it is if you have a mate or local garage with VCDS: el_zorro 1 Quote Link to comment Share on other sites More sharing options...
gfarmer Posted January 15, 2017 Report Share Posted January 15, 2017 I got Vw to turn mine off before I picked up the car like said find someone with vcds cause Vw with charge u something stupid for doing it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
EdotP Posted January 15, 2017 Author Report Share Posted January 15, 2017 I was looking at this recently and came across this video which may be of interest just for background. This chap is turning it off but shows how quick it is if you have a mate or local garage with VCDS: Yes I've seen this -thank you. As much as I want noise, I want it to be real. Any idea what VW would charge? And does anyone know of someone who has vcds in West Sussex? Sent from my iPhone using Tapatalk Cogito 1 Quote Link to comment Share on other sites More sharing options...
TomGolfRmk7 Posted January 15, 2017 Report Share Posted January 15, 2017 You're not alone. The artificial noise can feel a bit superficial. I don't know how much VW would charge for it but if you're car was going in for something anyway I'm sure they'd be interested in keeping your business and may do it for a nominal cost. I'm afraid I don't know of anyone in W Sussex but someone else in the forums might so I'll keep an eye out. Cheers. EdotP 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted January 16, 2017 Report Share Posted January 16, 2017 Yes I've seen this -thank you. As much as I want noise, I want it to be real. Any idea what VW would charge? And does anyone know of someone who has vcds in West Sussex? Sent from my iPhone using Tapatalk Emma: It's interesting how the Soundaktor divides mk7 owners into those who like the noise and those who hate it - clearly you fit into the latter category. Anyhow, going the VCDS/OBD11 route is much easier when disabling/deadening the Soundaktor, but with not too much difficulty, it can be done manually by simply disconnecting the supply wires. Something that you may want to consider as an alternative to using a dealer - and you will learn a lot too! Plus it's a task that's particularly suited to your gender because having small hands is a decided advantage when working inside the plenum chamber cavity! Worth considering - I suggest. If you have an interest, here's a video where the producer claims that it's a 10minute job! Don Quote Link to comment Share on other sites More sharing options...
EdotP Posted January 16, 2017 Author Report Share Posted January 16, 2017 Emma: It's interesting how the Soundaktor divides mk7 owners into those who like the noise and those who hate it - clearly you fit into the latter category. Anyhow, going the VCDS/OBD11 route is much easier when disabling/deadening the Soundaktor, but with not too much difficulty, it can be done manually by simply disconnecting the supply wires. Something that you may want to consider as an alternative to using a dealer - and you will learn a lot too! Plus it's a task that's particularly suited to your gender because having small hands is a decided advantage when working inside the plenum chamber cavity! Worth considering - I suggest. If you have an interest, here's a video where the producer claims that it's a 10minute job! Done I actually don't mind the sound. I want to disable because it's not real. Feel like my car is a fake when it's on. Thanks for the post I'll watch the video and see how confident I feel!! Quote Link to comment Share on other sites More sharing options...
MCC Posted January 16, 2017 Report Share Posted January 16, 2017 Darren dialled mine down to 50% from 100% (standard)... sounds fine. I was a bit annoyed that the noise inside was not real. Good now Rich_D 1 Quote Link to comment Share on other sites More sharing options...
Meercat Posted January 16, 2017 Report Share Posted January 16, 2017 Hi Emma I have VCDS, can do it for you, not around much as i do a lot of travelling, I will PM you and see if we can sort it out. Have a good look at the relevant threads, most seem to dial it down rather than disable but I can do either for you James Quote Link to comment Share on other sites More sharing options...
dexter Posted January 16, 2017 Report Share Posted January 16, 2017 Yes I've seen this -thank you. As much as I want noise, I want it to be real. Any idea what VW would charge? And does anyone know of someone who has vcds in West Sussex? Sent from my iPhone using Tapatalk Emma, for cost, see my post at #2 above Quote Link to comment Share on other sites More sharing options...
JJacko Posted January 16, 2017 Report Share Posted January 16, 2017 i disabled mine with VCDS and so glad i did it, ended up buying the cable just to kill the damn thing, but all the other tweaks have been a bonus! Sounds much, much better, get it done whichever way! Quote Link to comment Share on other sites More sharing options...
Meercat Posted January 16, 2017 Report Share Posted January 16, 2017 Emma, can't PM you...grrr. J Quote Link to comment Share on other sites More sharing options...
g7nickh Posted January 17, 2017 Report Share Posted January 17, 2017 or as ive done 5min job just pull the plug from the acktuator.. no warning lights.. race mode on all thetime.. Quote Link to comment Share on other sites More sharing options...
