RoundSquare Posted January 30, 2017 Report Share Posted January 30, 2017 So I've got the code to extend the brake lights however there is no field for "Brake lights on" Anyone know from the picture below what it is now. I tried aktiv 100% but it didn't work STG09 (Central Electronics)> Access Authorisation: 31347 > Adaptation Channels> Channel (8 )-Leuchte27 NSL RC6-Lichtfunktion C27" > "Brake light on" set (default: nicht aktiv) STG09 (Central Electronics)> Access Authorisation: 31347 > Adaptation Channels > Channel (10)-Leuchte27 NSL RC6-Dimming CD27" > on 100 Set(default: 0) Then to stop the middle lights going out when lockingLeuchte27NSL RC6-Lichtfunktion B 27 from not active to "Parklicht rechts" And there is no "Parklicht rechts" Again anyone know what the proper field is? Thanks Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 30, 2017 Report Share Posted January 30, 2017 This is because the coding instructions were written before VCDS was properly translated to English. I had the same issue with a different tweak but luckily it was easily translated! Your best bet is to swap the language to German and use the Search box to search for the codes to find the correct fields to change. Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted January 30, 2017 Author Report Share Posted January 30, 2017 This is because the coding instructions were written before VCDS was properly translated to English. I had the same issue with a different tweak but luckily it was easily translated! Your best bet is to swap the language to German and use the Search box to search for the codes to find the correct fields to change. Thanks I've already tried that. "Brake light on" = "Bremsleuchte eingeschaltet" which still isn't in that picture.. I've coded 4 other Golfs with the old coding with no issue then they had to go and change it Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted January 30, 2017 Author Report Share Posted January 30, 2017 I found this graphic which is contradicting other info I have The info I have says Channel (10)-Leuchte27 NSL RC6-Dimming CD27" > on 100 Set(default: 0) whereas the graphic if I'm reading it right says change it to 10 Source: http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-62.html#post1164108 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 30, 2017 Report Share Posted January 30, 2017 I found this graphic which is contradicting other info I have The info I have says Channel (10)-Leuchte27 NSL RC6-Dimming CD27" > on 100 Set(default: 0) whereas the graphic if I'm reading it right says change it to 10 Source: http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-62.html#post1164108 That's the guide that I used to do my lights and it worked fine. If I were you, I'd change the language to German and do it that way. If you change the wrong thing you'll be in all kinda of trouble with hazard lights coming on when pressing the brake and other weird and wonderful things. DUB R4XX 1 Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted January 30, 2017 Author Report Share Posted January 30, 2017 That's the guide that I used to do my lights and it worked fine. If I were you, I'd change the language to German and do it that way. If you change the wrong thing you'll be in all kinda of trouble with hazard lights coming on when pressing the brake and other weird and wonderful things. Cheers. I didn't know I could change it to German. That might be easier. Although now I think about it, all the drop downs are in German or is it something else that changes? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 30, 2017 Report Share Posted January 30, 2017 Cheers. I didn't know I could change it to German. That might be easier. Although now I think about it, all the drop downs are in German or is it something else that changes? I think it's the actual channel translations. The guides all show the German versions, its only recently that the channel language is English. In my case, I just searched the German and then changed the appropriate channel, my VCDS program was in English but the channel data was German. For example, my program was in English until I got to searching "Leuchte27" and then picked the correct channel and made the adaption. I've just had a look now and searching for "Leuchte27" on the most recent version of VCDS doesn't show anything as these have all been changed to English. It's going to be those channels you need to marry. Unfortunately even looking at the translation of Leuchte27 doesn't correspond to anything in the new list. I did a little research into changing the language of VCDS just now and it looks like it can't be done as it depends on the distributor you bought the cable from. Sorry about that. I'm really surprised that this is the current situation. Anyone using VCDS from 16.8 onwards will have issues in coding as the guides are all out of date now due to the changes. This link might explain a little more. http://www.ross-tech.com/vag-com/labels.html RoundSquare 1 Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted January 31, 2017 Author Report Share Posted January 31, 2017 I think it's the actual channel translations. The guides all show the German versions, its only recently that the channel language is English. In my case, I just searched the German and then changed the appropriate channel, my VCDS program was in English but the channel data was German. For example, my program was in English until I got to searching "Leuchte27" and then picked the correct channel and made the adaption. I've just had a look now and searching for "Leuchte27" on the most recent version of VCDS doesn't show anything as these have all been changed to English. It's going to be those channels you need to marry. Unfortunately even looking at the translation of Leuchte27 doesn't correspond to anything in the new list. I did a little research into changing the language of VCDS just now and it looks like it can't be done as it depends on the distributor you bought the cable from. Sorry about that. I'm really surprised that this is the current situation. Anyone using VCDS from 16.8 onwards will have issues in coding as the guides are all out of date now due to the changes. This link might explain a little more. http://www.ross-tech.com/vag-com/labels.html Sorry I'd just went to bed when you replied last night. My software updated to the latest 17.1.2 and I've still got the Leuchte27 channels although its added ENG1169xx-ENG1169xx or similar before it which is very strange Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 31, 2017 Report Share Posted January 31, 2017 Sorry I'd just went to bed when you replied last night. My software updated to the latest 17.1.2 and I've still got the Leuchte27 channels although its added ENG1169xx-ENG1169xx or similar before it which is very strange That is weird, but those are the channels you'll want to be adapting. Quote Link to comment Share on other sites More sharing options...
dv52 Posted January 31, 2017 Report Share Posted January 31, 2017 Roundsquare: Perfectly normal! The ENG1169xx-ENG1169xx are called "tags" and Ross Tech started using them a few versions back. They replaced the familiar number in parentheses in the older version software. They are intended to identify (in number notation) the parent - child relationships between adaptation channels and they also can be used to identify the same channel across different control modules. Don ashleyman, DUB R4XX and RoundSquare 3 Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 7, 2017 Author Report Share Posted February 7, 2017 Just to update my own post in case anyone else is stuck. After trying various options that have been posted on the net, I had the brain wave of checking what I had changed it to on my wife's car a year ago I also noticed in an OBD11 post it had the option of Bremslicht but unfortunately VCDS doesn't have this option. So the proper code for VCDS is: STG09 (Central Electronics)> Access Authorisation: 31347 Adaptation ChannelsLeuchte27 NSL RC6-Lichtfunktion C27 change "not active" to "Brake light" Adaptation Channels Leuchte27 NSL RC6-Dimming CD27" change "0" to "100" Then to stop the middle lights going out when locking Leuchte27NSL RC6-Lichtfunktion B 27 change "not active" to "Parking light right" Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 7, 2017 Report Share Posted February 7, 2017 Thanks I've already tried that. "Brake light on" = "Bremsleuchte eingeschaltet" which still isn't in that picture.. I've coded 4 other Golfs with the old coding with no issue then they had to go and change it I found this graphic which is contradicting other info I have The info I have says Channel (10)-Leuchte27 NSL RC6-Dimming CD27" > on 100 Set(default: 0) whereas the graphic if I'm reading it right says change it to 10 Source: http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-62.html#post1164108 Roundsquare: I don't mean to be rude, but I would caution doing tweaks of any sort to any mk7 lighting, by referring to individual adaptation channels. The fact is that notice needs to be taken of all 19 x adaptation channels in a Leuchte-set when making changes to the car's lighting In my table above, notice that I've given the Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) command a different Alpha label (its gone from Bank 1 to Bank 2) . I've done this to ensure the the correct priority occurs when both the Brake light and the parking light functions happen at the same time. Altering the Alpha label as in I have described above means that (10)-Leuchte27 NSL RC6-Dimming CD27 must be a value 10 to retain the original lighting level for the parking light function -this channel does not pertain to the Brake-light/Bremslicht command). The illumination level for the Brake-light/Bremslicht command is determined by the (6)-Leuchte27NSL RC6-Dimmwert AB 27 setting (which as you can see is 100) Don Quote Link to comment Share on other sites More sharing options...
ashleyman Posted February 7, 2017 Report Share Posted February 7, 2017 Roundsquare: I don't mean to be rude, but I would caution doing tweaks of any sort to any mk7 lighting, by referring to individual adaptation channels. The fact is that notice needs to be taken of all 19 x adaptation channels in a Leuchte-set when making changes to the car's lighting In my table above, notice that I've given the Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) command a different Alpha label (its gone from Bank 1 to Bank 2) . Ive done this to ensure the the correct priority occurs when both the Brake light and the parking light functions happen at the same time. Altering the Alpha label means that (10)-Leuchte27 NSL RC6-Dimming CD27 must be a value 10 to retain the original lighting level for the parking light function -this channel does not pertain to the Brake-light/Bremslicht command). The illumination level for the Brake-light/Bremslicht command is determined by the (6)-Leuchte27NSL RC6-Dimmwert AB 27 setting (which as you can see is 100) Don Take note people. The master has spoken! DUB R4XX and dv52 2 Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 7, 2017 Author Report Share Posted February 7, 2017 Roundsquare: I don't mean to be rude, but I would caution doing tweaks of any sort to any mk7 lighting, by referring to individual adaptation channels. The fact is that notice needs to be taken of all 19 x adaptation channels in a Leuchte-set when making changes to the car's lighting In my table above, notice that I've given the Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) command a different Alpha label (its gone from Bank 1 to Bank 2) . I've done this to ensure the the correct priority occurs when both the Brake light and the parking light functions happen at the same time. Altering the Alpha label as in I have described above means that (10)-Leuchte27 NSL RC6-Dimming CD27 must be a value 10 to retain the original lighting level for the parking light function -this channel does not pertain to the Brake-light/Bremslicht command). The illumination level for the Brake-light/Bremslicht command is determined by the (6)-Leuchte27NSL RC6-Dimmwert AB 27 setting (which as you can see is 100) Don Hi Don, No I don't think you are rude at all in fact I welcome your input. Thanks. I tried your coding above and it put out my normal inner lights to leave me just the outer lights. I don't mean while braking, I mean when the lights were on. The only reason I went with the codes I have listed above is, this was the coding for the full width brake lights from a few years back. Its been like that on my GTD since 2014 without any issue. I know that doesn't make it correct but it surely proves that it is safe? Can I ask what you mean by "Parking lights"? Is that just the normal rear lights when your front lights are on? I totally get the logic of your post but not sure what you mean re correct priority? Are you saying one will override the other in some way? Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 8, 2017 Report Share Posted February 8, 2017 Hi Don, No I don't think you are rude at all in fact I welcome your input. Thanks. I tried your coding above and it put out my normal inner lights to leave me just the outer lights. I don't mean while braking, I mean when the lights were on. The only reason I went with the codes I have listed above is, this was the coding for the full width brake lights from a few years back. Its been like that on my GTD since 2014 without any issue. I know that doesn't make it correct but it surely proves that it is safe? Can I ask what you mean by "Parking lights"? Is that just the normal rear lights when your front lights are on? I totally get the logic of your post but not sure what you mean re correct priority? Are you saying one will override the other in some way? Roundsquare: My bad - I keep forgetting that words change in other parts of the world and what's common-usage here (in Australia) might not be used elsewhere. "Parking light" is the term we Aussies use for the auxiliary lamps that light-up whenever the low beams are switched-on. Do you call them "side lights" perhaps? The lamps used for DRL do this on the front headlight assemblies and the rear tails also do this. Priority is something that needs to be considered when designing Leuchte programming instructions. When a lamp is asked to perform multiple functions, consideration needs to be given to how the lamp is to respond whenever more than one function is requested the the same time. This is sometimes called a "conflict" in programming language and it needs to be resolved. The way that Leuchte programming resolves the conflict is by the Alpha channel identifier (i.e. A, B, C.....F) - this determines what priority each function has in a conflict (hope this makes sense). Don RoundSquare 1 Quote Link to comment Share on other sites More sharing options...
