Deactivate headlight washers (OBDeleven Coding)
Booth11
1)  Select Central Electrics
2)  Select Coding
3)  Scroll down the very long list until you find Scheinwerferreinigungslage
4)  Change to not installed (default is 'installed')
5)  Press the green tick to confirm
The headlight washer should be disabled
Screenshots
09 Central Electrics
Coding
Search or scroll to Scheinwerferreinigungslage and tap it
Default is 'installed'
Change to 'not installed' and tap 'ok'
Should show as 'not installed' then tap green tick to accept the adaptation
  • 2 years later...
try this:
1)  Select Central Electrics module @  address hex09
2)  Select Security access
3)  Enter the magic number 31347
4)  Select Adaptation
5)  Search for "Scheinwerferreinigung" and select Headlamp washer system
6) set to "not installed"
  • 5 years later...
