Dr.R Posted April 7, 2017 Report Share Posted April 7, 2017 Anyone cracked this yet Thanks Quote Link to comment Share on other sites More sharing options...
dv52 Posted April 7, 2017 Report Share Posted April 7, 2017 9 hours ago, Dr.R said: Anyone cracked this yet Thanks Dr.R: My understanding is that retrofitting the "Performance Monitor" to those MIBII units that didn't have the function factory fitted is what's known as "SWAP" (Software as product) and as such it can only be purchased from a (willing) dealer with an activation code that is specific to your VIN. But you can always try the "poor cousin version" HERE Don Dr.R 1 Quote Link to comment Share on other sites More sharing options...
Dr.R Posted April 7, 2017 Author Report Share Posted April 7, 2017 Amazing DonI'll look into itMany thanks budAll the best Quote Link to comment Share on other sites More sharing options...
Chris1h Posted April 15, 2017 Report Share Posted April 15, 2017 anyone tried this? does it work? Quote Link to comment Share on other sites More sharing options...
Dr.R Posted April 22, 2017 Author Report Share Posted April 22, 2017 Still trying Chris1h 1 Quote Link to comment Share on other sites More sharing options...
Chris1h Posted April 24, 2017 Report Share Posted April 24, 2017 On 22/04/2017 at 15:40, Dr.R said: Still trying i for one wish so bad i had this. keep posted if you find a way. i asked my dealer and they said carnt be done but maybe they are hiding something Quote Link to comment Share on other sites More sharing options...
alexretro Posted May 2, 2017 Report Share Posted May 2, 2017 Performance monitor can be done only by dealer atm. Its VIN related Quote Link to comment Share on other sites More sharing options...
PmP Posted May 3, 2017 Report Share Posted May 3, 2017 Would I be right in saying it only works on cars with Nav too. Quote Link to comment Share on other sites More sharing options...
alexretro Posted June 2, 2017 Report Share Posted June 2, 2017 Hopefully this will be cracked this summer. For Pro mib2 only stotty8 and Dr.R 2 Quote Link to comment Share on other sites More sharing options...
Dr.R Posted June 2, 2017 Author Report Share Posted June 2, 2017 InfoDv52 sussed this a while back Quote Link to comment Share on other sites More sharing options...
Billy Whizz Posted June 8, 2017 Report Share Posted June 8, 2017 I've got the off road monitors on mine through VCDS, if you have MIB11, software v 0245 then you should be ok, I only asked for the 3 clocks that indicate temps, compass, altimeter, inclinometer etc just swipe up and down to change them. Don't use them TBH, just another gizmo, suppose I could have got him to unlock boost etc....? Was an afterthought whilst the guy was doing the normal brake light, drl, Aktivator stuff. But...they are unlockable without dealer intervention if your infotainment system meets certain requirements, and No, mine isn't Nav pro..... Dr.R 1 Quote Link to comment Share on other sites More sharing options...
roberth Posted June 8, 2017 Report Share Posted June 8, 2017 1 hour ago, Billy Whizz said: I've got the off road monitors on mine through VCDS, if you have MIB11, software v 0245 then you should be ok, I only asked for the 3 clocks that indicate temps, compass, altimeter, inclinometer etc just swipe up and down to change them. Don't use them TBH, just another gizmo, suppose I could have got him to unlock boost etc....? Was an afterthought whilst the guy was doing the normal brake light, drl, Aktivator stuff. But...they are unlockable without dealer intervention if your infotainment system meets certain requirements, and No, mine isn't Nav pro..... Be interested to know how this is done, as all threads on unlocking the performance monitor point to Dealer only Dr.R 1 Quote Link to comment Share on other sites More sharing options...
Dr.R Posted June 9, 2017 Author Report Share Posted June 9, 2017 DV52 has cracked the input codes but like above depends on your unit spec etc Quote Link to comment Share on other sites More sharing options...
roberth Posted June 9, 2017 Report Share Posted June 9, 2017 31 minutes ago, Dr.R said: DV52 has cracked the input codes but like above depends on your unit spec etc Perhaps dv52 would like to share his findings lukeh92, Booth11 and marshy 3 Quote Link to comment Share on other sites More sharing options...
Dr.R Posted June 9, 2017 Author Report Share Posted June 9, 2017 I'll send you the link later roberth 1 Quote Link to comment Share on other sites More sharing options...
