Album Artwork
RichC
I've decided to leave an SD card in my car with a selection of my favourite music on for when i'm not using Spotify or the radio, etc.
I spent a bit of time a while ago tidying all of my music, tagging it all correctly and adding in the artwork, this was done using iTunes.
I've dropped a load of the files on to the SD card in folders for each artist and put it in the car, but only some of the artwork appears, it's really confusing me to be honest because I can't work out why it's showing some and not others, they were all jpg when I linked them.
Anyone else experienced this or have any advice?
I've even tried dropping the same files back into Windows Media Player on my works laptop and its shows all the artwork on there.
I usually go for the highest quality I can find, usually ends up around 1000 x 1000, so any that are showing up already will be around that size. I can't work it out at all. Andy how did you add the artwork to your tracks? And also how are you guys adding them to the SD card?
I use an SD card & a USB Stick and I have used mp3tag to do all the artwork at 600 x 600 and then copied and pasted from my PC to the SD card or USB Stick
iTunes can be a right pain the way it writes the mp3 tags with artwork.
I would get mp3tag and open the files that you are having the issues with from within mp3tag and then fix the faulty artwork and save them back to the SD card using mp3tag
Hope that makes some sense.
"Computers make it easier to do a lot of things, but most of the things they make it easier to do don't need to be done."
I did a similar thing to my music collection prior to getting the R. I read that max album art size is 500x500 pixels and needs to be in a jpg format and can be in-bedded in the MP3 file.
The problem you will probably have is itunes, personally I can't stand the stinking pile of cr*p but I appreciate there are apple devices owners who have few other options. One of the reasons the artwork won't appear is that itunes stores them as png file types and has done for a while, which makes it incompatible with an awful lot of media players.
Best bet is to run through your music library with a programme such as MP3 tag or any other free piece of software which allows you to specify the album art size and then it will scrape the internet for the appropriate images and inbed it correctly to the file, although itunes will then try to revert it back to a png file if you allow it to.
All you need to know re id3 tagging etc
mp3tag is brilliant
sansmp3art is great piece of freeware.  Fir tagging and resizing
Wirhout gettibg into detail, each track needs image embedded in its id3 tag, rather than within album folders separate .jpg.   iTunes etc can operate in different ways, even with same MP3 container.
Key point maybe that for mib1 and 2, 400*400 pix is max that can be displayed in car.  Larger files get ignored.
Its worth spending a few a few hours tagging your collection so that it works on all your systems home-car-portable rig etc.  Once tagged correctly, it's then easy to batch convert, should you require.
Car-net now has gracenotes app on it, it runs in the background and fetches the correct album art for you.....obviously you need to be online
I used the add album artwork / google trick to some of mine but there were albums with no artwork on my sd drive...gracenotes added the artwork on-the-fly
Gracenote wasn’t enabled on mine, it was shortly after delivery......
Same as Street View was
On 10/08/2017 at 13:13, veneeringman said:
Gracenote wasn’t enabled on mine, it was shortly after delivery......emoji4.png
Gracenote is actually already embedded in  mib 1 and 2 disco pro sw
But, it's for CDs and not optimised for other inputs. I guess it's a metadata and db thang.
Success!
All is well at last. Thanks for everyone's help.
A few things just for clarity, i ended up resizing to 600 x 600 and all display perfectly, although some had previously been tagged correctly with larger files and they did display also.
mp3tag was perfect for the job, showed up all the errors and allowed me to be consistent with the tagging.
I think the reason some of mine were working and some weren't wasn't actually down to the size of the artwork but more how it was tagged as others have already mentioned.
I'm doing the same with an SD card of music, although every few days the infotainment unit seems to lose its database of tracks and only shows the first album. If I eject the card and put it back in it's ok again.
Anyone else seen this, mine is a FL with standard nav?
