James42 Posted August 23, 2017 Report Share Posted August 23, 2017 I've been revo stage 2 for about 3 weeks now but the last couple of days the car doesn't seem to be boosting as strong and just generally feeling sluggish just seems like it's holding back a bit, anybody had similar symptoms ?? Cheers Quote Link to comment Share on other sites More sharing options...
James42 Posted August 23, 2017 Author Report Share Posted August 23, 2017 Dv is the first thing I thaught but wasn't sure it would cause these symptoms and vwr600 tt inlet wagner bcs turbo back 200 cell cat Quote Link to comment Share on other sites More sharing options...
Danielwang Posted August 23, 2017 Report Share Posted August 23, 2017 What supporting mods? Post a video if possible. 1st thoughts would be have you a DV+ installed?, The stock part isn't really up to stage 2 Failing that I would be checking for leaks on boost pipe. Agree, increasing boost may cause the DV fail and has boost leak Quote Link to comment Share on other sites More sharing options...
Frantastic Posted August 23, 2017 Report Share Posted August 23, 2017 Have you got an intercooler? I'm revo stage 2 and I can notice it differing on the outside TempsSent from my E6853 using Tapatalk Quote Link to comment Share on other sites More sharing options...
seadragon Posted August 24, 2017 Report Share Posted August 24, 2017 I am stage 2 and I cant say I was blown away by the difference. I thought it would be way more aggressive than standard. The car is still bloody lazy unless you put your foot down. Quote Link to comment Share on other sites More sharing options...
James42 Posted August 24, 2017 Author Report Share Posted August 24, 2017 12 hours ago, Frantastic said: Have you got an intercooler? I'm revo stage 2 and I can notice it differing on the outside Temps Sent from my E6853 using Tapatalk Yeah got the Wagner Quote Link to comment Share on other sites More sharing options...
James42 Posted August 24, 2017 Author Report Share Posted August 24, 2017 2 hours ago, seadragon said: I am stage 2 and I cant say I was blown away by the difference. I thought it would be way more aggressive than standard. The car is still bloody lazy unless you put your foot down. When I first had it done It felt great I don't know if it's me getting used to it but 99% sure somethings up just not coming on boost as hard Quote Link to comment Share on other sites More sharing options...
GrayMK7R Posted August 24, 2017 Report Share Posted August 24, 2017 3 hours ago, seadragon said: I am stage 2 and I cant say I was blown away by the difference. I thought it would be way more aggressive than standard. The car is still bloody lazy unless you put your foot down. That's the stock throttle pedal mapping that want to change mate Quote Link to comment Share on other sites More sharing options...
James42 Posted August 24, 2017 Author Report Share Posted August 24, 2017 1 hour ago, GrayMK7R said: That's the stock throttle pedal mapping that want to change mate Does the revo affect peddle mapping or does it stay stock ? Quote Link to comment Share on other sites More sharing options...
GuyKitch Posted August 24, 2017 Report Share Posted August 24, 2017 Could be to do with the weather in all honesty. It's quite muggy at the moment. Not a lot of cool air. The intake air temperatures will rise and lead to a loss of power due to heat soak etc. Plus if you like running your air con 24/7 I'd advise you didn't... this will also lead to power loss and increased heat. Quote Link to comment Share on other sites More sharing options...
Naz7r Posted August 24, 2017 Report Share Posted August 24, 2017 I've been revo stage 2 for about 3 weeks now but the last couple of days the car doesn't seem to be boosting as strong and just generally feeling sluggish just seems like it's holding back a bit, anybody had similar symptoms ?? Cheers I'd check the diverter valve or possibly even change it to GFB, I did on mines and noticed the car was boosting loads better and the throttle response on boost was instant even throughout shifts. Also check the spark plugs as cars on stage 2 like my one loves to cook the standard plugs. Quote Link to comment Share on other sites More sharing options...
Ferg_7R Posted August 24, 2017 Report Share Posted August 24, 2017 21 hours ago, James42 said: I've been revo stage 2 for about 3 weeks now but the last couple of days the car doesn't seem to be boosting as strong and just generally feeling sluggish just seems like it's holding back a bit, anybody had similar symptoms ?? Cheers Do you have access to VCDS? I think you really need to log boost and timing pull to see what is going on. marshy 1 Quote Link to comment Share on other sites More sharing options...
James42 Posted August 24, 2017 Author Report Share Posted August 24, 2017 9 minutes ago, Ferg_7R said: Do you have access to VCDS? I think you really need to log boost and timing pull to see what is going on. No but my local garage does I'll have them take a look I think Quote Link to comment Share on other sites More sharing options...
James42 Posted August 24, 2017 Author Report Share Posted August 24, 2017 15 minutes ago, Naz7r said: I'd check the diverter valve or possibly even change it to GFB, I did on mines and noticed the car was boosting loads better and the throttle response on boost was instant even throughout shifts. Also check the spark plugs as cars on stage 2 like my one loves to cook the standard plugs. What plugs have you upgraded to ? Quote Link to comment Share on other sites More sharing options...
Naz7r Posted August 24, 2017 Report Share Posted August 24, 2017 Apr recommended Denso ikh24 for stage 2, it's also on there website.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
