lonions Posted June 18, 2018 Report Share Posted June 18, 2018 So the past week I’ve noticed that I’m occasionally getting a stop start error, saying there is a fault with the system.I did a scan with my obd and got the error code “Battery terminal recognition open circuit”, I cleared it and it started working again but it has re appeared today. I’ve had a quick look at the battery and can’t see anything wrong with it. Anyone had a similar issue or know what might be causing it? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
chrisrgolf Posted June 13, 2019 Report Share Posted June 13, 2019 Did you find a fix for this? Same thing is happening with my R Quote Link to comment Share on other sites More sharing options...
lonions Posted June 13, 2019 Author Report Share Posted June 13, 2019 I had the same issue, it started occurring after they done a software update on the parking brake.When i took it for its service I mentioned the fault and they said they reinstalled the software for the brake and I haven’t seen it since.Might not be the same issue as yours but I had the same fault code when I used my OBD scanner!I never really understood the problem but I noticed mine would idle at about 1000rpm when I had the stop start error as well.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
lonions Posted June 13, 2019 Author Report Share Posted June 13, 2019 Just realised I started this topic thinking it was someone else it’s been a long weekSent from my iPhone using Tapatalk sjw94, DaveGR, Shug and 1 other 4 Quote Link to comment Share on other sites More sharing options...
chrisrgolf Posted June 13, 2019 Report Share Posted June 13, 2019 Haha.. yeah I've got that same code as well. Ive just recently gotten my front brake pads replaced. Not sure what kind of software tom foolery they would have to do there... Quote Link to comment Share on other sites More sharing options...
Jrzinho Posted December 8, 2021 Report Share Posted December 8, 2021 On 13/06/2019 at 05:15, lonions said: Acabei de perceber que comecei este tópico pensando que era outra pessoa , faz uma longa semana Enviado do meu iPhone usando Tapatalk Managed to solve? Quote Link to comment Share on other sites More sharing options...
Jrzinho Posted December 8, 2021 Report Share Posted December 8, 2021 (edited) I'm Brazilian and around here I haven't found any solution. My car gets heavy driving start stop error Fan does not pass speed 3 It rarely gives warning of low battery and keyless error. Very rarely. I already changed the negative cable, the one that goes to the battery pole. Alternator. I already replaced the battery, for an original one. And I've already cleared all grounds, ends and nothing. And every time I try to resolve it is necessary to disconnect the terminals. This resets q causes the problem to take a long time to reappear. Has a friend already solved this problem and could inform the diagnosis? Edited December 8, 2021 by Jrzinho Quote Link to comment Share on other sites More sharing options...
Millsn Posted December 24, 2021 Report Share Posted December 24, 2021 Mine did something similar a few days before my battery died. There was a fault with a couple of the cells apparently. Quote Link to comment Share on other sites More sharing options...
Avesshen Posted February 2, 2022 Report Share Posted February 2, 2022 Anyone managed to find a solution for the stop/ start issue ? Quote Link to comment Share on other sites More sharing options...
fastandy Posted February 2, 2022 Report Share Posted February 2, 2022 Usually 1. battery, 2. terminals or ground wire corrosion, 3. charging issue. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 3, 2022 Report Share Posted February 3, 2022 14 hours ago, fastandy said: Usually 1. battery, 2. terminals or ground wire corrosion, 3. charging issue. With # 1 being way more common than the other two. Some contributors to # 3 are: - Short runs and/or heavy traffic where the battery never gets charged up properly - Car sitting unused for long periods allowing charge to drop down too much - Aftermarket electrical changes causing parasitic drain (eg dash cam, ICE, extra/different lights ) - Leaving ICE/lights on, or charging phone when engine not running Quote Link to comment Share on other sites More sharing options...
Avesshen Posted February 4, 2022 Report Share Posted February 4, 2022 I’ve check all the above mentions and it’s not that , that’s cause the battery terminal recognition open error Quote Link to comment Share on other sites More sharing options...
fastandy Posted February 4, 2022 Report Share Posted February 4, 2022 quick google suggests check all the points previously posted. How old is the battery? How do you know the battery is not faulty? ### www. golfmk7.com/forums/index.php?threads/8521278-battery-terminal-recognition-u1411-00-008-open-circuit.370919/ ### Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 4, 2022 Report Share Posted February 4, 2022 3 hours ago, Avesshen said: I’ve check all the above mentions and it’s not that , that’s cause the battery terminal recognition open error Have you checked your battery for cranking capacity, and voltage; resting and with engine running ? Quote Link to comment Share on other sites More sharing options...
Avesshen Posted February 5, 2022 Report Share Posted February 5, 2022 Hi, We've checked battery and even went through the trouble of replacing it with a new battery within spec for the car. its been a week now and the issue hasn't shown up again but as usual it will randomly pop up Quote Link to comment Share on other sites More sharing options...
