OBD 11 checking timing belt alignment
EcosseGolfR
  • 6 months later...
  • 2 years later...
Hello @EcosseGolfR
Did you ever find the tolerance values for chain stretch?
Ive got error P00016 - Crank/Cam Position Correlation – Bank 1 Sensor “A”
and values
Camshaft adaptation intake bank 1, phase position = -2.6 degrees
Camshaft adaptation exhaust bank 1, phase position = 12.3 degrees
Off the top of my head it doesn't look great!
26 minutes ago, JAMMIO said:
Hello @EcosseGolfR
and values
Unfortunately I didn’t, I didn’t receive any errors. I was only looking what the tolerances where for the sake of knowing.
without me revisiting the shopdap video above, did that help any? It was so long ago.
Ok no problem, the info in the video is good but its for the older tsi engine. It looks like the newer engines have 2 camshaft sensors(values) on the intake and exhaust and the old engines just have one reading to look at so im not sure how to interupt if the readings are correct or not.
Ill try and get onto VW or a garage see if they know ,
cheers
  • 3 months later...
