Daveleach Posted April 5, 2019 Report Share Posted April 5, 2019 Just purchased OBDELEVEN. Is there anyway of testing the haldex/pump output? I’m getting a lot of traction light flashing on brand new MP4 tyres. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 5, 2019 Report Share Posted April 5, 2019 I think if you are getting any kind of lack of traction get the Haldex looked at asapSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 5, 2019 Author Report Share Posted April 5, 2019 Codes read? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 5, 2019 Report Share Posted April 5, 2019 Looked at as in service, you shouldn't get any traction issues at all even from a launch. I take it you have good quality matched tyres which is why you suspect the Haldex? Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 5, 2019 Author Report Share Posted April 5, 2019 I have 4 brand new ps4 fitted. im unicorn stage 2, but my tc seems to flash easily! ive cleaned the pump and changed the oil previously Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 5, 2019 Report Share Posted April 5, 2019 I have 4 brand new ps4 fitted. im unicorn stage 2, but my tc seems to flash easily!Ah sorry Dave missed that on the first thread, even at 400bhp you shouldn't get any slip so does sound like something is not quite right especially if the tyres are brand new, what mileage is the car on and has it ever had a Haldex oil change?Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 5, 2019 Author Report Share Posted April 5, 2019 2 minutes ago, SpursMadDave said: Ah sorry Dave missed that on the first thread, even at 400bhp you shouldn't get any slip so does sound like something is not quite right especially if the tyres are brand new, what mileage is the car on and has it ever had a Haldex oil change? Sent from my SM-G950F using Tapatalk Car is on 40k. and yes I’ve serviced the Haldex. changed oil/cleaned filter Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 5, 2019 Report Share Posted April 5, 2019 Car is on 40k. and yes I’ve serviced the Haldex. changed oil/cleaned filter Could be the pump then maybe? Hopefully nothing major, back to the original question not sure there is anything on OBD but I do remember someone getting a kind of graph or something but not sure if it was for the Haldex sorry. Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 5, 2019 Author Report Share Posted April 5, 2019 Would a faulty pump not throw a code when scanned tho Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 5, 2019 Report Share Posted April 5, 2019 Would a faulty pump not throw a code when scanned thoNot sure Dave, most likely but maybe it's just not at full strength? Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
MDLBC Posted April 5, 2019 Report Share Posted April 5, 2019 Unfortunately not necessarily.The easiest test is to do a launch.Here is a thread that you may find useful:APR + all-seasons = traction issues?https://r.tapatalk.com/shareLink?share_fid=7951&share_tid=9298691&url=https%3A%2F%2Fforums%2Evwvortex%2Ecom%2Fshowthread%2Ephp%3Ft%3D9298691&share_type=t Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 5, 2019 Author Report Share Posted April 5, 2019 So something is possible with obd. Will I need to pro to reset the values etc? Quote Link to comment Share on other sites More sharing options...
MDLBC Posted April 5, 2019 Report Share Posted April 5, 2019 So something is possible with obd. Will I need to pro to reset the values etc?You will. Quote Link to comment Share on other sites More sharing options...
Daveleach Posted April 6, 2019 Author Report Share Posted April 6, 2019 Quick update Haldex clutch pump current 1.534A haldex clutch pump PWM signal 12% haldex clutch pump voltage 1.7V haldex clutch pump status degree of blockage 0.0% i then tried to reset as described in the thread posted above and i got an error message 13) function cannot be performed, mess . Length or format incorrect. Quote Link to comment Share on other sites More sharing options...
MDLBC Posted April 6, 2019 Report Share Posted April 6, 2019 Quick update i then tried to reset as described in the thread posted above and i got an error message 13) function cannot be performed, mess . Length or format incorrect. Try contacting OBD Eleven or one of the other people that performed this function on VWVortex but at this point (and assuming still under warranty) a trip to the dealership sounds in order. Quote Link to comment Share on other sites More sharing options...
