Haldex test
Daveleach
  • 1 year later...
On 15/05/2019 at 09:03, Daveleach said:
After a public outing in another post.
Actually forgot I was meant to post something. So cheers for the public outing
Obdeleven
Have you tried the pump motor? AWD -> Basic Settings -> Pump motor
Then try reseting adaptations in Basic Settings.
Engine on 1. (22) AWD -> Basic Settings -> Pump Prime for 30 seconds It seems to make a humming noise and then seems to purge. Sound is an alive indicator. I've found nothing else to diagnose a pump without taking it out which I also done and put 12v through it and it was fine.
2. (22) AWD -> Output Tests -> Clutch Engaged/Disengaged 2 times for 30 seconds each.
Ignition on, Engine off 3. (22) AWD -> Clear codes (even if none are present)
4. (22) AWD -> Basic Settings -> Clear all adaptation values
5. Drive off, no launches for a few miles or so.
I found this cured my issues and have not seen the TC light since.
the above was from various posts and trial and error with obdeleven.
Has anyone had any problems get this to work? Seems to try and then says test unavailable, does the car have to be warmed up before trying this? Any help greatly appreciated!
