Haldex test
Daveleach
I was getting lots of tc light. Cleaned pump changed oil. Same.
scanned with obdeleven no faults in unit 22. Then combined a few steps I found in a couple of different posts, and now I have no tc light.
So are codes only logged after a launch?
Holy shit man. Tell us what you actually did.
Sent from my SM-N950U1 using Tapatalk
  • 2 weeks later...
  • 4 weeks later...
After a public outing in another post.
Actually forgot I was meant to post something. So cheers for the public outing
Obdeleven
Have you tried the pump motor? AWD -> Basic Settings -> Pump motor
Then try reseting adaptations in Basic Settings.
Engine on 1. (22) AWD -> Basic Settings -> Pump Prime for 30 seconds It seems to make a humming noise and then seems to purge. Sound is an alive indicator. I've found nothing else to diagnose a pump without taking it out which I also done and put 12v through it and it was fine.
2. (22) AWD -> Output Tests -> Clutch Engaged/Disengaged 2 times for 30 seconds each.
Ignition on, Engine off 3. (22) AWD -> Clear codes (even if none are present)
4. (22) AWD -> Basic Settings -> Clear all adaptation values
5. Drive off, no launches for a few miles or so.
I found this cured my issues and have not seen the TC light since.
the above was from various posts and trial and error with obdeleven.
