Keyless protector
Parky-SPP
On 02/05/2019 at 10:13, gregozedobe said:
It's worth checking every now and then that the faraday pouches are still doing their job - I've read a few reports now that some faraday pouches' linings wear out and are no longer effective at blocking signals.[snip]
^ This.  Once the inner lining goes soft or deteriorates at all, they need replacing.  I've found the lining deteriorates rapidly if subjected to any bending - for example, walking around with one in your trouser pocket.
Yeah I’ve heard this too.. Another thing is you need to make sure the flap is fully over the opening. I tried a couple of times with the key in the bag to open the door when the flap was slightly ajar and after a couple of goes the car unlocked. If I’m leaving it for any time like holiday or weekend away or anywhere I’m ‘not sure’ it’s an old fashioned big yellow crook lock!!  Didn’t know you could disable the fob by pressing and holding the lock button though! Top tip 😄
Because of these issues with the pouches, I chose to buy this:
https://www.amazon.co.uk/Alpha-Shield-Premium-Keyless-Aluminium-Schwarz/dp/B077JCQFXQ/
These are full metal boxes and shield perfectly. They also look pretty classy; the downside is they are pretty expensive...
They are thicker than a pouch, but have smaller length/width.
Overall, I'm very satisfied and wouldn't change them (I bought two, for both keys).
Edited by r@d00
