Scotty2hotty Posted May 28, 2019 Report Share Posted May 28, 2019 Can anyone help, I coded pace car indicators on my friends mk7 Golf R and when he indicates left both the inner tailgate indicators blink instead of just one side 🤦‍♂️ Has anyone come across this?  Thanks in advance.  Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 28, 2019 Report Share Posted May 28, 2019 How did you code it and what code did you use?Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Scotty2hotty Posted May 28, 2019 Author Report Share Posted May 28, 2019 I followed these instructions Quote Link to comment Share on other sites More sharing options...
Haych Posted May 28, 2019 Report Share Posted May 28, 2019 Might be worth checking channel Leutchte16BLK again. From memory i think this is the channel that controls what the tail lights do, when pushing the indicator stalk down. Mostly likely the wrong adaptation has been selected, as the adaptation names are very similar. i would check if Blinken links Dunkelphase have been selected instead of a similarly worded adaptation. Scotty2hotty 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted May 29, 2019 Report Share Posted May 29, 2019 To add to the replies that have already beenn given - your description that " when he indicates left both the inner tailgate indicators blink instead of just one side" strongly suggests that on the Leuchte-set for the right-side lamp, a left-side leuchte-command has been used (i.e with the term "links") instead of a right-side Leuchte-command (i.e, with the term "rechts"). This error would result in your explanation - and it would also mean that neither inner tailgate indicator would operate when "he indicates" right.  The Leuchte-set for the right-side inner tailgate indicator lamp is Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - look through the settings in this Leuchte-set - there should be NO reference to "links" in any of the 19 x channels in this Leuchte-set  Don Scotty2hotty 1 Quote Link to comment Share on other sites More sharing options...
Scotty2hotty Posted May 29, 2019 Author Report Share Posted May 29, 2019 Thank you for your help and replies I will give it a go later when I get home from work, it probably is user error 🤦‍♂️🤣  @dv52 your absolutely correct, when he indicates right only the outer right lamp works and no others. Quote Link to comment Share on other sites More sharing options...
Scotty2hotty Posted May 29, 2019 Author Report Share Posted May 29, 2019 Thanks for your help guys, you were both correct, when coding the right side I selected Blinken links Dunkelphase instead of Blinken rechts Dunkelphase.  Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 29, 2019 Report Share Posted May 29, 2019 Thanks for your help guys, you were both correct, when coding the right side I selected Blinken links Dunkelphase instead of Blinken rechts Dunkelphase.  You blinken dunklephase Sent from my SM-G950F using Tapatalk Scotty2hotty 1 Quote Link to comment Share on other sites More sharing options...
