shurcomb Posted January 14, 2020 Report Share Posted January 14, 2020 Anyone else seen this error message before? I have had it intermittently over the past few weeks. Had initially attributed it to happening when the car was stood for a few days without moving over Christmas period, but had it happen on Saturday morning. I had parked the car on Friday night and about 14 hrs between park up and driving again on Saturday. The error clears within a couple of minutes of driving and no other issues I am aware of. Any suggestions? or is it a dealer visit to see what the dealership monkeys can tell me. Cheers, Quote Link to comment Share on other sites More sharing options...
Paradox1 Posted January 14, 2020 Report Share Posted January 14, 2020 Ideally it needs a scan to see what the fault is. I had this issue recently and it turned out to be the wiring on my throttle body. Not saying this is the same issue you are having but I had the same error Quote Link to comment Share on other sites More sharing options...
shurcomb Posted January 14, 2020 Author Report Share Posted January 14, 2020 2 minutes ago, Paradox1 said: Ideally it needs a scan to see what the fault is. I had this issue recently and it turned out to be the wiring on my throttle body. Not saying this is the same issue you are having but I had the same error OK, thanks for the info. I will get it booked into the dealer and see what they say. Was yours covered by warranty? Ta. Quote Link to comment Share on other sites More sharing options...
Jens0n Posted January 14, 2020 Report Share Posted January 14, 2020 Common issue if you google. Hopefully you’re under warranty as it’s a replacement switch in the DSG box and prop shaft needs dropping to access. JSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Fletch..gti Posted January 14, 2020 Report Share Posted January 14, 2020 As above , had mine done 18 months ago . Big job but done under warranty Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 15, 2020 Report Share Posted January 15, 2020 Can’t quite see what it says for the dust!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Paradox1 Posted January 15, 2020 Report Share Posted January 15, 2020 20 hours ago, shurcomb said: OK, thanks for the info. I will get it booked into the dealer and see what they say. Was yours covered by warranty? Ta. No mate mine wasn't covered by warranty, I've got a gen 1 engine Quote Link to comment Share on other sites More sharing options...
shurcomb Posted January 15, 2020 Author Report Share Posted January 15, 2020 4 hours ago, slider09 said: Can’t quite see what it says for the dust! Sent from my iPhone using Tapatalk Yeah, the screen could do with a good clean, like the rest of the inside and outside of the car at the moment 😃😃 Cheers! slider09 1 Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted January 16, 2020 Report Share Posted January 16, 2020 On 15/01/2020 at 01:24, shurcomb said: Anyone else seen this error message before? I have had it intermittently over the past few weeks. Had initially attributed it to happening when the car was stood for a few days without moving over Christmas period, but had it happen on Saturday morning. I had parked the car on Friday night and about 14 hrs between park up and driving again on Saturday. The error clears within a couple of minutes of driving and no other issues I am aware of. Any suggestions? or is it a dealer visit to see what the dealership monkeys can tell me. Cheers, Eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeek!!!!....Dusty screen.... Quote Link to comment Share on other sites More sharing options...
blower Posted January 16, 2020 Report Share Posted January 16, 2020 On 14/01/2020 at 12:24, shurcomb said: Anyone else seen this error message before? I have had it intermittently over the past few weeks. Had initially attributed it to happening when the car was stood for a few days without moving over Christmas period, but had it happen on Saturday morning. I had parked the car on Friday night and about 14 hrs between park up and driving again on Saturday. The error clears within a couple of minutes of driving and no other issues I am aware of. Any suggestions? or is it a dealer visit to see what the dealership monkeys can tell me. Cheers, This is a common fault on all DSG cars and has existed since 2005 in the VAG range It typically surfaces if the car has been left standing for a long time - when the switch is on the way out. Unfortunately it requires replacing the entire selector mechanism as you cant get to the switch inside it - although spraying some contact cleaner at the switch and then a bit of silicone oil may free it up and give it some more life. I've had to replace the mechanism's on a couple of cars due to this issue, including my own on a Mk5 Golf. Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 16, 2020 Report Share Posted January 16, 2020 This is a common fault on all DSG cars and has existed since 2005 in the VAG range It typically surfaces if the car has been left standing for a long time - when the switch is on the way out. Unfortunately it requires replacing the entire selector mechanism as you cant get to the switch inside it - although spraying some contact cleaner at the switch and then a bit of silicone oil may free it up and give it some more life. I've had to replace the mechanism's on a couple of cars due to this issue, including my own on a Mk5 Golf. A known free fix has fixed this problem. Just move the DSG from P to D/S many times. This seems to have the affect of cleaning these micro switches and clears any crud which causes this issue. Sent from my iPhone using Tapatalk gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
shurcomb Posted January 16, 2020 Author Report Share Posted January 16, 2020 Thanks for the replies guys. Would have thought VAG might have changed the type of switch being used by now. I am still within the warranty period so I will take it in and see what the local dealer can do. Although the thought of them clambering all over the car makes me shudder and think about the other things they can damage in the process! Considering my car has about 15K on the clock and is a 17.5 model (May 2017), its pretty poor durability for the switch. Quote Link to comment Share on other sites More sharing options...
