Help with Coolant problem
Steviehtcs
Got a 14 plate r, heaters not blowing as hot as normal, loosing a bit of coolant once a week and the pressure in bottle is massive; slowly unscrew cap tons of air and then coolant just starts pouring out, if I run car and n idle with cap off with in a few minutes coolant boils up and pours out bottle, anyone any ideas
  • Replies 6
Is the silicone bag intact in the header tank?
Any white smoke / steam coming out of the exhaust?  Normally the case if the head gasket has gone together with mayonnaise on the oil filler cap and dipstick as per Nostig's post.
There is also a tester that you put in the antifreeze that detects combustion contamination.
