haldex controller adaption,re activating modules, please help
Markt
Hi guys I have just fitted a second hand haldex controller to my 2015 Golf r and now I have loads of error codes.
03 Brakes
    System description: ESC
    Software number: 3Q0907379R
    Software version: 0711
    Hardware number: 3Q0907379G
    Hardware version: H42
    Serial number: 61185000000882
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 034036
    Long coding: 01FA93A154252970077C070141CC6980C92A94E0E08296F718425078C208
    Trouble codes:
        U112100 - Databus missing message
            static
                Date: 2021-01-02 15:18:19
                Mileage: 54266 km
                Priority: 2
                Malfunction frequency counter: 1
                Unlearning counter: 165
                Extended Freeze Frames: 0000001872000000CD00F100FF00006302430001010010
13 Adaptive Cruise Control
    System description: ACC Bosch MQB
    Software number: 5Q0907572D
    Software version: 0304
    Hardware number: 5Q0907572D
    Hardware version: H05
    Serial number: 18041503213033
    ODX name: EV_ACCMRRBoschVW372
    ODX version: 001015
    Long coding: 001C1300FE0739
    Trouble codes:
        U112300 - Databus error value received
            static
            static
            static
        B10E7F0 - Cruise Control Front Distance Range Sensor separated
            static
19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530AC
    Software version: 2203
    Hardware number: 5Q0907530M
    Hardware version: 212
    Serial number: 29041510800441
    ODX name: EV_GatewConti
    ODX version: 011020
    Long coding: 030100042F085900EF00027E1C0F00010001050000000000000000000000
    Subsystems:
        System description: J367-BDMHella
        Software version: 8050
        Hardware version: H04
        Serial number: 0587246603
        System description: E221__MFL-DC1
        Software version: 0040
        Hardware version: H10
        Serial number: 29150000875770035181
        Long coding: 2DFFFF
    Trouble codes:
        U011400 - Lost Communication With Four-Wheel Drive Clutch Control Module
            static
        U106600 - Radio No Communication
            static
        U112400 - Data bus Additional installations detected
            static
Basically I have been left with no TPMS,no ESC or TC,no Parking sensors and no ADAPTIVE CRUISE OR ASSISTANCE and still no AWD.
Module 22 AWD in the list has a black circle as does 56 radio and I think I accidentally removed the modules.I have added them to the list but they are not active now and I don't know how to re activate them.
please can someone help?
Sorry for the very basic response but guessing you've driven the car for 5 mins since scanning?
Seem to recall seeing threads that a battery disconnection throws up a multitude of faults that are cleared within the first few minutes of driving.
Hoping you get it fixed.
J.
@Markt hi
First thing is to get the installation list in the Gateway module fixed. OBD11 has an automatic fix for this called AUTOCODE - see testeronline post about two-thirds down the thread  HERE
After this, clear the errors and re-post another copy of your scan report - unedited please
Right,I have done the auto code and that removes module 22(all wheel control).when the control unit 22 is added the number is in a black circle.Below is a list of faults. I’m beginning to think I’ve been sold a goosed controller. Just one last thing,the controller was from a TTS and was just a later revision of the same part number.
OBDeleven data log
Date: 2021-01-07 18:04
VIN:
Car: Volkswagen Golf R
Year: 2015
Body type: 5-dr hatchback
Engine: CJXC
Mileage: 54459 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259E
Software version: 0005
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259E
ODX version: 001005
Long coding: 091D00322466050B2004
Trouble codes:
static
Date: 2021-01-07 06:00:23
Mileage: 54459 km
Priority: 6
Unlearning counter: 255
Engine speed: 1704.75 1/min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 36 °C
Intake air temperature: 45 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.542 V
Dynamic environmental data: 20962841690000416A0005416B0001
02 Transmission
System description: DQ250-6A MQB
Software number: 0D9300012L
Software version: 4522
Hardware number: 02E927770AQ
Hardware version: H53
Serial number: TFK01504212750
ODX name: EV_TCMDQ250021
ODX version: 001001
Long coding: 0014
Trouble codes:
P173400 - Starter release from the selector lever sensor system
Intermittent
03 Brakes
ODX version: 034036
Trouble codes:
static
Date: 2021-01-07 05:57:33
Mileage: 54459 km
Priority: 2
Unlearning counter: 177
Extended Freeze Frames: 0000001852000000A500010000FF005902400000000010
08 Air Conditioning
System description: Climatronic
Software number: 5G0907044BC
Software version: 1001
Hardware number: 5G0907044BC
Hardware version: H03
ODX name: EV_ACClimaBHBVW37X
ODX version: 004131
Long coding: 00120004200100011005004000101000
Trouble codes:
No trouble codes found
09 Central Electrics
System description: BCM MQBAB H
Software number: 5Q0937084AJ
Software version: 0137
Hardware number: 5Q0937084AJ
Hardware version: H18
Serial number: 01011512600558
ODX name: EV_BCMCONTI
ODX version: 013000
Long coding: 03001A42C24122F30BA44080B10C07281000000000000000000000000000
Subsystems:
System description: WWS 150423
Software version: 0551
Hardware version: 042
Serial number: 150429060603
Long coding: 0E4DDD
System description: RLHS
Software version: 0059
Hardware version: 037
Serial number: S2Y15M05D12H12M19S32
Long coding: 90A8DD
System description: Sensor, DWA
Software version: 0315
Hardware version: 005
Serial number: 000000000ZY150890P1Y
System description: Sirene, DWA
Software version: 0311
Hardware version: 004
Serial number: 00000000000062341951
Trouble codes:
ODX version: 001015
Trouble codes:
static
Date: 2021-01-07 06:01:13
Mileage: 54459 km
Priority: 6
static
Mileage: 54459 km
Priority: 6
static
Mileage: 54459 km
Priority: 6
static
Mileage: 54459 km
Priority: 6
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655AA
Software version: 0386
Hardware number: 5Q0959655AA
Hardware version: 014
Serial number: 003MLR0EKTFM
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002130
Long coding: 98CCC000000000005C0000CF00C800000065
Subsystems:
System description: BeltPretRevFL
Software version: 0350
Hardware version: H36
Serial number: 34169677B05051541373
Long coding: 333135
System description: BeltPretRevFR
Serial number: 34169676B07051580612
Long coding: 333135
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 35767000000E87EC1413
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 35867000000FB5EC1416
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Serial number: 3516502C71A8786582FP
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3526502BD1A91E71F3BX
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3556502991A2DCD5634R
Long coding: 2D2D2D
Trouble codes:
16 Steering Column
System description: Lenks. Modul
Software number: 5Q0953507DD
Software version: 0110
Hardware number: 5Q0953549C
Hardware version: 002
Serial number: 05051504221439
ODX name: EV_SMLSKLOMQB
ODX version: 017001
Long coding: 0C10
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 5G1920958
Software version: 4310
Hardware number: 5G1920958
Hardware version: 304
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009043
Long coding: 27AD08082F80260001882A011400000000000000
Trouble codes:
19 Gateway
ODX version: 011020
Subsystems:
Long coding: 2DFFFF
Trouble codes:
42 Driver Door
System description: TSG FS
Software number: 5Q0959593D
Software version: 0028
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 230415BDN03471
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 003F0220D001048000001000
Subsystems:
System description: FOND_FHSG_DRV
Serial number: 00000000000006061877
Long coding: 0D0000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 3Q0909144H
Software version: 5061
Hardware number: 3Q0909144H
Hardware version: 505
ODX name: EV_SteerAssisMQB
ODX version: 012140
Long coding: 8103
Trouble codes:
52 Passenger Door
System description: TSG BFS
Software number: 5Q0959592D
Hardware number: 5Q0959592B
Serial number: 270415BDQ13493
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Long coding: 003F0020DE01048000801000
Subsystems:
System description: FOND_FHSG_PSG
Serial number: 00000000000006084181
Long coding: 150000
Trouble codes:
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357D
Software version: 0090
Hardware number: 7P6907357A
Hardware version: H07
Serial number: --------------
ODX name: EV_HeadlRegulVWAFSMQB
ODX version: 001120
Long coding: 02AE01000B000200
Subsystems:
System description: LeiMo links
Software version: 0002
Hardware version: H01
Long coding: 2E0000
System description: LeiMo rechts
Long coding: 2E0000
Trouble codes:
5F Multimedia
System description: MU-S-D-ER
Software number: 5G0035842
Software version: 0421
Hardware number: 5G0035842
Hardware version: 041
Serial number: V7E00505150644
ODX name: EV_MUStd4CPASE
ODX version: 002039
Long coding: 027300000000000021111202000800001F0207260100010001
Subsystems:
System description: ABT_Std_Radio
Software version: 0030
Hardware version: H60
Serial number: VWZ8Z9RS2077U1
Trouble codes:
76 Parking Assistance
System description: PARKHILFE 8K
Software number: 5Q0919294E
Software version: 0048
Hardware number: 5Q0919294A
Serial number: 39391512504858
ODX name: EV_EPHVA18AU3700000
ODX version: 002024
Long coding: 0071051011
Trouble codes:
static
Date: 2021-01-07 05:58:11
Mileage: 54459 km
Priority: 6
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159B
Software version: 0006
Hardware number: 4H0907159A
Serial number: 150328200531
ODX name: EV_SoundActuaGen2AU64X
ODX version: 003010
Trouble codes:
hmm........the  Black colored circle means that the hex22 module has been added to the Gateway list, but it hasn't responded when polled by the hex19 module. If it was my car I would be checking the wiring loom and the connector - pay particular attention to the CAN high/Low wires/pins  on the 8 x pin connector - and the power supply terminals (especially earth).
Problem found,2 broken wires where they enter the plug that connects to the Haldex controller.
I am going to try and repair the connector as fitting a new harness requires the fuel tank to be dropped.
Thanks for the advice Don
That was fortunate - I think you owe Don a beer or 2. However does that mean your original haldex was OK and it was just the wiring all along?
