Tyres question
R-chef
I bought my first R in December last year. A 2017 Mk7.5, lapis blue, 20500 miles. I now need to buy two new front tyres and am going for Bridgestone Potenza S001 but am not sure where to place them, front or rear. Given it’s 4WD but not permanent 4WD, are the new tyres better to be fitted front or back??
any help more than appreciated.
I’m a proponent of new tyres on the rear.  It can be a divisive topic though.  Some info in this thread worth a look as to why new rubber on the rear.
https://www.vwroc.com/forums/topic/22983-new-tyres-front-or-rear/?do=findComment&comment=371446
There are better tyres for the R than S001s such as Michelin PS4S so worth a think about that.
Welcome along too!
Thank you both for the replies. Some good reading there.
ive read many good things bout the pilot sport 4 so will def try them
in future. I am a great believer in having all 4 corners shod with the same tyre and my rears at the moment are potenza so next time I need tyres it will probably be a full set and looks like mps4 ….
Thanks again.
Does anyone have any issues with interior panel vibrations. I’ve got a really annoying vibration in the front passenger side that I just can’t track down. Sounds like it’s coming from the tweeter grill on the side pillar?…
Have you tried the rear view mirror housing?
That or pull on passenger door grab handle and see if it stops.
Also, +1 on avoiding Bridgestone. They're too hard, wear too quick and have crap grip imo.
Always worth having a passenger in the car when checking for the source of unwanted noises, which can originate from somewhere completely different to where you think they’re coming from. The passenger can be that extra pair of ears to try and track down the noise source, and apply pressure to trim panels to see if the noise stops - very difficult for you do do while driving! Alternatively, if anyone else is insured to drive your car, you can be the passenger to do the listening and apply pressure to the panels while someone else drives.
Quite a common unwanted noise / vibration sources are;
  • the hard plastic cover on the vanity mirror in the sun visor vibrating against the vanity mirror lamp when the sun visor’s folded back against the headlining and not in use.
  • the hinged door on the sunglasses compartment, or loose items in the sunglasses compartment
  • the adjustable upper seat belt mounting point on the B pillar can also vibrate - moving it up or down a notch can stop the vibration.
+1 For the sun visor. For me it's the hinge itself. I either have to open it slightly (and optionally put something inbetween to avoid it from folding in completely), or give it a firm push close. I've been too lazy to bother with putting some grease on it as it comes from the hinge itself for me for sure.
  • Booth11 changed the title to Tyres question
Interesting comments bout the Potenza tyres too. I thought their life was pretty good. I’ve read that the MPS4 is excellent grip but very soft therefore quick wearing?? Is this wrong?
Is the Michelin very much better?
MPS4S are a much better tyre than Bridgestone S001s in pretty much all areas - wet grip, dry grip, comfort in poor roads, noise etc.  Obviously wear can differ depending on a number of factors but on my mk7R I got over 20k miles out of my first set of PS4S which I was astounded at.  The Conti 5Ps they replaced I hit 13k miles out of.  I now have Goodyear Eagle F1 Supersports in the 8R and so far they are proving to be a very worthy contender to the PS4S.
  • 3 weeks later...
Tire update. I was recently in need of new front tires on my mk7.5 and had ordered 2 new Bridgestone Potenza to match the rears. After reading the replies from you helpful owners i decided to change all 4 to Michelin pilot sport 4s and I am very happy that I did. Excellent grip, quieter and a lot more feed back to me. So, thank you to all those who advised. Much appreciated.
Any thoughts on engine oil??
