dv52 Posted July 25, 2021 Report Share Posted July 25, 2021 8 hours ago, Markyo7 said: Turned indicator s off but left one don’t flash anymore I assume that you mean FRONT left indicator where I've shown options with "/", the first is incandescent and the second is LED: Leuchte 0 BLK VL B36 Lasttyp 0 > 12 - Blinkleuchten/33 - LED-Modul Blinkleuchten Lampendefektbit Position 0 > 34 Fehlerort mittleres Byte DTC-DFCC 0 > 14 Lichtfunktion A 0 > Blinken links Hellphase Lichtfunktion B 0 > not active Dimmwert AB 0 > 100/127 Lichtansteuerung HD AB 0 > Always Lichtfunktion C 0 > not active Lichtfunktion D 0 > not active Dimmwert CD 0 > 0 Dimming Direction CD 0 > maximize Lichtfunktion E 0 > not active Lichtfunktion F 0 > not active Dimmwert EF 0 > 0 Dimming Direction EF 0 > maximize Lichtfunktion G 0 > not active Lichtfunktion H 0 > not active Dimmwert GH 0 > 0 Dimming Direction GH 0 > maximize Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 Are these all the correct setting for indicators to work ? Quote Link to comment Share on other sites More sharing options...
OOV Posted July 25, 2021 Report Share Posted July 25, 2021 Yes. exactly as dv52 says. Dimmwert value is the brightness. Check you have Lichtansteuerung HD AB 0 > Always maybe the problem? Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 You are a legend buddy I must of pressed something wrong I have no right indicator to managed to get rid of the amber lights as drls now no indicators 🙈 Quote Link to comment Share on other sites More sharing options...
OOV Posted July 25, 2021 Report Share Posted July 25, 2021 Leuchte1BLK VRB20 is the right indicator, Same as dv52 posted above, except Lichtfunktion A 0 > Blinken rechts Hellphase Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 Thanks ever so much for your help guys I’m gonna play around with the obd11 and let you know Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 Managed to get both indicators to work but when I now put hazard lights on only the left side flashes not the right side some settings look different for the right side Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 There’s no setting lichtfunction A 0. For the right side indicator?? Quote Link to comment Share on other sites More sharing options...
Markyo7 Posted July 25, 2021 Author Report Share Posted July 25, 2021 ITS ALL DONE NOW THANKS TO YOU GUYS 1 hour with obd11 I LUV THIS FORUM MANY THANKS OOV 1 Quote Link to comment Share on other sites More sharing options...
Martin2 Posted July 27, 2021 Report Share Posted July 27, 2021 On 12/07/2021 at 10:18, Ignition1 said: Yeah I've seen a lot of Ranges with front indicators as DRLs - hate that as well. Looks much better with just the standard blue/white DRL instead of it being mixed in with yellow. I do like the rear DRLs you can enable on some cars - "Scandinavian mode" I think it was called in VCDS in the Audi A3 8V. That makes sense for hazards actually, more eye catching. Thankfully I haven't seen any, I wouldn't like it either. My RR has the rears on all the time, which was standard (it's a 2019), it hasn't been messed with. Quote Link to comment Share on other sites More sharing options...
romprod Posted August 25, 2022 Report Share Posted August 25, 2022 On 25/07/2021 at 20:50, Markyo7 said: ITS ALL DONE NOW THANKS TO YOU GUYS 1 hour with obd11 I LUV THIS FORUM MANY THANKS Sorry to resurect an old post, can I follow the original instructions or is there more to be done that you later resolved? I like the idea of the DRL but hate that the yellow indicator light is always on, which has already confused people at junctions\rounadbouts because they can't see that I'm indicating, so I've turned th DRL off to stop this. Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 26, 2022 Report Share Posted August 26, 2022 @romprod Hi. First, two basic pieces of information: ONE: the Leuchte-sets (being the group of 19 x adaptation channels that control a particular lamp on a mk7/mk7.5) for the 2 x front blinkers are: Leuchte 0 BLK VL B36 (left-side) Leuchte1BLK VRB20 (right-side) TWO: the Leuchte-command for the DRL lighting function is Tagfahrlicht for OBD11 and it's Daytime running lights for VCDS. So, to delete the DRL function from the 2 x front blinkers - simply look through the 2 x Leuchte-sets above (in particular, look in each of the 8 x Lichtfunktion channels) for the DRL Leuchte-command (again, as above) and change the value to nicht aktiv for OBD11, or not active for VCDS. Don romprod 1 Quote Link to comment Share on other sites More sharing options...
