Which one?
Peterb3n
5 hours ago, Peterb3n said:
After trawling through lots of posts both here and elsewhere, I'm struggling to decide which OBDeleven to go with. Is the Ultimate pack worth the extra? I'm not good with coding so plan on using only the one click apps. Any advice appreciated.
If you’re only going to use the apps then you don’t need the Pro version, the basic pack will suffice.  BUT…. if you get the Pro then that does give you the option to do coding which is the better way to do changes as you can track exactly what you’ve changed and if needed reverse the changes in the same way.  However that said, you can purchase Pro activation at a later date should you decide to look at some coding.  The Ultimate Pack gives you a few extras but depends whether any of those things are worth it to you.  I have the NextGen Pro version and only use coding so suits me well and personally thing that’s the better option.
Be careful with the one click apps.Some people have had issues with these and can’t revert to what code was there before as they don’t know what’s changed.
Yes at least with coding you’re in control and can reverse what you’ve done, as there’s a history kept.  And if you do get into a mess OBDeleven supremo @dv52 is always a great help on this forum
Please NEVER use the apps, or you'll become one of those sad souls complaining that you did X, Y and Z, and now A, B and C don't work and you don't have a backup or any idea what was changed. Remember that apps are a fairly generic solution and if something goes wrong (i.e. you're trying to do something not supported on your own car) you won't know about it until it's too late. Coding lets you see immediately if something hasn't worked.
Also, in order to stay sane, make only one change at a time (whether app or coding) and WRITE IT DOWN, then TEST IT. Once it's working as expected you can move on to item #2 on your list. There's plenty of free advice available, and you'll soon become an expert!
My suggestion for the best deal: get the plain NextGen device and the Pro Plan. Don't pay for credits that you really shouldn't be using. 🙂
