AHG Posted October 8, 2021 Report Share Posted October 8, 2021 Hey, Just got my OBDeleven NextGen with Pro subscription, and started playing around, and got a couple of fault codes in the engine module.Then I tried to do start/stop and sound at closing, first one worked, second didn’t, then I put it all back.And them I got another code in module 19 (engine was on an bonnet wasn’t open the second time, so maybe that’s it). Does anyone know what these fault codes mean, and if I can just clear them or should I do something ?(couldn’t find anything useful online) Module 19 - Gatewayu120200Module 01 - Engineu112300u041600 B. It calls my car A3 with body style unknown (it’s a S3 saloon), couldn’t find how to change it (saw a video showing it asks you, but it didn’t ask me).Is it important that this is accurate ? Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Hey, Just got my OBDeleven NextGen with Pro subscription, and started playing around, and got a couple of fault codes in the engine module.Then I tried to do start/stop and sound at closing, first one worked, second didn’t, then I put it all back.And them I got another code in module 19 (engine was on an bonnet wasn’t open the second time, so maybe that’s it). Does anyone know what these fault codes mean, and if I can just clear them or should I do something ?(couldn’t find anything useful online) u120200u112300u041600 B. It calls my car A3 with body style unknown (it’s a S3 saloon), couldn’t find how to change it (saw a video showing it asks you, but it didn’t ask me).Is it important that this is accurate ? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 8, 2021 Report Share Posted October 8, 2021 @AHG Regards your second question, iirc when I first added my 8R it just came up as generic mk8 with body type unknown, engine unknown, but production date, the VIN and mileage all accurate. I deleted it and re-added it with the VIN but engine type still not recognised so am contacting OBDeleven about it. You can change the name manually. Go into Garage. Tap anywhere on the car photo (don’t tap the X) and the info comes up. For the ones you can change (Name, Image) there’s the words ‘Change’ in green. You can edit those but it’s essentially just renaming and adding your own photo. Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Thanks !I tried the change but it didn’tI will try to tap on the photoRe codes, so you have any idea or source of information ?I think databus faults are usually closed lid or engine running while scanning, but want to make sure before I clear them. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 8, 2021 Report Share Posted October 8, 2021 3 hours ago, AHG said: Thanks ! I tried the change but it didn’t I will try to tap on the photo Re codes, so you have any idea or source of information ? I think databus faults are usually closed lid or engine running while scanning, but want to make sure before I clear them. Give it another go as it let me change the title on mine. Re the codes, engine running can throw up some codes. I did my last two adaptations with the engine running (as my battery voltage was on the low side) and it threw up several codes that I just cleared. But that might have been because the bonnet was not released as I was unaware of that at the time. If you go into the codes and tap on each one, it should bring up more info and in some cases it will link you to online info. I’m no expert on codes though and somebody like @dv52 is better placed to advise. Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Per chance, may I be so bold as to ask you to take a peek in your app history and see what those codes were ? Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Managed to change the name(just had to tap Submit and not Close :-))But in all the video I viewed it asked the user questions upon connecting the car initially, like specific model and body type. But I had no such option.If it doesn’t matter, than I can let it go.Just need some reassurance that A3 Coupe is identical to S3 Saloon, OBD-11-wise. Quote Link to comment Share on other sites More sharing options...
JonnyG Posted October 8, 2021 Report Share Posted October 8, 2021 There is a way to upload the whole scan log a text file which you can then send to your email and peruse at leisure 👍 It's quite a few pages long ! Example snippet :- Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Problem is, I don’t think I’d know what it means :-) Quote Link to comment Share on other sites More sharing options...
JonnyG Posted October 8, 2021 Report Share Posted October 8, 2021 4 minutes ago, AHG said: Just need some reassurance that A3 Coupe is identical to S3 Saloon, OBD-11-wise. I'm pretty sure the VIN is the most important thing and what OBD uses, but I'm no expert !! Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 Do you think I can clear the codes and if it’s a real problem they will come back ?Or should I resist and wait until I understand what they were ? Quote Link to comment Share on other sites More sharing options...
JonnyG Posted October 8, 2021 Report Share Posted October 8, 2021 The full scan log gives you the number of occurrences and the date they occurred. You can then make the decision as to whether to clear them or not. Personally I have cleared them in the past (on older cars) if my car has been running fine. However on my recent scan (current MK 8) I had a lot of recurring faults 😲, so I have left them all uncleared just in case I need the dealer to look at anything in the future under warranty. AHG 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 8, 2021 Report Share Posted October 8, 2021 18 minutes ago, AHG said: Do you think I can clear the codes and if it’s a real problem they will come back ? Or should I resist and wait until I understand what they were ? Don (dv52) is your best source of info and he is really helpful on here. If you do clear them, if they are persistent then they’ll likely show up on a future scan. Have you done a full scan? Quote Link to comment Share on other sites More sharing options...
AHG Posted October 8, 2021 Author Report Share Posted October 8, 2021 I did. 3 times. First time only the 2 engine module faults popped up.Second time there was a new one on module 19.Third time today, all three appeared.I cleared the one on module 19, since I think it may have come from me scanning with the engine on.The other I fear to clear, as I don’t know their source, and if I need them documented somehow (does the history in the app save codes that were cleared ?)Is [mention=20064]dv52[/mention] here in this forum and can see this thread ?P.S. I didn’t open the bonnet last two times, and it still did what I asked it to. Maybe it is different in Audi or older cars (2018) ? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 8, 2021 Report Share Posted October 8, 2021 2 hours ago, AHG said: I did. 3 times. First time only the 2 engine module faults popped up. Second time there was a new one on module 19. Third time today, all three appeared. I cleared the one on module 19, since I think it may have come from me scanning with the engine on. The other I fear to clear, as I don’t know their source, and if I need them documented somehow (does the history in the app save codes that were cleared ?) Is [mention=20064]dv52[/mention] here in this forum and can see this thread ? P.S. I didn’t open the bonnet last two times, and it still did what I asked it to. Maybe it is different in Audi or older cars (2018) ? In History - the log of each scan is retained even if you clear codes (it also retains the info on cleared faults), so you still have a record of the log that you can email to yourself. What I found on my 8R was a full scan without the bonnet catch released I got multiple fault codes (which is what I originally did as I wasn’t aware at that stage of the bonnet release requirement for the coding etc). I cleared them and have subsequently done a scan with the bonnet released and got 0 codes. Now I don’t know exactly when the bonnet release necessity came into effect but if yours is accepting coding changes without it being released maybe your car pre dates that. Certainly on the mk8 it’s necessary for coding changes and it appears to affect the scanning too. Yes @dv52 is an active member on here and appears to regularly view the forum obdeleven / VCDS sections and regularly helps out members with such queries. He is in Oz I believe so time difference comes into play. Quote Link to comment Share on other sites More sharing options...
