Buggeredifino Posted August 26, 2023 Report Share Posted August 26, 2023 So, I've had my 8R for 2 months now. Absolutely loving it, but the lane guidance is doing my head in. It's steered me towards a hedge, a pothole and a cyclist once to often, so I reckon an OBD eleven is called for. Is the OBD11 the best way ahead? Are there alternatives that are better, or at least worth consideration? Having had a look, am I right in thinking the "Pro Pack" with the NextGen device and the PRO VAG plan is the option to go for? As a secondary question: those of you who have used it, what other functions and changes have you found beneficial? As always; thanks in advance. Cheers, Dave Quote Link to comment Share on other sites More sharing options...
neilybealy Posted August 26, 2023 Report Share Posted August 26, 2023 There’s a whole section in the forum for obd11. Can’t link to it on my phone but click on the main forum list and scroll down Quote Link to comment Share on other sites More sharing options...
Buggeredifino Posted August 26, 2023 Author Report Share Posted August 26, 2023 Thanks Neil. I thought there would be but a search just gave me a whole load of individual posts but no overall section or thread. If I'm wrong and my searching/eyeballs need work, I apologise!🤣 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 26, 2023 Report Share Posted August 26, 2023 58 minutes ago, Buggeredifino said: Thanks Neil. I thought there would be but a search just gave me a whole load of individual posts but no overall section or thread. If I'm wrong and my searching/eyeballs need work, I apologise!🤣 Definitely get the NextGen dongle with Pro pack (on VAG Pro plan), which allows you to code properly and not rely on the one-tap apps (to be avoided), which you have no control over and no knowledge of what they are changing. You’ll be able to keep a history of what you change just in case you ever need to undo something or want to return anything you change back to factory for any reason. Here is the link to the obdeleven board. https://www.vwroc.com/forums/forum/84-obdeleven/page/3/ Anything with ‘Mk8’ and ‘coding’ in the title is relevant, so have a browse to see what other things people have done, mainly the first two pages of the board. Here’s the link to the Lane Assist coding for obdeleven. I already had obdeleven but worth it just to turn that off. Quote Link to comment Share on other sites More sharing options...
Buggeredifino Posted August 26, 2023 Author Report Share Posted August 26, 2023 Brilliant. Thanks Becs Quote Link to comment Share on other sites More sharing options...
AHG Posted August 26, 2023 Report Share Posted August 26, 2023 Remember the device is the same (NextGen) and the rest are just annual packages or credits for apps, so getting the Pro pack makes sense but you will need to renew it (at 50€) every year. I bought the device only, and then bought a plan on their website (you get an activation code). Don’t buy through the app, as it will charge you more (they say it’s due to App Store fees). Their service is very good and they helped me with many things At the moment OBDeleven are the only ones (I know of) offering SFD unlock on their app (via 2-step identification) which is crucial to many of the things you may want to do (without it the car is pretty “closed up”). Here are some changes I did on the 8 (most of them are up in the OBD forum here): - Chirp at lock up - Dynamic lighting system (highbeam assist) - Remember last setting - AC Air Ci4culation - Remember last setting - Soundaktor @ 0% - Turn off Car2X (no service in my location) There are other things that I did on my spouse’s Tiguan and my previously owned S3, like traffic light recognition, start/stop override, honk on close, and other controls for convenience opening of sunroof (which I currently don’t have), but I’m not sure if those can be done on mk8s. Other things I’m still looking for ways to do: - start/stop override (either remember last setting or stays off) - Driving modes - remember last setting (reverts to Sport) - Poor weather light auto-on - Remember privacy setting without being registered (no WeConnect here) neilybealy 1 Quote Link to comment Share on other sites More sharing options...
neilybealy Posted August 27, 2023 Report Share Posted August 27, 2023 11 hours ago, AHG said: Dynamic lighting system (highbeam assist) - Remember last setting Thanks for this, I need to look this up as I thought I read it didn't work on the 8R like it did before Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 27, 2023 Report Share Posted August 27, 2023 @Buggeredifino Dave, if you do get obdeleven, for the SFD protected modules which require a 2-step authentication to unlock SFD protection so you can make changes, Google Authenticator app is good. I use that and it works well. Also when come to do adaptations, with obdeleven, for some, you need to release the bonnet (using bonnet release handle) prior to carrying out the adaptation/coding in order for the adaptation to be accepted. Quote Link to comment Share on other sites More sharing options...
neilybealy Posted August 27, 2023 Report Share Posted August 27, 2023 Yes got SFD unlock sorted but never tried coding the highbeam assist as didn’t know it worked on the 8R. I’ll have to give it a go Thanks for the reminder re bonnet open 😀 Quote Link to comment Share on other sites More sharing options...
AHG Posted August 27, 2023 Report Share Posted August 27, 2023 Works great, but bonnet need to be open. Here’s the change you need to do: Module 09 - Central Electric Adaptation Fernlicht assistent Change to “Not Active” neilybealy 1 Quote Link to comment Share on other sites More sharing options...
neilybealy Posted August 27, 2023 Report Share Posted August 27, 2023 awesome thanks AHG 1 Quote Link to comment Share on other sites More sharing options...
AHG Posted August 27, 2023 Report Share Posted August 27, 2023 19 hours ago, AHG said: Other things I’m still looking for ways to do: - start/stop override (either remember last setting or stays off) - Driving modes - remember last setting (reverts to Sport) - Poor weather light (either remember last setting or automatically turn on when lights go on) - Remember privacy setting without being registered (no WeConnect here) If someone gets any joy (success) with one of those, I’d love to hear about it, so I can get it done as well. Quote Link to comment Share on other sites More sharing options...
neilybealy Posted August 27, 2023 Report Share Posted August 27, 2023 Does the ignition need to be on or off as well please? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 27, 2023 Report Share Posted August 27, 2023 4 hours ago, neilybealy said: Yes got SFD unlock sorted but never tried coding the highbeam assist as didn’t know it worked on the 8R. I’ll have to give it a go Thanks for the reminder re bonnet open 😀 Apologies Neil, my earlier post (on SFD authentication and bonnet open) was actually meant for Dave @Buggeredifino but mentioned you in error. I’ve edited it now. Buggeredifino 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 27, 2023 Report Share Posted August 27, 2023 11 minutes ago, neilybealy said: Does the ignition need to be on or off as well please? Ignition needs to be on. You can do it with or without engine running. neilybealy 1 Quote Link to comment Share on other sites More sharing options...
