Running Man Posted September 17, 2014 Report Share Posted September 17, 2014 No issues with my last 7R, apart from the paint being very needy and time consuming. However that said a beautifully crafted colour with serious flaws. Roll on RED Quote Link to comment Share on other sites More sharing options...
harryhackenbacker Posted September 17, 2014 Report Share Posted September 17, 2014 No issues with my last 7R, apart from the paint being very needy and time consuming. However that said a beautifully crafted colour with serious flaws. Roll on RED Lost track why are you on your seond 7R ??? just curious saw a red today MINT Quote Link to comment Share on other sites More sharing options...
Stubsy Posted September 17, 2014 Report Share Posted September 17, 2014 No issues with my last 7R, apart from the paint being very needy and time consuming. However that said a beautifully crafted colour with serious flaws. Roll on RED Lost track why are you on your seond 7R ??? just curious saw a red today MINT He had the abarth 500 and his R. Couldn't run both, so sold the R. Regretted it. Getting rid of the 500 and ordered another R..... Correct me if I'm wrong Quote Link to comment Share on other sites More sharing options...
Running Man Posted September 17, 2014 Report Share Posted September 17, 2014 No issues with my last 7R, apart from the paint being very needy and time consuming. However that said a beautifully crafted colour with serious flaws. Roll on RED Lost track why are you on your seond 7R ??? just curious saw a red today MINT He had the abarth 500 and his R. Couldn't run both, so sold the R. Regretted it. Getting rid of the 500 and ordered another R..... Correct me if I'm wrong Correct Quote Link to comment Share on other sites More sharing options...
Stubsy Posted September 17, 2014 Report Share Posted September 17, 2014 No issues with my last 7R, apart from the paint being very needy and time consuming. However that said a beautifully crafted colour with serious flaws. Roll on RED Lost track why are you on your seond 7R ??? just curious saw a red today MINT He had the abarth 500 and his R. Couldn't run both, so sold the R. Regretted it. Getting rid of the 500 and ordered another R..... Correct me if I'm wrong Correct I'm good at this game Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted September 17, 2014 Report Share Posted September 17, 2014 Well actually one above the T and one to the right of that now I'm looking at it. It's hard to see the imperfection in the photo. Does it line up with the fixings? Quote Link to comment Share on other sites More sharing options...
Doohie Posted September 19, 2014 Report Share Posted September 19, 2014 Had recently suffered from a slight slipping clutch at 75 mph in 6th gear. Were seated with 5 people in the car..now 2500 miles. will follow up Update Tested yesterday the car and he did it again. remarkable.. was only evident when the oil temperature was 80/90 degrees at 56mp/h around 2200 rpm.. go deeper into the throttle the refs varies about 500 rpm, once the oil above 100 degrees the clutch no longer slips. Update II Today, the car goes in to the dealer for a diagnosis/repair Of course, as always, if you end up going to the garage ... the clutch are no longer slips Wonder how this story will turn out. Update III To have been received after a first time,the car is back at the dealership The first time they have deaerated the hydraulic system that operates the clutch.. they have the car tested on some sprints in 3rd and 4th gear and encountered nothing..thought this was over...until I drove at home by 75 mph/3000 rpm the cluth just did the same as before. I have filmed in the case the cluth is not doing it again but luckily it did happen again during the test drive. Meanwhile, they have taken the gearbox out and the entire cluth will be renewed. One problem..the pieces are not in stock.. Last Update The progress can be followed here...which finally ended well What the hell actually happens with that clutch ?? 4000km after replace It happened again !! Quote Link to comment Share on other sites More sharing options...
Zaphire Posted September 19, 2014 Report Share Posted September 19, 2014 So I currently have my R in for a full detail and according to the detailer the paintwork is shocking. He says it's full of swirls, scratches and deep gouges, some of which he says he isn't going to get rid of as they are so deep! It's been there for around 2 weeks of work so far and I will be picking it up when I'm home. After which the car is going to VW to get the spoiler replaced and for a solution (hopefully) to my infotainment issues. As far as I'm aware VW technical are still looking into it, anddddd to refit/replace the sensor button on the driver side B pillar. While the car is in though I will be making my thoughts known about the issues I've had and about the state of the paintwork. Doubt it will make the slightest of difference BUT buying the top of the line, flagship model should not have as many issues as this. Love the car to bits but disappointed at the same time. Quote Link to comment Share on other sites More sharing options...
panosm Posted September 20, 2014 Report Share Posted September 20, 2014 Here are my dimples. You can see the smaller one like a flat black spot just above the regplate. The larger one is besides it but not visible at this angle. Quote Link to comment Share on other sites More sharing options...
MarkH Posted October 23, 2014 Report Share Posted October 23, 2014 R booked in VW dealer to replace sound actuator (vibrator), replace black rear spoiler bits that are hanging off and rectify rubbing brakes when reversing. has anyone had any of these items rectified, if so, how did it go? Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2014 Report Share Posted October 23, 2014 The black spoilers hanging off is happening a fair bit with the GTI and GTD too. Quote Link to comment Share on other sites More sharing options...
ANewell89 Posted October 23, 2014 Report Share Posted October 23, 2014 I had the plastic trim on the rear windows coming off, the manager tells me there is a fix as fail out for them to be glued on as they're only held on by sticky tape. I fixed mine myself as I gave up waiting for VW, but it is supposed to be having it done correctly when the car goes in for a new seat base next week. Quote Link to comment Share on other sites More sharing options...
courgaR Posted October 23, 2014 Report Share Posted October 23, 2014 My R rear screen trims were coming away, replaced under warranty and coming away again. Big problem on UK Golf Rs. Quote Link to comment Share on other sites More sharing options...
add1ct3dd Posted October 23, 2014 Report Share Posted October 23, 2014 Yep, that's what happens when they're stuck on with double-sided sticky tape, they should be properly bonded! I have no doubts mine will come away again, they were replaced about a month ago. Quote Link to comment Share on other sites More sharing options...
harryhackenbacker Posted October 23, 2014 Report Share Posted October 23, 2014 No Nails double sided , fixed mine in 2 mins ( thanks Ironside for the Tip ) It hangs on to 500 bhp going backwards through Sheffield Quote Link to comment Share on other sites More sharing options...
