nw83 Posted January 29, 2025 Report Share Posted January 29, 2025 (edited) Hi. Sorry.. new here.. Got a 2025 golf with a few faults after a tracker install (owner also on here and knows about them) I've bought an obdeleven next gen device, set up my account, confirmed email, set up google 2 factor, got the bonnet open. I'm using the 'for vag' app as the other one keeps getting in a cycle of telling me my authentication is good and then asking me to re connect. The 'for vag' app seems to connect but takes FOREVER to search for installed modules and then tells me there arent any other than the gateway module? is this normal? Any help greatly appreciated before I accept defeat and pay for it to go back to a dealer Edited January 29, 2025 by nw83 Quote Link to comment Share on other sites More sharing options...
nn7man Posted January 29, 2025 Report Share Posted January 29, 2025 Still not sorted my light issue yet - the rear LHS brake light isn't working so more than just an error code glitch. My tracker installer is struggling to read the error codes with OBD Eleven, he's posted here Anyone know if you need a Pro subscription to read everything? Quote Link to comment Share on other sites More sharing options...
AHG Posted January 29, 2025 Report Share Posted January 29, 2025 Are you using an android or apple phone/tablet to connect with it ? Is the car switched on ? (press start without foot on brake) This is the app I use Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 Tried with ign on and car running. No difference. using iPhone 15 Quote Link to comment Share on other sites More sharing options...
AHG Posted January 29, 2025 Report Share Posted January 29, 2025 No need for pro to scan Only to code Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 6 minutes ago, AHG said: No need for pro to scan Only to code ok thanks. Any idea why I cannot connect then? I’m getting conflicting info. Obd11 forum says it’s locked as it’s SFD2. but you guys seem to think I should be able to connect and clear any codes? On 28/01/2025 at 21:57, dv52 said: @nn7man:Hi. Yes, the tracker installation may "not been anywhere near the rear lights..." - but the wire loom that supplies power and switch-ON/OFF signals to the tail-lights is connected to a module that sits under the dashboard. On a Golf mk8/mk8.5, the location of this module is item #13 in my picture below (assuming that this is a RHD "pommie" car): So, it's not clear from your post whether the error messages in your diagnostic device screen are a direct consequence of the installation work for the tracker - or if it's a genuine, current fault. I suggest that you eyeball the operation of ALL the lamps on the outer left-side tail-light fitting. If the lamps operate OK - the error messages are likely historic (probably the result of the tracker install work). In this case, simply clear the errors with your diagnostic device. If the lamps do not operate properly - maybe it is prudent to have a forceful, but polite conversation with "he" (the bloke who installed the tracker) ? Don Quote Link to comment Share on other sites More sharing options...
AHG Posted January 29, 2025 Report Share Posted January 29, 2025 SFD should be in your way to coding, not to scanning. Many people here with OBD11 and a 8.5 that can try and scan and tell you it works Maybe you haven’t plugged it in all the way ? Power on in the car (started without ignition) ? Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 9 minutes ago, AHG said: SFD should be in your way to coding, not to scanning. Many people here with OBD11 and a 8.5 that can try and scan and tell you it works Maybe you haven’t plugged it in all the way ? Power on in the car (started without ignition) ? I tried multiple times and yes to both (although I'll try again again tomorrow). Also... I've been working with cars for 20 years and I don't THINK I'm an idiot... but there is every possibility that I have missed something so thank you for the advice... even if its simple things. Out of interest should I be using the 'for vag' app or the normal one? For some reason the normal one wont connect to the dongle now (says my 6 digit pin is incorrect)... but the 'for vag' app connects just fine and lets me change the pin so not sure what's going on with the normal app? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 29, 2025 Report Share Posted January 29, 2025 13 minutes ago, nw83 said: I tried multiple times and yes to both (although I'll try again again tomorrow). Also... I've been working with cars for 20 years and I don't THINK I'm an idiot... but there is every possibility that I have missed something so thank you for the advice... even if its simple things. Out of interest should I be using the 'for vag' app or the normal one? For some reason the normal one wont connect to the dongle now (says my 6 digit pin is incorrect)... but the 'for vag' app connects just fine and lets me change the pin so not sure what's going on with the normal app? I have obdeleven and have an 8.5R and haven’t scanned it yet but will do so tomorrow morning to see if I get the same and feedback to you. I have been in to attempt coding and other modules were visible then (such as A5) but the SFD2 protection prevented access for coding. But I haven’t run a scan so will see what happens when I do. I’m also using the obdeleven for vag app. Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 11 minutes ago, Booth11 said: I have obdeleven and have an 8.5R and haven’t scanned it yet but will do so tomorrow morning to see if I get the same and feedback to you. I have been in to attempt coding and other modules were visible then (such as A5) but the SFD2 protection prevented access for coding. But I haven’t run a scan so will see what happens when I do. I’m also using the obdeleven for vag app. greatly appreciated. This thread on obd11 forum best describes what I experienced. https://forum.obdeleven.com/thread/35127/control-unit-responding Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 29, 2025 Report Share Posted January 29, 2025 17 minutes ago, nw83 said: greatly appreciated. This thread on obd11 forum best describes what I experienced. https://forum.obdeleven.com/thread/35127/control-unit-responding Ah, on reading the post on obd11 forum, it clarifies the situation a little. So the scan does go through the various modules but you then try to go into modules other than Gateway 19 without success (I read it at first in your other thread as only scanning Gateway and not finding any other modules). That does sound like the SFD2 protection but I will run scan on mine to compare. When I go into the obdeleven app without being connected to my car (just looked now) and into Garage and click on my car and look at the control units, only Gateway 19 is showing which is in line with that thinking. BTW it’s normal to have to input your VIN to set up a new car and it doesn’t state my Engine or Body type either. Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 2 minutes ago, Booth11 said: Ah, on reading the post on obd11 forum, it clarifies the situation a little. So the scan does go through the various modules but you then try to go into modules other than Gateway 19 without success (I read it at first in your other thread as only scanning Gateway and not finding any other modules). That does sound like the SFD2 protection but I will run scan on mine to compare. When I go into the obdeleven app without being connected to my car (just looked now) and into Garage and click on my car and look at the control units, only Gateway 19 is showing which is in line with that thinking. BTW it’s normal to have to input your VIN to set up a new car and it doesn’t state my Engine or Body type either. OK to the VIN. Sometimes when you click on the 'control units' icon it lists out all the units I expect to see when connecting to a car. Body Control, Central Electrics, ABS, AirCon.. etc. But it wont let me connect to any of them. I get the error "control unit not responding. Check ignition and try again" Other times it only shows the Gateway module (19). It lets me connect to that and says it has some faults, which I've googled and one is to do with the rear cam (which works fine... and the google consensus is to ignore it).. the others seemed non relevant to this issue and again generic ones which most people say are always there and to ignore. If I try to clear them it says its succeeded but they come straight back. I actually took the dash apart again this evening to make sure I hadn't missed something and everything is plugged in as it should be. I didn't go near the BCM or unplug anything other than the air bag switch on the side of the dash and the button cluster with the hazard switch which you have to unplug to get that trim out so you can remove the glove box. Sorry for not being clearer.. its been a long few days on various projects and im trying to problem solve this one late in the evenings and I'm not familiar with the obd11 software yet. Small point.. the car has also been detailed while it's been here... washed and lots of machine polishing. Is there a chance the actual light cluster has failed somehow (water ingress or vibration) and its not a stubborn fault at all but a failed cluster? Symptom is that it seems to function fine.. indicator works, side light works but no brake light on the left / passenger rear cluster. Also the glowing outer section only part illuminates sometimes.. but other times it lights up perfectly. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 29, 2025 Report Share Posted January 29, 2025 17 minutes ago, nw83 said: OK to the VIN. Sometimes when you click on the 'control units' icon it lists out all the units I expect to see when connecting to a car. Body Control, Central Electrics, ABS, AirCon.. etc. But it wont let me connect to any of them. I get the error "control unit not responding. Check ignition and try again" Other times it only shows the Gateway module (19). It lets me connect to that and says it has some faults, which I've googled and one is to do with the rear cam (which works fine... and the google consensus is to ignore it).. the others seemed non relevant to this issue and again generic ones which most people say are always there and to ignore. If I try to clear them it says its succeeded but they come straight back. I actually took the dash apart again this evening to make sure I hadn't missed something and everything is plugged in as it should be. I didn't go near the BCM or unplug anything other than the air bag switch on the side of the dash and the button cluster with the hazard switch which you have to unplug to get that trim out so you can remove the glove box. Sorry for not being clearer.. its been a long few days on various projects and im trying to problem solve this one late in the evenings and I'm not familiar with the obd11 software yet. Small point.. the car has also been detailed while it's been here... washed and lots of machine polishing. Is there a chance the actual light cluster has failed somehow (water ingress or vibration) and its not a stubborn fault at all but a failed cluster? Symptom is that it seems to function fine.. indicator works, side light works but no brake light on the left / passenger rear cluster. Also the glowing outer section only part illuminates sometimes.. but other times it lights up perfectly. I think @dv52 posted a helpful response a page back in this thread regarding the lights and suggested checking a few things. It sounds like there is a real fault with the passenger side brake light then, not just an error showing up. I’m no obdeleven expert, just an amateur user, so all I can do is see if I get the same issue you are encountering with obdeleven in not being able to connect to modules other than gateway. My previous attempts (in order to code) suggest this is the case due to SFD2 protection (the modules are present but inaccessible). I can’t remember the message it came up with but will check tomorrow morning. My experience when running scans is that it is not unusual to get intermittent errors showing up and for the most part usually nothing to be concerned about. I think it’s unlikely that detailing would result in the light cluster failing and water would only get into the cluster of there is some defect that allows it in. I’ve detailed my car fully and done severe, washes and no water ingress into lights at all. No worries about explaining, I understand it’s been a long day for you and trying to get to the bottom of this. Quote Link to comment Share on other sites More sharing options...
nw83 Posted January 29, 2025 Author Report Share Posted January 29, 2025 this is the rear light when its not fully illuminating. See the side and lower part of the outer surround is not lit up. But then other times it does light up.. like when unlocking the car for instance. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 29, 2025 Report Share Posted January 29, 2025 1 minute ago, nw83 said: this is the rear light when its not fully illuminating. See the side and lower part of the outer surround is not lit up. But then other times it does light up.. like when unlocking the car for instance. And presumably the other side fully illuminates when braking? Quote Link to comment Share on other sites More sharing options...
