Warning!
muggins86
The latest VW theory is "A crisp packet may have floated across the road" - If its that sensitive I DEFINITELY want it turned off!
Mine detected a big leaf blowing across the fast lane of the motorway and gave me the audible warning. If that leaf had got lodged on the ACC sensor I suppose the car would have slammed on the brakes. Very slim chance I guess, but that sort of thing is bound to happen to a few unlucky peeps.
Correct me if I'm wrong but I assumed the OP was driving a DSG equipped R with ACC engaged?
The ACC can be switched off and the car's speed controlled by the driver, but left 'on' in the background so that you get the aural and visual distance warnings, together with the red screen of impending death. I've often had that on in that state but never had the car intervene physically when it thinks you're facing a crash?
I also thought a manual equipped car won't brake to a stop according to the driving manual, but I have seen it brake quite hard if it doesn't detect the driver applying brakes as early as it thinks you should. It's a strange sensation!
My car is manual - And I can wholeheartedly confirm that I went from 60mph to 0 - Not a simple slow down but an emergency stop.
I thought the ACC was based on pulse doppler radar so it should only apply brakes if it senses something largish and metallic.
Leaves and crisp bags would not be enough to set off the braking but it might throw a red crevlon warning covering all of the DIS or more likely if got stuck over sensor a no clear view and acc deactivated error. I recall the Danno and a video of him crashing into boxes or a milk crate or something in a field as it didnt work?
Not had any issues with mine so the tech works. Hope they sort it out for you.
I thought it could only bring you down to 18mph in a manual car?
According to the book, everything starts & stops at 18mph, and when I have let the car try and stop itself (following another car to a full stop in ACC mode), once it reaches circa 20mph it tells you to take over braking?
Very strange if its brought you to a complete stop?
Mine worked like that when I was testing it to better understand how it works.  Mine is working fine but the apparent randomness of the OPs situation is a bit concerning...
That 18mph threshold is the limitation of the ACC system using the radar, below 18mph, the parking sensors take over detection duty, allowing the DSGers to come to a complete stop. In a manual car, the system will not brake the car so hard as to force a stall if the revs drop too much. For that reason the manual MK7 is far more likely to give a warning bang on the brakes to prompt the driver to take over and brake/change gear after doing a bit of braking for you.
