Smiwii Posted July 15, 2015 Report Share Posted July 15, 2015 Hi all ive had my R since 02/03/2015 just got in it to drive home from work and come up with start/Stop Error this should be covered on warranty shouldnt it? Quote Link to comment Share on other sites More sharing options...
Lightweight Posted July 15, 2015 Report Share Posted July 15, 2015 yes will be... i got mine june last year and it hadn't worked since i got it, went in for a brake issue and the dealer sorted the stop / start, so I assume it was just a software glitch Quote Link to comment Share on other sites More sharing options...
JonnyG Posted July 15, 2015 Report Share Posted July 15, 2015 Have you tried turning the engine off and back on ? It wouldn't surprise me if its just a one off If not, someone said its a common fault and should be fixed under warranty. Quote Link to comment Share on other sites More sharing options...
Scott7R Posted July 15, 2015 Report Share Posted July 15, 2015 I had that problem too, was the ABS brake vacuum sensor. Was replaced under warrantee Quote Link to comment Share on other sites More sharing options...
Smiwii Posted July 16, 2015 Author Report Share Posted July 16, 2015 Yeah I did try turning it off and on again first thing I tried lol ideal thanks alot for your help guys Quote Link to comment Share on other sites More sharing options...
Roadbuster Posted July 16, 2015 Report Share Posted July 16, 2015 Have you tried turning the engine off and back on ? Yeah I did try turning it off and on Mister Trick the salesman shuffles over "Yeah - you only only ordered the manual start-stop then Guv'ner - common mistake - can i interest you in a Golf Estate R with Auto start-stop post BW22 upgrade? Lovely motor. Paperworks a doddle. Red or Blue for you?" Quote Link to comment Share on other sites More sharing options...
R Soul Posted July 16, 2015 Report Share Posted July 16, 2015 Hi all ive had my R since 02/03/2015 just got in it to drive home from work and come up with start/Stop Error this should be covered on warranty shouldnt it? Happened to me several times. I continue to drive normally to my destination (naturally worried that without the stop/start operating I'm killing a few more polar bears). After leaving it for a little while I then start off again and find it's cleared. I just assumed it was the ECU's 'time of the month'. Worth getting it checked out under warranty though Smiwil or they'll be no polar bears left soon Quote Link to comment Share on other sites More sharing options...
Steve_3939 Posted July 16, 2015 Report Share Posted July 16, 2015 That middle left button is the first thing I do after starting engine. Every single time. bigmac3161, stiggy786, toocoolpash and 1 other 4 Quote Link to comment Share on other sites More sharing options...
R Soul Posted July 16, 2015 Report Share Posted July 16, 2015 That middle left button is the first thing I do after starting engine. Every single time. Why? I love it! My reduced CO emissions means that I can wear a halo which covers some of my baldness (if you squint a bit) tobys, Craig and Steve_3939 3 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted July 17, 2015 Report Share Posted July 17, 2015 Mine does this, I think its due to the short journeys and the battery charge is lower after a long journey it seems not to do it any more. Must look into the charge level using the trip button to confirm. VCDS I think shows nothing. Quote Link to comment Share on other sites More sharing options...
tescor Posted July 17, 2015 Report Share Posted July 17, 2015 using the trip button to confirm How do you do this please? I need to do the same thing. I do mostly short journeys, and my stop start hardly every works. If it does, it tends to be at the end of a longer journey. Quote Link to comment Share on other sites More sharing options...
TechieAli Posted July 17, 2015 Report Share Posted July 17, 2015 Switch the ignition off, then press (and continue to hold) the trip reset button in the middle lower of the instrument panel. It will cycle from first resetting the trip to 0 miles > show "Time" to allow you to change the clock > then keep holding until say "Battery".Release the button and display SOC for a few seconds before returning back to the main screen. It would seem though that this works on some cars others need it enabling via VCDS. tescor 1 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted July 17, 2015 Report Share Posted July 17, 2015 Just tried it on mine, it didnt need VCDS coding. Did clear the trip though. 60% doh. Quote Link to comment Share on other sites More sharing options...
colts99 Posted July 17, 2015 Report Share Posted July 17, 2015 (edited) Your Start/stop only works when there is over 80% battery charge am pretty sure. take it to a dealer they will just leave it on charge over night or if you take it in early morning you most likely recieve it at the end of the day edit - its common on all VW with start/stop Edited July 17, 2015 by colts99 SlowYello 1 Quote Link to comment Share on other sites More sharing options...
Lawrie Posted July 18, 2015 Report Share Posted July 18, 2015 That middle left button is the first thing I do after starting engine. Every single time. It should be the driving mode button to put it back in 'true race' mode Quote Link to comment Share on other sites More sharing options...
