Gadget Posted October 12, 2015 Report Share Posted October 12, 2015 Have searched and not found anything so please point me in the right direction if I am wrong. Ok about 1,000miles ago I replaced the Bridgestones on the front of my R with Michelin Pilot Super Sports. Since then the car has become very twitchy as if it has low tyre pressures on the rear. I was wondering is it the tyres or is it because I never changed all 4 and this is causing the strange effect. Going into VW for a service tomorrow so will get them to check everything as well. Quote Link to comment Share on other sites More sharing options...
Limey Posted October 12, 2015 Report Share Posted October 12, 2015 Are the fronts out performing the rears now you have decent boots on? Dave Quote Link to comment Share on other sites More sharing options...
andy13 Posted October 12, 2015 Report Share Posted October 12, 2015 Have searched and not found anything so please point me in the right direction if I am wrong. Ok about 1,000miles ago I replaced the Bridgestones on the front of my R with Michelin Pilot Super Sports. Since then the car has become very twitchy as if it has low tyre pressures on the rear. I was wondering is it the tyres or is it because I never changed all 4 and this is causing the strange effect. Going into VW for a service tomorrow so will get them to check everything as well. You wouldnt believe what difference a set(4) of tyres can make. Changing the rears is the first step to understanding if there are wider issues. Likely this will resolve your problem though. tobys 1 Quote Link to comment Share on other sites More sharing options...
Gadget Posted October 12, 2015 Author Report Share Posted October 12, 2015 You wouldnt believe what difference a set(4) of tyres can make. Changing the rears is the first step to understanding if there are wider issues. Likely this will resolve your problem though. Just worried that if its the tyres that over £600 down the pan to sort the problem. Are the fronts out performing the rears now you have decent boots on? Dave Am wondering that. Its actually putting me off the car its that bad. Thanks for your help though guys looks like changing the rears is now needed and will get them swapped front to back as well Quote Link to comment Share on other sites More sharing options...
mr gee Posted October 12, 2015 Report Share Posted October 12, 2015 general rule of thumb is to fit the better tyre in the rears. there's something from youtube on this. Some may say the car is awd so don't count but the haldex is primarily fwd so consider this. FBF and Booth11 2 Quote Link to comment Share on other sites More sharing options...
Limey Posted October 12, 2015 Report Share Posted October 12, 2015 Swap front to rear, see if the problem goes? You paid £600 for 2 tyres? Dave Quote Link to comment Share on other sites More sharing options...
Limey Posted October 12, 2015 Report Share Posted October 12, 2015 general rule of thumb is to fit the better tyre in the rears. there's something from youtube on this. Some may say the car is awd so don't count but the haldex is primarily fwd so consider this. Nice 'pants' Dave Quote Link to comment Share on other sites More sharing options...
Gadget Posted October 12, 2015 Author Report Share Posted October 12, 2015 Swap front to rear, see if the problem goes? You paid £600 for 2 tyres? Dave No matter meant that if I had changed all 4 Quote Link to comment Share on other sites More sharing options...
Bugsy_B Posted October 12, 2015 Report Share Posted October 12, 2015 I have 2 PSS rears from my BMW sitting in shed with 5mm still on them, but IIRC they are 245 35's. Quote Link to comment Share on other sites More sharing options...
quattrogmbh Posted October 12, 2015 Report Share Posted October 12, 2015 Ideally on any 4WD vehicle you would replace all 4 at the same time. Different levels of grip and rolling circumference will introduce handling anomalies through thrust angle. Not so much of an issue on our Haldex equipped vehicles, but if you have a torsen differential like in an old school Audi Quattro, the difference in rolling circumference would cause the diff to "Wind up" and over time minimize its service life. Booth11 1 Quote Link to comment Share on other sites More sharing options...
chris_blue Posted October 12, 2015 Report Share Posted October 12, 2015 Driven cars (both same model and variant) on both Pilot Super sports, and Pilot sport 3s, and for the price difference would swear on Pilot sport 3s. The 3s twitched just a little bit quicker (But took ages) on the rolling country roads in damp conditions. Was comparing both to Bridgestone Potenzas 50REO (I think) which were awful to be honest. They used to twitch going round the corner in the rain at 20mph! Worries me as R's are supplied with Bridgestones Booth11 and Gadget 2 Quote Link to comment Share on other sites More sharing options...
Tiger's Wood Posted October 12, 2015 Report Share Posted October 12, 2015 Just make sure you rotate front<>rear on a regular basis. I use Winter wheels/tyres so that's a good opportunity to rotate when they are cycled. Also, you can ask the garage to swap them when going in for a service. (Or you can break out the jack/wrench yourself but that's too much like hard work, especially if you get a 'sticky' nut ooer). Booth11 1 Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted October 12, 2015 Report Share Posted October 12, 2015 I have new pss on the front and 4mm contis on the rear and i have no such issues. And i purposely provoke the rear end too. Quote Link to comment Share on other sites More sharing options...
Mainframe Posted October 12, 2015 Report Share Posted October 12, 2015 Never mix tyre brands either across or between axles. Especially on performance oriented cars. Booth11 and tobys 2 Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted October 13, 2015 Report Share Posted October 13, 2015 Never mix tyre brands either across or between axles. Especially on performance oriented cars. Between axles is fine. Thats an absurd thing to say. Quote Link to comment Share on other sites More sharing options...
