Is this normal
Cossieian
Guys this might sound like a silly question so apologies in advance this is my first DSG car
When slowing down and Stop/Start still activated when braking gently the car will cut out before it even comes to a stop!! Therefore allowing the car to roll on but engine not running??
This may be totally normal but IMO it just don't seem right
I hardly ever use Stop/Start anymore, but with DSG you do get DSG creep but not sure this is what you are describing, as that's usually with the engine still running.  In the times I have used S/S, I can't say I've noticed the car moving forwards whilst the engine was disengaged, and I'm pretty sure I would have noticed, especially at certain junctions where that would be risky.  If you've pressed down on the footbrake properly it should engage Autohold (if you have that set to on), so shouldn't roll forwards at all. If you have your foot still lightly resting on the footbrake usually S/S won't engage and therefore won't cut the engine.
I've used Normal, Race and Individual modes but not tried Eco mode so not sure what happens in that.
No it's in normal mode, maybe hard to describe, basically if I'm in the process of stopping with my foot slightly on the brake, when I lift of the brake but the car still moving basically the engine cuts out and the car will coast along on its own. I'm only talking about 10-15mph but I feel this just shouldn't happen :undecided:
It doesn't sound right.  I'm out later in the car tonight, so will use S/S in normal mode, with foot lightly on brake when stopping and see if it does the same thing at any point.
Have you got Autohold engaged?
Yes, this is normal, there's another thread about it somewhere, but basically its the car pre-empting an auto stop slightly. It's described in the manual and may be MIB2 era cars only. Careful use of the brake pedal can avoid it if you so wish.
Interesting as I haven't experienced this at all.  On my drive this evening I could not get it to do this at all.  Must be down to driving style.
Thankyou that would be great :afro:
yea I always have Autohold engaged :wink:
Whilst out driving tonight, which included lots of junctions, traffic lights etc, I didn't experience what you have described at all.  The engine would cut out only when the car came to a complete standstill each time, not at all before it had come to a halt, and it did not carry on moving forward.  The ONLY time it continues to move forward is if I have kept my foot lightly on the brake, just enough to override the S/S system, then, on lightly lifting off the footbrake, the car will move but of course the engine is still engaged in that scenario.
If other's are describing it as normal (and it's in the manual), then experiencing or not, maybe comes down to the individual's use of the footbrake I guess. At least now you know it's not a fault and nothing to worry about.  Maybe mine has a fault, lol.
One thing I've do quite like if I am using S/S is the kind of 'sweet spot' - the point on the footbrake where the engine restarts after S/S has cut the engine, just as you are lifting off the brake, but before you press the accelerator.  That's quite handy and is also mentioned in the manual BUT strangely, it does not happen every time, so I really think it depends on the exact driving style and conditions of coming to a stop in each circumstance.
But my favourite thing is to switch off Stop Start.
My R arrived last Monday and I noticed this straight away; the stop/start cutting the engine on braking to an almost stop at roundabouts and junctions. I would still be moving and engine was off.
Ive turned the stop/start off as it got annoying.
I wonder if this may be a feature on the newer cars. Mine is an early 2014 and I tried it in all three modes this evening and it doesn't happen.
However if I touch the brake very lightly the start stop won't activate, but with more pressure it activates most of the time.
I find it a bit puzzling. Mine is a newer car - Sept 2015 - and it doesn't happen in either Normal, Race or Individual mode (not tried Eco) . But the (current) manual does mention it, which makes me think it comes down to exactly how, when etc, each person applies the brakes.
The latter seems to be the same for most and has been noted a few times.
Well thanks people that clears things up massively, I guess if I'd bothered to look in the handbook I'd of answered my own question :nerd:
rebecca not sure why you haven't experienced this, as you say it may be down to driving style etc :undecided:  but I Thankyou for your very detailed feedback, very much appreciated indeed :afro:
