Is this normal
Cossieian
I find it a bit puzzling. Mine is a newer car - Sept 2015 - and it doesn't happen in either Normal, Race or Individual mode (not tried Eco) . But the (current) manual does mention it, which makes me think it comes down to exactly how, when etc, each person applies the brakes.
The latter seems to be the same for most and has been noted a few times.
Sorry my first post was a bit vague, but yes Rebecca, it is only newer cars, I believe, that have the prempt and on all cars S/S is rather finicky about brake pressure and (maybe duration) in conjunction with vehicle speed. I guess I may have encountered this sooner than some others as to get into my drive I have to stop (or slow to very slow) on RHS of road, check mirrors etc, swing across at 90deg to LHS of road, engage reverse then pull backwards into drive thru narrow entrance. It's a lot easier with DSG than my old Evo manual, but the S/S took a bit of getting used to - as turning off the engine for .5s between steps was a Pita! ;-)
Yeah, I can see S/S being a major pita in your circumstances.
I’m glad I haven’t yet encountered this pre-empting engine cut out, as I would find that annoying. But anyway I tend to switch S/S off at the start of each drive, not because of the cutting out on stopping which does only occur at a complete stop the way I drive, but because I don’t like the .5 second delay in in starting up again, when I want to move off swiftly. It’s just a bit too long a hesitation for my liking.
So it gets switched off routinely as part of my setting off routine. Get in, seat belt on, ignition on, S/S off, select music…..
And in Race mode or with gearbox in Sport, S/S is deactivated anyway so that’s a bonus.
I don't understand people's issue with s/s on dsg. If you dont want the car to cut out, lift the pressure very slightly off the brake as you come to a halt The car won't cut out. In my wife's focus it's a pain in the ass as it cuts out based on clutch dip.
The problem is, mine has cut out and had to restart as I haven't come to a halt, so your "solution" doesn't work on the newest dsg cars.
Keepimg foot lightly on the brake works for me, but sometimes I just forget to do it.  Switching S/S  off takes care of that.
