Automatic rain control?
A l 3 x
Worked fine on mine this morning, it was not dark enough to need headlights, set off and it started raining a few minutes later, lights came on automatically after the wipers, it stopped raining a few minutes later and it all turned off again, exactly how it should, but there is a slight delay, on purpose to stop lights coming on & off all the time.
Disabling the 'headlights on with rain' option in the menu does just that, however with rain sometimes comes darkness, so that could still trigger the lights in some situations.
  • 2 weeks later...
Just leave the switch in 'Auto' job done, the lights will switch on relevant to the light levels outside, as already mentioned with rain comes a slightly darker sky, the car will pick up on this and operate them if required, another pointer is you will also notice that your lighting around the Rev counter & speedometer will also illuminate but will turn off as conditions get better.
Why bother with working out what sort of lighting you need, just leave in auto......job done.
unless its foggy where auto just doesn't work.
You should have lights on when it is raining though so why you would want them off is beyond me.
